pow/log functions in fixed point
Started by dsp.study July 20, 2010
On 7/21/2010 9:00 PM, Steve Pope wrote:
> dsp.study<learner.study@n_o_s_p_a_m.gmail.com> wrote: > >> This is on a mips processor which doesn't have native floating pt support. >> I have converted from floating pt to fixed pt (8.24) i.e. 8 bits for int >> part and 24 for fraction. >> >> I'd looking at log10 - any pointers would be highly appreciated. > > I'd recommend implementing log2 in fixed point, and recoding > anything to use it instead of log10.
Even without recoding, they differ only by a simple multiplicative constant. Does .30103 seem familiar? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
>> I'd recommend implementing log2 in fixed point, and recoding >> anything to use it instead of log10.
>Even without recoding, they differ only by a simple multiplicative >constant. Does .30103 seem familiar?
Sure, one can put in this factor every time one had used a log10(), but you will have less round-off error accumulating if you don't do this. Whether it's worth redoing your code depends on how sensitive it is to such things. Steve
"Jerry Avins" <jya@ieee.org> wrote in message news:fZO1o.21428$lS1.13758@newsfe12.iad...
> On 7/21/2010 9:00 PM, Steve Pope wrote: >> dsp.study<learner.study@n_o_s_p_a_m.gmail.com> wrote: >> >>> This is on a mips processor which doesn't have native floating pt support. >>> I have converted from floating pt to fixed pt (8.24) i.e. 8 bits for int >>> part and 24 for fraction. >>> >>> I'd looking at log10 - any pointers would be highly appreciated. >> >> I'd recommend implementing log2 in fixed point, and recoding >> anything to use it instead of log10. > > Even without recoding, they differ only by a simple multiplicative constant. Does .30103 seem familiar? > > Jerry
If you can accomodate a reasonably hefty table and your CPU has a fast integer multiply (with the ability to get either a double-wide product or with a MULHI instruction available), quadratic interpolation in a table of function values is hard to beat in my experience. Below I demonstrate how this could be done for log2() in 8.24 fixed point. Our input x is of the form 2^e*m, 1 <= m < 2, m = 1 + f. Using a "count leading zeros" operation, we quickly establish e and f. Given f, 0 <= f < 1, we compute the index i of the closest, smaller, table entry in a table of values of log2(x) on [1,2). The difference between the actual argument and the function argument corresponding to i shall be d. Using the function value from the table, f0, as well as the next two table entries, f1 and f2, we compute the coefficients a, b of a parabola that fits through all three function values. The value of log2(m) is then computed as f0 + ((a * d) + b) * d, which is finally added to the integer part of the result, i.e. log2(2^e) = e, computed earlier. The same technique can be used for exp2(), and pow(x,y) can then be constructed from those two in the straightforward manner. I am aware that this leads to loss of accuracy if x is near 1 and y is large, but in many situations this is good enough. Note that the log implementation below is not fully accurate to the 8.24 precision, but it gets close. -- Norbert #include <stdlib.h> #include <stdio.h> #include <math.h> /* This is a single machine instruction on many platforms */ __inline int clz (unsigned int x) { /* Use Robert Harley's table-based algorithm */ static const unsigned char clz_tab[64] = { 32, 31, 31, 16, 31, 30, 3, 31, 15, 31, 31, 31, 29, 10, 2, 31, 31, 31, 12, 14, 21, 31, 19, 31, 31, 28, 31, 25, 31, 9, 1, 31, 17, 31, 4, 31, 31, 31, 11, 31, 13, 22, 20, 31, 26, 31, 31, 18, 5, 31, 31, 23, 31, 27, 31, 6, 31, 24, 7, 31, 8, 31, 0, 31 }; x |= x >> 1; x |= x >> 2; x |= x >> 4; x |= x >> 8; x |= x >> 16; x *= 7U*255U*255U*255U; return (int)clz_tab[x >> 26]; } /* One or two machine instructions on most platforms */ __inline long long int mul_wide (int x, int y) { return ((long long int)x) * y; } /* compute log2(x) in 8.24 fixed-point format, x != 0 */ unsigned log2_8_24 (unsigned x) { /* log2(x) on interval [1, 2+2/128] in 1.31 format */ static const unsigned int log_tab[130] = { 0x00000000, 0x016fe50b, 0x02dcf2d1, 0x04473475, 0x05aeb4dd, 0x07137eae, 0x08759c50, 0x09d517ef, 0x0b31fb7d, 0x0c8c50b7, 0x0de42120, 0x0f397609, 0x108c588d, 0x11dcd197, 0x132ae9e2, 0x1476a9fa, 0x15c01a3a, 0x170742d5, 0x184c2bd0, 0x198edd07, 0x1acf5e2e, 0x1c0db6ce, 0x1d49ee4c, 0x1e840be7, 0x1fbc16b9, 0x20f215b7, 0x22260fb6, 0x23580b65, 0x24880f56, 0x25b621f9, 0x26e2499d, 0x280c8c76, 0x2934f098, 0x2a5b7bf9, 0x2b803474, 0x2ca31fc9, 0x2dc4439b, 0x2ee3a575, 0x30014ac6, 0x311d38e6, 0x32377512, 0x33500472, 0x3466ec15, 0x357c30f3, 0x368fd7ee, 0x37a1e5d4, 0x38b25f5a, 0x39c14924, 0x3acea7c0, 0x3bda7fa9, 0x3ce4d544, 0x3dedace6, 0x3ef50ad2, 0x3ffaf335, 0x40ff6a2e, 0x420273ca, 0x43041403, 0x44044ec5, 0x450327eb, 0x4600a33e, 0x46fcc47a, 0x47f78f4c, 0x48f10751, 0x49e93016, 0x4ae00d1d, 0x4bd5a1d8, 0x4cc9f1ab, 0x4dbcffee, 0x4eaecfeb, 0x4f9f64de, 0x508ec1fa, 0x517cea63, 0x5269e12f, 0x5355a96d, 0x5440461c, 0x5529ba33, 0x5612089a, 0x56f93433, 0x57df3fd0, 0x58c42e3d, 0x59a80239, 0x5a8abe79, 0x5b6c65aa, 0x5c4cfa6c, 0x5d2c7f59, 0x5e0af6ff, 0x5ee863e5, 0x5fc4c886, 0x60a02757, 0x617a82c3, 0x6253dd2c, 0x632c38ed, 0x64039858, 0x64d9fdb7, 0x65af6b4b, 0x6683e34f, 0x675767f5, 0x6829fb69, 0x68fb9fce, 0x69cc5741, 0x6a9c23d6, 0x6b6b079c, 0x6c39049b, 0x6d061cd3, 0x6dd2523d, 0x6e9da6ce, 0x6f681c73, 0x7031b512, 0x70fa728c, 0x71c256ba, 0x72896373, 0x734f9a83, 0x7414fdb5, 0x74d98eca, 0x759d4f81, 0x76604191, 0x772266ad, 0x77e3c082, 0x78a450b8, 0x796418f2, 0x7a231ace, 0x7ae157e3, 0x7b9ed1c7, 0x7c5b8a07, 0x7d17822f, 0x7dd2bbc4, 0x7e8d3846, 0x7f46f932, 0x80000000, 0x80b84e23 }; int a, b, c, d, e, f, i, t, r, f0, f1, f2; c = clz(x); e = 7 - c; f = x << (c + 1); i = (unsigned int)f >> 25; d = f - (i << 25); f0 = log_tab[i]; f1 = log_tab[i+1]; f2 = log_tab[i+2]; t = (f1 - f0) << 1; a = (f2 - f0) - t; b = t - a; t = (int)(mul_wide(a, d) >> 25) + b; t = (int)(mul_wide(t, d) >> 26); r = f0 + t; return (e << 24) + (((unsigned int)r + 64) >> 7); } int main (void) { unsigned int arg, ref, res, err; unsigned int cnt[4] = {0, 0, 0, 0}; for (arg = 1; arg != 0; arg++) { ref = (int)(2.4204406323122971e+007 * log (arg / 16777216.0) + 0.5); res = log2_8_24 (arg); err = abs (res - ref); if (err > 3) { printf ("arg=%08x res=%08x ref=%08x\n", arg, res, ref); } else { cnt[err]++; } if (!(arg & 0x07ffffff)) { printf ("arg=%08x\n", arg); } } printf ("errcnt 0: %u 1: %u 2: %u 3: %u\n", cnt[0], cnt[1], cnt[2], cnt[3]); return EXIT_SUCCESS; }
On Tue, 20 Jul 2010 06:15:44 -0500, "dsp.study"
>Hi, > >I have successfully converted add, sub, mul and div operations to fixed pt >and see ~10 times improvement. > >I'm not sure how to go about doing pow and log functions...can some one >please suggest an algo or pt me to an open source code for reference. > >thanks, >Marty
Hi Marty, Clay S. Turner has written a neat article, titled "A Fast Binary Logarithm Algorithm". That article, most appropriate for fixed-point processors, will appear in the Sept. 2010 "DSP Tips & Tricks" column of the IEEE Signal Processing magazine. Good Luck, [-Rick-]
Norbert Juffa <juffa@earthlink.net> wrote:
>Below I demonstrate how this could be done for log2() in 8.24 fixed >point. Our input x is of the form 2^e*m, 1 <= m < 2, m = 1 + f. Using >a "count leading zeros" operation, we quickly establish e and f. Given >f, 0 <= f < 1, we compute the index i of the closest, smaller, table >entry in a table of values of log2(x) on [1,2). The difference between >the actual argument and the function argument corresponding to i shall >be d. Using the function value from the table, f0, as well as the next >two table entries, f1 and f2, we compute the coefficients a, b of a >parabola that fits through all three function values.
The above is a valuable technique, but times have changed and in many DSP scenarios these days one can just plug the mantissa into a (larger) LUT and be done with it. This applies to log(), square(), and similar functions. Steve
"Steve Pope" <spope33@speedymail.org> wrote in message news:i2cg29$hq6$1@blue.rahul.net...
> Norbert Juffa <juffa@earthlink.net> wrote: > >>Below I demonstrate how this could be done for log2() in 8.24 fixed >>point. Our input x is of the form 2^e*m, 1 <= m < 2, m = 1 + f. Using >>a "count leading zeros" operation, we quickly establish e and f. Given >>f, 0 <= f < 1, we compute the index i of the closest, smaller, table >>entry in a table of values of log2(x) on [1,2). The difference between >>the actual argument and the function argument corresponding to i shall >>be d. Using the function value from the table, f0, as well as the next >>two table entries, f1 and f2, we compute the coefficients a, b of a >>parabola that fits through all three function values. > > The above is a valuable technique, but times have changed and in many > DSP scenarios these days one can just plug the mantissa into > a (larger) LUT and be done with it. This applies to log(), square(), > and similar functions. > > Steve
For a table lookup method to work efficiently on most embedded processors requires a high likelihood that the table elements are present in L1 cache. Often there will be tables for division, sqrt(), exp(), log(), all of whom would want to fit into L1 at the same time, leaving room for other data as well. The L1 may be as small as 8KB or even 4KB, so keeping lookup tables small seems very much desirable. To achieve accuracy to full 8.24 precision one needs a table of 258*4 bytes (~1KB) each for both exp() and log() with quadratic interpolation. Table storage will increase significantly if linear interpolation is used, even if an economical scheme such as bipartite tables is used. Even for hardware implementations the use of quadratic interpolation may well be preferred to keep ROM sizes reasonable. I would be interested in learning in which scenarios requiring relative high accuracy (such as here) quadratic interpolation is dispensable, and linear interpolation or straight lookup are feasible. -- Norbert
On Jul 23, 2:42=A0pm, "Norbert Juffa" <ju...@earthlink.net> wrote:
> "Steve Pope" <spop...@speedymail.org> wrote in messagenews:i2cg29$hq6$1@b=
lue.rahul.net...
> > Norbert Juffa <ju...@earthlink.net> wrote: > > >>Below I demonstrate how this could be done for log2() in 8.24 fixed > >>point. Our input x is of the form 2^e*m, 1 <=3D m < 2, m =3D 1 + f. Usi=
ng
> >>a "count leading zeros" operation, we quickly establish e and f. Given > >>f, 0 <=3D f < 1, we compute the index i of the closest, smaller, table > >>entry in a table of values of log2(x) on [1,2). The difference between > >>the actual argument and the function argument corresponding to i shall > >>be d. Using the function value from the table, f0, as well as the next > >>two table entries, f1 and f2, we compute the coefficients a, b of a > >>parabola that fits through all three function values. > > > The above is a valuable technique, but times have changed and in many > > DSP scenarios these days one can just plug the mantissa into > > a (larger) LUT and be done with it. =A0This applies to log(), square(), > > and similar functions. > > > Steve > > For a table lookup method to work efficiently on most embedded processors > requires a high likelihood that the table elements are present in L1 cach=
e.
> Often there will be tables for division, sqrt(), exp(), log(), all of who=
m
> would want to fit into L1 at the same time, leaving room for other data a=
s
> well. The L1 may be as small as 8KB or even 4KB, so keeping lookup tables > small seems very much desirable. > > To achieve accuracy to full 8.24 precision one needs a table of 258*4 byt=
es
> (~1KB) each for both exp() and log() with quadratic interpolation. Table > storage will increase significantly if linear interpolation is used, even > if an economical scheme such as bipartite tables is used. Even for hardwa=
re
> implementations the use of quadratic interpolation may well be preferred =
to
> keep ROM sizes reasonable. > > I would be interested in learning in which scenarios requiring relative h=
igh
> accuracy (such as here) quadratic interpolation is dispensable, and linea=
r
> interpolation or straight lookup are feasible. > > -- Norbert- Hide quoted text - > > - Show quoted text -
Years ago I made a light meter that showed relative intensity in terms of F stops and density. Both of these are logarithmic quantities and I used a Mot 68HC05 micro and I went for the accuracy since the computation time being a microsecond or 10mSec just didn't matter! The idea was to force all of the error into the sensor and not have the processor's math add to the final error. Simplicity and tiny code was the desirable thing. My 4 arithematic floating point routines took only 512 bytes! When I added the input, output and log functions, I was still under 1k bytes! Clay
lue.rahul.net...
ng
e.
m
s
es
i had to look up "bipartite table" to get an idea about what you're talking about. would this paper: http://citeseerx.ist.psu.edu/viewdoc/download?doi=3D10.1.1.36.6368&rep=3Dr= ep1&type=3Dpdf be a good initial description of the technique? it's a little bit intriguing, it's based on the notion that the first derivative of a function changes much less in a segment of its domain than the "zeroth derivative" of the function. but i don't see quadratic interpolation in this. how is quadratic interpolation done? do you continue to divide the input word into three parts, use two tables, and have a quadratic function rather than a linear one (referring to Eq. 6 in the paper i cited above) for the least significant portion of the sum?
> Even for hardware implementations the use of quadratic > interpolation may well be preferred to keep ROM sizes reasonable.
if it's just the two tables, why stop at quadratic?
igh
r
i need more context to understand what you are seeking to answer. if it's still just two parallel table lookups (with sign-extension and addition following), there is no reason that the "a1" coefficient lookup need be a linear function of "x2" as is depicted in Eq. 6 of that paper. in fact, it need not be quadratic. furthermore, you can toss all assumptions to the wind and make some kinda MATLAB program to optimally determine *both* of the a1 and a0 tables in such a way to minimize error. BTW, for all of the fiddling around you need to do to implement this bipartite table lookup, possible sign extension, and addition in software, you might be able to perform a decent polynomial approximation for as few instruction cycles. the only reason i see LUT as superior to a, say, 4th-order or 6th-order polynomial approximation is in sheer speed when that is important and there is plenty of memory to burn. r b-j
I do not doubt the validity of the algorithms (for interpolating
down to a point where it reduces your table lookup size).
What I doubt is the significance, these days, of the vanishing
grey area between what you'd want to just do in IEEE double precision
floating point, and what you'd want to design to a target bit-width
in hardware.  The idea of an in-between, general-purpose format
is what I'm not sure is still there anymore.
Steve
On Jul 24, 1:46=A0am, spop...@speedymail.org (Steve Pope) wrote:
> I do not doubt the validity of the algorithms (for interpolating > down to a point where it reduces your table lookup size). > > What I doubt is the significance, these days, of the vanishing > grey area between what you'd want to just do in IEEE double precision > floating point, and what you'd want to design to a target bit-width > in hardware. =A0The idea of an in-between, general-purpose format > is what I'm not sure is still there anymore.
dunno what you mean by an "in-between, general-purpose format" but, Steve, even if you have IEEE doubles, but no std math lib, what would you do to get exp() and log()? how would you implement the stdlib exp() and log() or sqrt() or sin() or tan() or atan(), if you had to? isn't that of significance to some degree? or is the source code (say for the gnu std math lib) published somewhere? if so, i would like to see what order of polynomial they use and the coefficients. r b-j
