pulsewidth and bandwidth
Started by Fan.Zhang ●July 7, 2010
Hi Experts,
I know bandwidth = 1/pulsewidth.
After reconsider the pulse shape and ISI, this question comes to my
mind.But how it comes in this way?
Thanks,
F
On Jul 7, 5:43&#4294967295;am, "Fan.Zhang" <zf624@n_o_s_p_a_m.sina.com> wrote:
> Hi Experts, > > I know bandwidth = 1/pulsewidth. > > After reconsider the pulse shape and ISI, this question comes to my > mind.But how it comes in this way? > > Thanks, > > F
In mathematical terms, look at the fourier integral and simply apply time dilation to your pulse function. I.e., replace "t" with " a*t " and then define a new variable "T = a*t " and find the jacobian. You will end up with a omega/a term. And that is all there is to that. Thus you have the reciprocal relationship between time and frequenction dilation. IHTH, Clay
Well, that's a rather gross approximation. Not hugely useful when considering ISI I shouldn't think. But maybe..... Think of it this way: Construct a rectangular pulse and run it through a lowpass filter. What happens as you decrease the filter bandwidth? - First, the edges of the pulse start to spread out. - Then, the rise and fall of the pulse spread so much that they meet somewhere near the end of the pulse. - Then, pulse peak amplitude drops as the rise time is longer than ~1/2 the pulse width. - Eventually the pulse doesn't get through the filter "at all". Maybe bandwidth = 1/pulsewidth is somewhere around where the filter bandwidth is 1/pulsewidth. You can try this out with something like Matlab or just using simple math with an assumed RC filter. The output of the filter is just: A *(1-e^-t/RC) A is the amplitude of a rectangular pulse. t is time R is resistance C is capacitance. The bigger RC, the lower the filter bandwidth. So, when t = the pulse width and RC is such that e^-t/RC is around 0.02 i.e. 2% when t/RC=3.9 (or you pick the number) then we might say that the pulse amplitude is reached well enough at the output. If the RC product is great enough, then the output can't reach the selected value. As I recall from the dim past, the "bandwidth" of such a simple filter is 1/RC radians per second or 1/2piRC Hz. And that isn't going to match up exactly with the temporal analysis above that yields an RC perhaps more related to the need. But, I think you'll find that it's close (i.e. within 50%). Fred
well, they *are* proportional to the reciprocal of each other. but the constant of proportionality is dependent on the definitions of bandwidth or pulsewidth.
the inverse-proportionality comes from the fundamental time and frequency scaling property of the Fourier Transform. r b-j
On Jul 8, 3:09&#4294967295;pm, robert bristow-johnson <r...@audioimagination.com>
wrote:
> On Jul 7, 5:43&#4294967295;am, "Fan.Zhang" <zf624@n_o_s_p_a_m.sina.com> wrote: > > > Hi Experts, > > > I know bandwidth = 1/pulsewidth. > > well, they *are* proportional to the reciprocal of each other. &#4294967295;but > the constant of proportionality is dependent on the definitions of > bandwidth or pulsewidth. > > > After reconsider the pulse shape and ISI, this question comes to my > > mind.But how it comes in this way? > > the inverse-proportionality comes from the fundamental time and > frequency scaling property of the Fourier Transform.
For example, if you use an FT table and consider the power spectra (proportional to the square of the FT magnitude) of the gaussian time pulse x1 = exp(-(t/a)^2) and the rectangular time pulse x2 = step(t)-step(t-T), you can see how a and T determine the width of the main spectral lobe. Hope this helps. Greg
On Jul 12, 4:05&#4294967295;am, Greg Heath <he...@alumni.brown.edu> wrote:
> On Jul 8, 3:09&#4294967295;pm, robert bristow-johnson <r...@audioimagination.com> > wrote: > > > On Jul 7, 5:43&#4294967295;am, "Fan.Zhang" <zf624@n_o_s_p_a_m.sina.com> wrote: > > > > Hi Experts, > > > > I know bandwidth = 1/pulsewidth. > > > well, they *are* proportional to the reciprocal of each other. &#4294967295;but > > the constant of proportionality is dependent on the definitions of > > bandwidth or pulsewidth. > > > > After reconsider the pulse shape and ISI, this question comes to my > > > mind.But how it comes in this way? > > > the inverse-proportionality comes from the fundamental time and > > frequency scaling property of the Fourier Transform. > > For example, if you use an FT table and consider > the power spectra (proportional to the square of > the FT magnitude) of the gaussian time pulse > x1 = exp(-(t/a)^2) and the rectangular time pulse > x2 = step(t)-step(t-T), you can see how a and T > determine the width of the main spectral lobe.
a definition that i like to use for the width of a pulse is the width about 92.4% of the entire area of the pulse. the number is motivated by x(t) = exp(-pi*(t/t0)^2) which has Fourier Transform of X(f) = exp(-pi*(f/f0)^2) where the height of both pulses is 1, total area of either pulse is 1, and the pulsewidths in the two domains (t0 and f0) multiply to 1. if you take either pulse, square it (to get power or energy) and integrate it from -t0/2 to +t0/2 (or -f0/2 to +f0/2), you'll get about 0.924 of the total squared area, i think. in the sense of the guassian pulse, if you define pulsewidth that way, then the relationship bandwidth = 1/pulsewidth is exactly correct, and i wonder if it's close to the case for many other classes of signals. it might be interesting to see how that definition compares to the rectangular and sinc() pulses. r b-j
On Jul 12, 12:31&#4294967295;pm, robert bristow-johnson
<r...@audioimagination.com> wrote:
> > &#4294967295; &#4294967295; x(t) = exp(-pi*(t/t0)^2) > > which has Fourier Transform of > > &#4294967295; &#4294967295; X(f) = exp(-pi*(f/f0)^2) > > where the height of both pulses is 1, total area of either pulse is 1, > and the pulsewidths in the two domains (t0 and f0) multiply to 1.
Both x(t) = exp(-pi*(t/t0)^2) and X(f) = exp(-pi*(f/f0)^2) have value 1 at the origin, but why is the area 1 regardless of the values of t0 and f0? It is true that exp(-pi*(t)^2) has area 1, but what about exp(-pi*(t/t0)^2)? Surely stretching (or contracting) the time axis by a factor t0 should affect the area? Similarly for the Fourier transform.... --Dilip Sarwate
On Jul 12, 2:14&#4294967295;pm, dvsarwate <dvsarw...@gmail.com> wrote:
> On Jul 12, 12:31&#4294967295;pm, robert bristow-johnson > > <r...@audioimagination.com> wrote: > > > &#4294967295; &#4294967295; x(t) = exp(-pi*(t/t0)^2) > > > which has Fourier Transform of > > > &#4294967295; &#4294967295; X(f) = exp(-pi*(f/f0)^2) > > > where the height of both pulses is 1, total area of either pulse is 1, > > and the pulsewidths in the two domains (t0 and f0) multiply to 1. > > Both x(t) = exp(-pi*(t/t0)^2) and X(f) = exp(-pi*(f/f0)^2) > have value 1 at the origin, but why is the area 1 regardless > of the values of t0 and f0? &#4294967295;It is true that exp(-pi*(t)^2) has > area 1, but what about exp(-pi*(t/t0)^2)? &#4294967295;Surely stretching > (or contracting) the time axis by a factor t0 should affect > the area?
oops. i overlooked the necessary scaling factor. we need to put 1/t0 and 1/f0 in front of both to get the unity area thing. but then they are not exactly FT of each other so x(t) = 1/t0 * exp(-pi*(t/t0)^2) has area of 1 and FT of X(f) = exp(-pi*(f/f0)^2) and X(f) = 1/f0 * exp(-pi*(f/f0)^2) has area of 1 and an iFT of x(t) = exp(-pi*(t/t0)^2) where in all cases t0*f0 = 1. and because of that, i think it's natural to define t0 as the "pulsewidth" and f0 as the "bandwidth". thanks for keeping me honest. r b-j
On Jul 7, 2:43&#4294967295;am, "Fan.Zhang" <zf624@n_o_s_p_a_m.sina.com> wrote:
Strictly speaking, as far as I know, this is only true for Gaussian. If dt and df are the RMS width in time and frequency respectively, then the time-bandwidth product satisfies dt*df >= 1/2 Gaussian achieves the equality but is neither time-limited nor band- limited.
Comes from Cauchy-Schwarz inequality: http://en.wikipedia.org/wiki/Cauchy%E2%80%93Schwarz_inequality Jitendra
> > Thanks, > > F
Strictly speaking th
I don't understand what Jitendra Rayala <jray...@hotmail.com> wrote:
In response to the OP's statement
he writes
> Strictly speaking, as far as I know, this is only true for Gaussian. > If dt and df are the RMS width in time and frequency respectively, > then the time-bandwidth product satisfies > > dt*df >= 1/2 > > ......Gaussian achieves the equality......
But if "Gaussian achieves the equality", then dt*df = 1/2, not 1 as the OP wrote and to which Jitendra seemed to agree when he wrote "true for Gaussian". Perhaps Jitendra will explain further which is his position, 1/2 or 1. Jitendra also correctly asserted that the Gaussian pulse is neither time-limited nor band-limited. *Any* consistent definition of pulsewidth and bandwidth must take into account the fact that in at least one of the two domains, the support extends to infinity. Definitions such as 99% energy containment (or 92.4% energy containment as rb-j used) etc always work and give finite measures of pulsewidth and bandwidth, whereas some signals have rms pulsewidth or rms bandwidth equal to infinity. This corresponds to the notion in probability theory that some random variables e.g. Cauchy random variables, have infinite variance, as has been noted with some surprise in this newsgroup. --Dilip Sarwate
