Hello All This may not be the right place for CCS question. But I know I could find an answer here ! :o) Does anyone know how to modify the assembler command line in CCS ? -(not only the options)- I would like to supply the "object files" in the command line. Or in another way : How to include a (batch?) file invoking the assembler (asm500) with the correct arguments in my project ?. I try to play with GEL Files. But I did not succeed. Thank you.
[CCS] assembler command line
Started by ●February 17, 2004
Reply by ●February 18, 20042004-02-18
Hello, you may click 'Project-Build Options-Compiler' to see cmd line for asm500. It may be to correct as by ComboBoxes (and others), as direct.> Does anyone know how to modify the assembler command line in CCS > ? -(not only the options)- > I would like to supply the "object files" in the command line.I can't clear understand that is bad in standart way: you only point to files(.asm,.c,.cmd,.obj...) which must be included in project(executable file), all another do CCS.> How to include a (batch?) file invoking the assembler (asm500) with > the correct arguments in my project ?.Cheers
"Vic" <h3vic@yahoo.com> a �crit dans le message de news: </> Hello I use conditional assembly and would like to name the objects file differently. let me give you an example : mycode.asm: ---------------- .if Version1 .. .endif .if Version2 .. .endif --------------- Now I would like assemble the sourcefile with the following command asm500 mycode.asm mycodeV1.obj (specifics option) -dVersion1 -dVersion2=0 or asm500 mycode.asm mycodeV2.obj (specifics option) -dVersion1=0 - dVersion2 I'm using two projects (V1 and V2) with specific command line assembly. For the linker there is now problem since I can use a different cmd file. One solution would be to use a separate .bat file. But I would like to perform this in CCS environnment. Thanks
