Im implementing ITU standard based loudness measurement program and as it states i should use some kind of gating to exclude silence regions from affecting measured average sound level - for example - Ill take general integration time of 3 seconds - if, for example the first second of whole sound contains speech and the last 2/3 of it contains silence (people taking breath, thinking or for similar reasons) then value of loudness i get is smaller than it should be - because im taking silence regions in account. So then there is somehow suggested, but not very well documented solution - you take "instant" (400ms) loudness measurement besides needed (3000ms) integration time and if "instant" loudness is 8LU (LU stands for Loudness Unit) lower than loudness measured in "full time"(3000ms) - you then pause loudness measurement, while you get your instant level in range of long range level. Long story short - you get a number of incoming samples, for example 10ms of them, you calculate your sliding short and long term loudness, then you compare if the short term loudness is 8 units lower than long term and discard that set of samples/pause sound measurement for 10ms samples you just got, effectively ignoring them and keeping your long term loudness in higher level - ignoring those 10ms that are "to silent relative to long term"; So the problem is: since im ignoring all the samples(small chunks of samples actually) that are 8lu lower than my long term loudness level, im effectively blocking my long term loudness level to become smaller when it actually should. From "2010 papers of EBU P/Loud working group: "P/LOUD conducted listening tests in Q4/2009 and January 2010 to determine the best gating threshold. It was found that two candidate gating methods out of the four tested gave good results, both being statistically significantly better than the other two. Those two methods were a gate of 6LU relative to ungated LKFS (‘6rel’) and 10LU relative to ungated LKFS (‘10rel’). For all candidates a block length of 400ms was used. Pragmatically, a value of 8rel was chosen for further informal tests against the other gating function already used by broad‐casters"* P.S Sorry for my En, its not my native language.
Gating sound level
Started by ●July 8, 2010
Reply by ●July 8, 20102010-07-08
On 7/8/2010 11:09 AM, Stormiy wrote: ...> P.S Sorry for my En, its not my native language.Your English is good enough. What is your question? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> > So the problem is: since im ignoring all the samples(small chunks of > samples actually) that are 8lu lower than my long term loudness level, im > effectively blocking my long term loudness level to become smaller when it > actually should. >I think you have something fundametally backwards...discarding the silence should increase your result, not decrease it... After you integrate do you not divide by the time period?, perhaps you are calculating "energy" and should be calculating "power"? Just a guess... Mark
