Hi, I'm making a CCSDS reed-solomon decoder. I'm using the C code as written by Simon Rockliff (1991) as a starting point. The main feature of the CCSDS specification is that it uses alpha^11 as primitive element and generator polynomial roots are : alpha^(128-E) to alpha^(127+E), which makes the problem unusual. In the above C code, by changing the generator polynomial and using the roots of gen polynomial to calculate syndromes, and by evaluating the error locator polynomial at powers of (alpha^11) rather than alpha(as usually is the case), Im able to correctly decode the error locations. Now, can you provide any help regarding how to find error value? Please suggest any modifications in error evaluation step of the decoding algorithm, in the light of the unique features of the CCSDS specification.
CCSDS Reed-solomon decoding- error evaluation
Started by ●August 6, 2010
