Filter and inverse filter =/ timedelay?
Started by Demus ●July 26, 2010
Hello,
This might be a silly question, but I can't figure out what implications
the phase of a transfer function has for causality.
If I pass a signal to a filter and pass the output to the inverse filter...
my intuition of causality tells me then that the output of the inverse
filter can not be the same as what enters the first filter.
And by 'can not be the same' I mean to include it's place in time. It
should have the same shape but not occur at the same time, which would then
suggest that the result is a pure time delay.
However, when I simulate this situation in simulink I get the opposite
result, the two signals have the same time coordinates as well, so I guess
my intuition is off.
(By the same token, in my opinion the phase of a causal system can't really
be said to be negative, at least not when the inputs and outputs are
non-stationary signals...)
Can someone please explain this situation to me, perhaps including how
phase relates to causality?
Thanks in advance!
On 26 Jul, 17:19, "Demus" <sodemus@n_o_s_p_a_m.hotmail.com> wrote:
> Hello, > > This might be a silly question, but I can't figure out what implications > the phase of a transfer function has for causality. > > If I pass a signal to a filter and pass the output to the inverse filter... > my intuition of causality tells me then that the output of the inverse > filter can not be the same as what enters the first filter. > And by 'can not be the same' I mean to include it's place in time. It > should have the same shape but not occur at the same time, which would then > suggest that the result is a pure time delay. > > However, when I simulate this situation in simulink I get the opposite > result, the two signals have the same time coordinates as well, so I guess > my intuition is off.
I think this has to do with the way you simulate the system. If the output of the filter is fed straight into the input of the inverse, with no delay elements in between, I wouldn't be surprised if the overall delay is negligable. Provided the inverse is well-behaved(stable & causal), numerical issues are neglegable, etc. Rune
Your intuition is good, you are just not modeling the world well enough. The four things that you are not modeling in Simulink are the fact that no real system is minimum phase, no real system has a finite order, no real system is noise free, and no real system can be known completely. No real system has finite order. There are always low-pass processes lurking in the upper frequency ranges of any system you may choose to model, and the harder you look for these low-pass processes the more you'll find. A simple R-C low-pass filter has one pole because of the capacitor, right? But it has another one because of the inductance of the resistor leads. If you look further, it has more because of the capacitance of the resistor to "the world". Look further yet and you'll find that the propagation of electromagnetic energy through (or around) the resistor and cap is limited by the speed of light. Go even deeper and you find that as the wavelength decreases, at some point the system just reflects the energy, or becomes transparent, or whatever. Mechanical systems, electromechanical systems, chemical systems, etc. -- they all have modeling limitations of some sort, which are ultimately limited by the speed of light. No real system is minimum phase, if for no other reason that because of the pure delay mentioned above. No system can be known completely, and this limits the accuracy of the model you can make. Without an exact model, your inverse filtering doesn't work -- particularly at frequencies where your gain needs to be high. So as your frequency gets high (and sometimes low), your model's accuracy breaks down, and your inverse filter doesn't work correctly. Real systems have noise. You stick a stimulus into a system, you measure the output -- but that output is corrupted by noise, and the spectrum of the noise is going to be a lot whiter than the spectral response of the system. Now you run that output through a 'perfect' inverse filter. The filter -- necessarily -- has _really high_ gain at the higher frequencies, but the noise process -- inevitably -- has substantial energy at those same high frequencies. So the output of your inverse filter is noisy. I'm not even getting into the fact that no real system is really fully linear, but you can imagine the difficulties. So try your Simulink example again, only use a much more complicated system for your 'real' system than for your 'inverted' system, and inject some white noise into the signal after the 'real' system. I think then that your intuition will be satisfied. Trying to come up with the 'best' guess at an input signal to a real system can keep an engineer like me honestly and profitably employed for years, if the system is complicated enough. Trying to come up with a workable definition for 'best' is often no small part of the effort.
> (By the same token, in my opinion the phase of a causal system can't really > be said to be negative, at least not when the inputs and outputs are > non-stationary signals...)
Negative phase slope indicates delay, which is perfectly reasonable to expect in a causal system. I think you're thinking of a positive phase slope, indicating lead. You can have lead in a real system, but only at the expense of a rising amplitude vs. frequency (think differentiation). The amplitude 'distortion' is the price you pay for the 'prediction' effect of differentiation.
> Can someone please explain this situation to me, perhaps including how > phase relates to causality?
The slope of the phase vs. frequency characteristic of a linear system transfer function indicates the effective delay of signals at that particular frequency. It can be positive, but as I mentioned, if the system is causal then the positive phase vs. frequency slope comes with a cost in the amplitude vs. frequency relationship. There's some relationship, but I can't remember the details, even if I ever learned them. I know that if a system is minimum phase then its phase response is the Hilbert transform of its magnitude, but I couldn't even tell you if that's magnitude, magnitude squared, log magnitude, etc. But if you really want to know, you should be able to at least find a book reference with an internet search. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
>I think this has to do with the way you simulate the system. >If the output of the filter is fed straight into the input >of the inverse, with no delay elements in between, I wouldn't >be surprised if the overall delay is negligable. Provided the >inverse is well-behaved(stable & causal), numerical issues are >neglegable, etc. > >Rune
Do you mean that Simulink simplifies the system when it simulates (the system is stable and min-phase) and in reality makes essentially no computations at all and just passes the signals through? Otherwise you would see a pure time-delay, right? Or why do you say that the time-delay should be negligable?
On 07/26/2010 08:50 AM, Demus wrote:
>> I think this has to do with the way you simulate the system. >> If the output of the filter is fed straight into the input >> of the inverse, with no delay elements in between, I wouldn't >> be surprised if the overall delay is negligable. Provided the >> inverse is well-behaved(stable& causal), numerical issues are >> neglegable, etc. >> >> Rune > > Do you mean that Simulink simplifies the system when it simulates (the > system is stable and min-phase) and in reality makes essentially no > computations at all and just passes the signals through? > Otherwise you would see a pure time-delay, right? Or why do you say that > the time-delay should be negligable?
No, _you_ simplify the system when you go from the real world to a mathematical description. Simulink then faithfully reproduces the behavior of your simplified (and physically unrealizable) system. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
really
>> be said to be negative, at least not when the inputs and outputs are >> non-stationary signals...) > >Negative phase slope indicates delay, which is perfectly reasonable to >expect in a causal system. I think you're thinking of a positive phase >slope, indicating lead. You can have lead in a real system, but only at >the expense of a rising amplitude vs. frequency (think differentiation). > The amplitude 'distortion' is the price you pay for the 'prediction' >effect of differentiation. >
Oh yeah, you're right... I had positive phases in mind. And yeah, of course that makes sense. Ok, but I'm not sure I understand this completely, even if dealing only with ideal linear systems (and stable, minphase) and uncorrupted signals. The answer is no, there shouldn't (ideally) be a pure time-delay in the above mentioned setup?
>> Can someone please explain this situation to me, perhaps including how >> phase relates to causality? > >The slope of the phase vs. frequency characteristic of a linear system >transfer function indicates the effective delay of signals at that >particular frequency. It can be positive, but as I mentioned, if the >system is causal then the positive phase vs. frequency slope comes with >a cost in the amplitude vs. frequency relationship.
So what does this mean in the time domain (still ideally - perfect linearity, no noise)?
> >There's some relationship, but I can't remember the details, even if I >ever learned them. I know that if a system is minimum phase then its >phase response is the Hilbert transform of its magnitude, but I couldn't >even tell you if that's magnitude, magnitude squared, log magnitude, >etc. But if you really want to know, you should be able to at least >find a book reference with an internet search.
Isn't this Bode's Integral Theorem? I brought this up a couple of months ago? I can verify (by the way) that the discrete time version is explicitly stated in the first edition of Oppenheims' Digital Signal Processing. Also, sorry, I posted my previous post before I saw your post. Thanks!
I think I understand the situation better now... I guess I tricked myself
before.
Thanks for the explanation!
On 07/26/2010 09:17 AM, Demus wrote:
>>> (By the same token, in my opinion the phase of a causal system can't > really >>> be said to be negative, at least not when the inputs and outputs are >>> non-stationary signals...) >> >> Negative phase slope indicates delay, which is perfectly reasonable to >> expect in a causal system. I think you're thinking of a positive phase >> slope, indicating lead. You can have lead in a real system, but only at >> the expense of a rising amplitude vs. frequency (think differentiation). >> The amplitude 'distortion' is the price you pay for the 'prediction' >> effect of differentiation. >> > > Oh yeah, you're right... I had positive phases in mind. And yeah, of course > that makes sense. > > Ok, but I'm not sure I understand this completely, even if dealing only > with ideal linear systems (and stable, minphase) and uncorrupted signals. > The answer is no, there shouldn't (ideally) be a pure time-delay in the > above mentioned setup?
Correct. In fact, for a linear, time-invariant, minimum-phase (no zeros on the imaginary axis), purely stable system (no poles on the imaginary axis) with a finite number of states, you can always find an inverse, and the cascade of the system with its inverse will always have a transfer function of one. This should contradict your intuition, before you even get to Simulink.
>>> Can someone please explain this situation to me, perhaps including how >>> phase relates to causality? >> >> The slope of the phase vs. frequency characteristic of a linear system >> transfer function indicates the effective delay of signals at that >> particular frequency. It can be positive, but as I mentioned, if the >> system is causal then the positive phase vs. frequency slope comes with >> a cost in the amplitude vs. frequency relationship. > > So what does this mean in the time domain (still ideally - perfect > linearity, no noise)?
That you can't make a predictor that's not both inaccurate and noisy.
>> There's some relationship, but I can't remember the details, even if I >> ever learned them. I know that if a system is minimum phase then its >> phase response is the Hilbert transform of its magnitude, but I couldn't >> even tell you if that's magnitude, magnitude squared, log magnitude, >> etc. But if you really want to know, you should be able to at least >> find a book reference with an internet search. > > Isn't this Bode's Integral Theorem?
No -- Bode's Integral Theorem is probably similar, but it has to do with the sensitivity of a control system to disturbances and what you can do with it. Although perhaps its a corollary -- or perhaps the one I'm familiar with is the corollary.
> I brought this up a couple of months > ago? I can verify (by the way) that the discrete time version is explicitly > stated in the first edition of Oppenheims' Digital Signal Processing.
Oppenheim & Schafer? Copyright 1975? I can't find a reference to it in the index or table of contents -- do you have a page number, or do I gave the wrong book?
No problem -- it's just a race condition. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
H(z) x 1/H(z) === 1
This is scientific fact (except for the special case H(z) === 0).
Neither H(z) nor 1/H(z) have to be casual.
Neither H(z) nor 1/H(z) have to be stable.
Neither H(z) nor 1/H(z) have to be minimum phase.
Intuition may be good at gambling.
"Matlab does all thinking for us" (TM)
> (By the same token, in my opinion the phase of a causal system can't really > be said to be negative, at least not when the inputs and outputs are > non-stationary signals...) > > Can someone please explain this situation to me, perhaps including how > phase relates to causality?
There is no such relation. VLV
>No -- Bode's Integral Theorem is probably similar, but it has to do with >the sensitivity of a control system to disturbances and what you can do >with it. Although perhaps its a corollary -- or perhaps the one I'm >familiar with is the corollary.
Yeah, the waterbed effect for "2-pole-excess" systems, right? They might have the same name sometimes but I know that one at least as Bode's Sensitivity Integral.
>> I brought this up a couple of months >> ago? I can verify (by the way) that the discrete time version is
explicitly
>> stated in the first edition of Oppenheims' Digital Signal Processing. > >Oppenheim & Schafer? Copyright 1975? I can't find a reference to it in >the index or table of contents -- do you have a page number, or do I >gave the wrong book?
I don't have the book, I borrowed it from the library last time (and then I only found it in the first edition, not the second edition). I might be way off here but I'm pretty sure it was either theorem 5.21 or 7.21. Can't remember. Again, thanks for your replies. You've always been very helpful.
