an audio question about impedance matching
Started by robert bristow-johnson July 29, 2010
i know it's not DSP, but i thought people on the list would have some
experience, opinions, and knowledge.
whether it's a microphone going into a preamp or mix board, or an
electric guitar going into a guitar amp, how does impedance matching
(or mismatching) affect *tone*?
the way i see it (as an EE) is:
1. that if one of either the source or load impedance has reactive
components and the other is resistive, changing the resistance will
change the simple RC filter and the corner frequency of it, thus
changing the tone.
2. if both source and load impedance are mostly resistive, changing
one or the other will only change the level, not the waveshape.  if
the input to the pre-amp or amp has some nonlinearity, a louder level
will push that stage into the nonlinear region which will change the
waveshape and affect the timbre.
other than that, i do not understand the why "impedance matching" is
considered so important in audio.  it's not like we need to maximize
power transfer (in micro watts) from the transducer or pickup into the
input of the amplifier.  and, at audio frequencies (and the length of
cables), reflections along the transmission lines (due to impedance
mismatch) should not be an issue either.
why can't a low-impedance source simply connected to a high-impedance
load suffice?  why are matching transformers needed (unless level is
important)?
r b-j                  rbj@audioimagination.com
"Imagination is more important than knowledge."
robert bristow-johnson  <rbj@audioimagination.com> wrote:
>why can't a low-impedance source simply connected to a high-impedance >load suffice? why are matching transformers needed (unless level is >important)?
Many audio connections are in fact a low-impedance source connected to a high impedance load. Using transformers on some connections is thought to prevent ground loops. Matched connections (e.g. a 600 ohm load), when they are used, are thought to prevent hum on long lines. I'm not sure how scientific either of these beliefs are. Steve
> i know it's not DSP, but i thought people on the list would have some > experience, opinions, and knowledge.
> whether it's a microphone going into a preamp or mix board, or an > electric guitar going into a guitar amp, how does impedance matching > (or mismatching) affect *tone*?
As far as I know, the usual case is that a high impedance microphone should not have too long of a cable. The cable capacitance and the microphone impedance make a low pass filter, which will reduce the high frequencies. Pros use low impedance so that they can use long cables without a significant effect on the high frequencies. Otherwise, the mismatch will mean a smaller signal, more amplification, and more noise. -- glen
On Thu, 29 Jul 2010 10:20:18 -0700 (PDT), robert bristow-johnson
>whether it's a microphone going into a preamp or mix board, or an >electric guitar going into a guitar amp, how does impedance matching >(or mismatching) affect *tone*? > >the way i see it (as an EE) is: > >1. that if one of either the source or load impedance has reactive >components and the other is resistive, changing the resistance will >change the simple RC filter and the corner frequency of it, thus >changing the tone.
This is probably the most significant source of tonal change -- simple passive filter concepts applied to the frequency response of the components.
>2. if both source and load impedance are mostly resistive, changing >one or the other will only change the level, not the waveshape. if >the input to the pre-amp or amp has some nonlinearity, a louder level >will push that stage into the nonlinear region which will change the >waveshape and affect the timbre.
A secondary effect, at most. My response to customers complaining about how bad equipment sounds when pushed into nonlinearity is, "Don't do that."
>other than that, i do not understand the why "impedance matching" is >considered so important in audio. it's not like we need to maximize >power transfer (in micro watts) from the transducer or pickup into the >input of the amplifier.
That depends. For microphones and phonograph cartridges this can be very important. Also don't forget that mechanical transducers form resonant systems, so the impedance relationships affect not only bandwidth, but Q.
>and, at audio frequencies (and the length of >cables), reflections along the transmission lines (due to impedance >mismatch) should not be an issue either.
Exactly. The wavelengths are so large compared to the length of the conductor that transmission line effects don't even come into play.
Generally they can.
Do you mean something like a 600 Ohm system? Generally it's for level matching. I think it's pretty much a holdover from the vacuum tube days, where high output impedances were common. Greg
On Jul 29, 1:30&#4294967295;pm, spop...@speedymail.org (Steve Pope) wrote:
> robert bristow-johnson &#4294967295;<r...@audioimagination.com> wrote: > > >why can't a low-impedance source simply connected to a high-impedance > >load suffice? &#4294967295;why are matching transformers needed (unless level is > >important)? > > Many audio connections are in fact a low-impedance source connected > to a high impedance load.
i know. i'm having a discussion with someone who designs custom pickups and he has a version that transformer couples the output to the guitar amp. it's a step-up which increases the voltage (and decreases current) by the turns ratio factor and also the apparent source impedance (by the square of the turns ratio). now my thinking is that this is a levels issue (the louder level in the guitar amp makes for a hotter sounding pickup), but he insists that the reason is impedance matching and that results in a "better tone".
> Using transformers on some connections is thought to prevent ground loops. > Matched connections (e.g. a 600 ohm load), when they are used, are > thought to prevent hum on long lines. &#4294967295;I'm not sure how scientific > either of these beliefs are. &#4294967295;
i dunno if the matched connection is responsible for suppressing hum, or if it's the natural differential input that a transformer primary winding is. you get a damn good common-mode rejection ratio (CMRR) with a transformer floating around in all this low-frequency slew of E&M radiation. r b-j
On Jul 29, 1:41&#4294967295;pm, Greg Berchin <gberc...@comicast.net.invalid>
wrote:
> On Thu, 29 Jul 2010 10:20:18 -0700 (PDT), robert bristow-johnson > > <r...@audioimagination.com> wrote: > >whether it's a microphone going into a preamp or mix board, or an > >electric guitar going into a guitar amp, how does impedance matching > >(or mismatching) affect *tone*? > > >the way i see it (as an EE) is: > > >1. that if one of either the source or load impedance has reactive > >components and the other is resistive, changing the resistance will > >change the simple RC filter and the corner frequency of it, thus > >changing the tone. > > This is probably the most significant source of tonal change -- simple passive > filter concepts applied to the frequency response of the components. > > >2. if both source and load impedance are mostly resistive, changing > >one or the other will only change the level, not the waveshape. &#4294967295;if > >the input to the pre-amp or amp has some nonlinearity, a louder level > >will push that stage into the nonlinear region which will change the > >waveshape and affect the timbre. > > A secondary effect, at most. &#4294967295;My response to customers complaining about how bad > equipment sounds when pushed into nonlinearity is, "Don't do that."
or, if it's a Mesa Boogie amp or Marshall stack or a Fender Twin- Reverb, it might be more like "Do do that! more! harder! harder!" one person's abuse (like S&M sex) is another person's "kinky".
> > >other than that, i do not understand the why "impedance matching" is > >considered so important in audio. &#4294967295;it's not like we need to maximize > >power transfer (in micro watts) from the transducer or pickup into the > >input of the amplifier. &#4294967295; > > That depends.
on what? whether we have the capability of amplifying signals or not?
> For microphones and phonograph cartridges this can be very > important. &#4294967295;Also don't forget that mechanical transducers form resonant systems, > so the impedance relationships affect not only bandwidth, but Q. > > >and, at audio frequencies (and the length of > >cables), reflections along the transmission lines (due to impedance > >mismatch) should not be an issue either. > > Exactly. &#4294967295;The wavelengths are so large compared to the length of the conductor > that transmission line effects don't even come into play. > > >why can't a low-impedance source simply connected to a high-impedance > >load suffice? &#4294967295; > > Generally they can. > > >why are matching transformers needed (unless level is > >important)? > > Do you mean something like a 600 Ohm system? &#4294967295;Generally it's for level matching. > I think it's pretty much a holdover from the vacuum tube days, where high output > impedances were common.
i'm thinking a custom guitar pickup (with lower source impedance) going into a guitar amp. r b-j
>>why can't a low-impedance source simply connected to a high-impedance >>load suffice? why are matching transformers needed (unless level is >>important)?
It is usual that the microphone impedance is lower than the input impedance, such that the microphone isn't loaded down. A high impedance microphone with built-in amplifier might be about 1K ohms, and work well with a 10k ohm load. Low impedance, according to wikipedia, is between 50 and 200 ohms, well matched for the shielded twisted pair cable usually used.
> Using transformers on some connections is thought to prevent ground loops. > Matched connections (e.g. a 600 ohm load), when they are used, are > thought to prevent hum on long lines. I'm not sure how scientific > either of these beliefs are.
Well, not only prevent ground loops but remove any common-mode signals picked up along the way. The shield helps, but doesn't do much for low frequency magnetic (inductive) coupling. Note that transformers are also used on both ends of UTP ethernet to remove the common mode signals. -- glen
>Steve Pope <spope33@speedymail.org> wrote: >Note that transformers are also used on both ends of UTP >ethernet to remove the common mode signals.
They do that, but their primary purpose is electrical isolation for safety. They aren't tested at 4kV for their common mode rejection qualities. :-) Steve
On Thu, 29 Jul 2010 10:53:36 -0700 (PDT), robert bristow-johnson
>> >other than that, i do not understand the why "impedance matching" is >> >considered so important in audio. &#4294967295;it's not like we need to maximize >> >power transfer (in micro watts) from the transducer or pickup into the >> >input of the amplifier. &#4294967295; >> >> That depends. > >on what? whether we have the capability of amplifying signals or not?
Or upon how much we need to amplify the signal. For a microphone or phono cartridge or guitar pickup, we want to provide as much signal amplitude as possible to the gain stages because they amplify the noise (including thermal noise, with such low-output devices) as much as they amplify the signal, and then they add noise of their own.
>i'm thinking a custom guitar pickup (with lower source impedance) >going into a guitar amp.
With musical instruments, often it is not what makes sense that counts, but what sounds good. "Good" is in the ear of the beholder. If a transformer makes it sound good, who are we to argue? Greg
>i know it's not DSP, but i thought people on the list would have some >experience, opinions, and knowledge. > >whether it's a microphone going into a preamp or mix board, or an >electric guitar going into a guitar amp, how does impedance matching >(or mismatching) affect *tone*? > >the way i see it (as an EE) is: > >1. that if one of either the source or load impedance has reactive >components and the other is resistive, changing the resistance will >change the simple RC filter and the corner frequency of it, thus >changing the tone. > >2. if both source and load impedance are mostly resistive, changing >one or the other will only change the level, not the waveshape. if >the input to the pre-amp or amp has some nonlinearity, a louder level >will push that stage into the nonlinear region which will change the >waveshape and affect the timbre. > >other than that, i do not understand the why "impedance matching" is >considered so important in audio. it's not like we need to maximize >power transfer (in micro watts) from the transducer or pickup into the >input of the amplifier. and, at audio frequencies (and the length of >cables), reflections along the transmission lines (due to impedance >mismatch) should not be an issue either. > >why can't a low-impedance source simply connected to a high-impedance >load suffice? why are matching transformers needed (unless level is >important)? > >-- > >r b-j rbj@audioimagination.com > >"Imagination is more important than knowledge."
As others have said, a huge number of audio connections are a pretty low impedance feeding a pretty high one, and RC filtering is the main thing you need to worry about in most cases. However, there are a few places were impedance really matters. A top quality mic and mic amp can get an amazing noise floor, but you'd better have the impedances achieving maximum power transfer if you don't want to spoil things. Most mics, LP cartidges and other electromechnical input devices have resonance issues, unless they are properly loaded. Most output devices - speakers and headphones - are best driven from a super low impedance, so the amp damps their bass resonances. This is why putting the amp as close as possible to a speaker, or even inside the cabinet, makes so much sense. A lot more sense than trying to minimise impedance with crazy thick wires from a distant amp. Steve
