Band limited function zero crossings, how many?
Started by Ron Hardin February 18, 2004
"Ron Hardin" <rhhardin@mindspring.com> wrote in message
news:4033F78F.68ED@mindspring.com...
> And in fact, if my guess is right, any continuous function at all might
appear in a given
> time window and still be band limited (though huge outside that time
window). Your guess is correct. There is a family of prolate spheroidal wave functions, all limited to any given band, that is complete in any given time interval.
Ron Hardin wrote:
> Is there a maximum number of zero crossings per unit time that a > band limited > function can have? My current feeling is that there isn't. > > I think equivalently, any (continuous) function can be matched by > a band limited function over a finite interval, if you don't care > about what happens outside > that interval? (``matched'' probably must mean arbitrarily > closely.) > > What happens, I think, is that you get exponentially large tails > outside the interval when you do it. > > I'm just going on intuition here. Does anybody know?
I guess you're not talking about a sampled system, which is discrete in time and/or amplitude. And I guess, that you talk of an ideal band-limiter (ideal low-pass) However, you're obviously talking of functions like one-dimensional signal streams, because I guess that zero-crossings make no sense otherwise ? Following is required for the signal then: 1. Every second zero crossing (ZC) has opposite direction: neg->pos, pos->neg, neg->pos, ... 2. Derivate dA/dt (slope) changes sign between consequent ZCs. 3. Second derivate has ZCs between consequent ZCs of the signal. I'd guess that the second derivate of your function must obey the same band-limitation requirements as your original function (except near the borders of the interval) . Thinking of fourier analysis (as far as it is applicable to your function), I would think, that your function cannot have more ZCs than the cosine function with the maximum frequency which is just inside your band. And, only subharmonics of that maximum frequency are allowed as additional components, so that their ZCs coincide with those of this fastest cosine component. Example: If the band-limitation requires frequencies below 500Hz, you'll end up with ZCs not closer than 1ms. However, I'm not so familiar with the hidden places of function theory. Therefore, you'd better check the other postings, and/or reveal which functions you're interested in and why. Bernhard
Matt Timmermans wrote:
> > Your guess is correct. There is a family of prolate spheroidal wave > functions, all limited to any given band, that is complete in any given time > interval. > >
Er, what does that mean? Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
>>>>> "Fred" == Fred Marshall <fmarshallx@remove_the_x.acm.org> writes:
Fred> If you don't like to use infinite sincs then I bet you will find that Fred> suitably windowed sincs will support the same arguments. Is there not a theorem that says you can't have both a time-limited and a band-limited signal? Something about the time-bandwidth product being constant? Ray -- -- -- Ericsson may automatically add a disclaimer. Sorry, it's beyond my control.
On Thu, 19 Feb 2004 08:21:03 +0100, Bernhard Holzmayer
<holzmayer.bernhard@deadspam.com> wrote:
>>Following is required for the signal then: >>1. Every second zero crossing (ZC) has opposite direction: >> neg->pos, pos->neg, neg->pos, ... >>2. Derivate dA/dt (slope) changes sign between consequent ZCs. >>3. Second derivate has ZCs between consequent ZCs >> of the signal.
Do not forget that the zeroes of a function are not necessarily real. For zeroes in the complex plane, the concepts of "positive" and "negative" are not so well defined. Quoting from the Kay and Sudhaker paper that I referenced earlier: "[A] way of representing ... signals is by means of their real and complex zeros. A zero-based representation can be shown to be valid for band-limited signals which is usually the case of interest. Often, however, the process of determining the zero sequence which corresponds to a given waveform may not be trivial. The real zeros of the waveform are its conventional zero axis crossings and are easy to determine by clipping. Usually, the complex zeros are not easy to identify, except through numerical factorization of a trigonometric polynomial. An alternative procedure is to preprocess the signal prior to the zero extraction by means of an invertible transform which converts all the complex zeros into first-order real zeros. In the case of periodic band-limited signals, signal recovery to within a scale factor from the zero crossing sequence is straightforward using a product expansion. For aperiodic signals which are represented by an infinite product, the signal can only ba approximately recovered."
>>Thinking of fourier analysis (as far as it is applicable to your >>function), I would think, that your function cannot have more ZCs >>than the cosine function with the maximum frequency which is just >>inside your band.
It turns out that this is EXACTLY what Kay and Sudhaker did to "preprocess" the signal -- they added a sine whose frequency was incrementally above the band limit of the signal. When the amplitude of the added sine was sufficiently large, the resulting "processed" signal became a sine wave with jittered zero crossings. This implies that there is an upper limit to the number of zero crossings of a band limited signal in a finite time interval -- it is 2(BW)T, where BW is the bandwidth, and T is the interval. Greg Berchin
"Bob Cain" <arcane@arcanemethods.com> wrote in message
news:c11ost12qpp@enews2.newsguy.com...
> Matt Timmermans wrote: > > > > > Your guess is correct. There is a family of prolate spheroidal wave > > functions, all limited to any given band, that is complete in any given
time
> > interval. > > > > > > Er, what does that mean?
It means that you can make a sum of these functions that converges to any function you like within an interval, like Fourier transform can do with sines and cosines. In addition, the entire functions are bandlimited to whatever band you choose, so you are guaranteed to have a bandlimited result. There are lots of nifty things you can do with these. The "prolate spheroidal wave functions" part actually means wave functions in prolate spheroidal coordinates, which means... bla bla bla... I don't think you want to go that way. At least I haven't found any way to relate this construction to the amazing properties these functions have. For a lightish introduction to the good stuff, see: See http://www.math.ucdavis.edu/%7Esaito/courses/ACHA/slepian83.pdf.
"Raymond Toy" <toy@rtp.ericsson.se> wrote in message
news:4n3c97cfbd.fsf@edgedsp4.rtp.ericsson.se...
> >>>>> "Fred" == Fred Marshall <fmarshallx@remove_the_x.acm.org> writes: > > Fred> If you don't like to use infinite sincs then I bet you will find
that
> Fred> suitably windowed sincs will support the same arguments. > > > Is there not a theorem that says you can't have both a time-limited > and a band-limited signal? Something about the time-bandwidth product > being constant?
Raymond, Yes. If one is strictly limited, the other has infinite extent. But, sometimes we get hung up on the difference between a signal and a function where one is real and the other is not. Infinite-extent functions aren't real signals. But, windowed ones can be. So, that was my point here about windowed sincs supporting the argument that there can be no more than one zero per sample period over a time span for a "well behaved" function -> which gets closer to a real signal. So, allowing the bandwidth to be different than perfectly bandlimited doesn't hurt the argument. (I do believe). No. The time bandwidth product from one function or signal to another isn't constant. A "CW" pulse and an "fm sweep" pulse have different TW products. Otherwise it wouldn't be very interesting. It's really a different aspect of somewhat related subjects. Fred
"Greg Berchin" <Bank-to-Turn@mchsi.com> wrote in message
news:u5h930lgfso7o04up2lvh0ait9rnnjqck9@4ax.com...
> Do not forget that the zeroes of a function are not necessarily > real. For zeroes in the complex plane, the concepts of "positive" > and "negative" are not so well defined. >
NB: I was very careful to say that we were talking about zero crossings (of a real function) and *not* the zeros of a function of a complex variable. So, something like f(t) and not H(s). OK? Fred
"Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message
news:oY3Zb.7360$Cd6.652711@news20.bellglobal.com...
> "Bob Cain" <arcane@arcanemethods.com> wrote in message > news:c11ost12qpp@enews2.newsguy.com... > > Matt Timmermans wrote: > > > > > > > > Your guess is correct. There is a family of prolate spheroidal wave > > > functions, all limited to any given band, that is complete in any
given
> time > > > interval. > > > > > > > > > > Er, what does that mean? > > It means that you can make a sum of these functions that converges to any > function you like within an interval, like Fourier transform can do with > sines and cosines.
Matt, Meaning that the larger the family or set of them you use, the closer you get..... The Fourier Series still has its Gibbs phenomenon. Do the PSWFs have some equally nice way to characterise the remaining error? I probably should know..... but don't. (I'm not sure everyone knows what "complete" means.....) Fred
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message
news:R_-dnZ5R7dKZUqndRVn-vg@centurytel.net...
> > "Raymond Toy" <toy@rtp.ericsson.se> wrote in message > news:4n3c97cfbd.fsf@edgedsp4.rtp.ericsson.se... > > >>>>> "Fred" == Fred Marshall <fmarshallx@remove_the_x.acm.org> writes: > > > > Fred> If you don't like to use infinite sincs then I bet you will
find
> that > > Fred> suitably windowed sincs will support the same arguments. > > > > > > Is there not a theorem that says you can't have both a time-limited > > and a band-limited signal? Something about the time-bandwidth product > > being constant? > > Raymond, > > Yes. If one is strictly limited, the other has infinite extent. > But, sometimes we get hung up on the difference between a signal > and a function > where one is real and the other is not. > Infinite-extent functions aren't real signals.
Ooopppss.. I meant "real world" as distinct from "of the real numbers". Fred
