Hi, I put an old IIR filter design script here: https://drive.google.com/file/d/0B1gLUU8hXL7vN0ZQZHFjUlo3VG8/edit?usp=sharing I make no promises on this algorithm... The intention is to design a minimum-phase (=>low group delay) filter for a given magnitude response. As it doesn't know the phase, it designs for some starting value, then takes the phase of the result as input to the least-squares solver and tries again several times. You can control the result by - specifying the frequency response you want (i.e. "1" for passband, "0" for stopband - setting a weight for different regions, trading passband ripple against stopband rejection. Leaving "don't-care" regions with "0" weight will improve performance in other areas. You could also have a look here: http://www.dsprelated.com/showcode/20.php Slightly different approach - it creates the phase from the amplitude spectrum via Hilbert transform. _____________________________ Posted through www.DSPRelated.com
Is 'Bessel' digital lowpass filter standard?
Started by ●August 24, 2010
Reply by ●July 11, 20142014-07-11
.. but if I use an elliptic (Cauer) or Chebyshev filter, it won't be that much different from the above, and I get it with standard design methods. These filters have significant group delay ripple (clearly asymmetric impulse response) but are fast overall (the IR "kicks in" rather quickly). I understood that is the requirement, otherwise this would be a little out of place under the "Bessel" title... _____________________________ Posted through www.DSPRelated.com
Reply by ●August 13, 20142014-08-13
>.. but if I use an elliptic (Cauer) or Chebyshev filter, it won't be that >much different from the above, and I get it with standard design methods. > >These filters have significant group delay ripple (clearly asymmetric >impulse response) but are fast overall (the IR "kicks in" ratherquickly).>I understood that is the requirement, otherwise this would be a littleout>of place under the "Bessel" title... > >_____________________________ >Posted through www.DSPRelated.com >mnentwig, thanks for your assistance here. I haven't looked through your script yet as I had parked this for a while, but will definitely have a look through it as soon as this issue comes back to bite me in the ass in the not so distant future! _____________________________ Posted through www.DSPRelated.com
Reply by ●March 5, 20182018-03-05
> I'm just wondering why I had such a hard time to find reference to a Bessel > filter in the digital domain.Google for Thiran-Filter instead. See: Jean-Pierre Thiran: Recursive Digital Filters with Maximally Flat Group Delay. IEEE Transactions On Circuit Theory, Vol. CT-18, No. 6, November 1971.
On 5.3.18 14:49, tobiaszawada@gmail.com wrote:> >> I'm just wondering why I had such a hard time to find reference to a Bessel >> filter in the digital domain. > > Google for Thiran-Filter instead. > > See: Jean-Pierre Thiran: Recursive Digital Filters with Maximally Flat Group Delay. IEEE Transactions On Circuit Theory, Vol. CT-18, No. 6, November 1971.You do not usually need them. A Bessel filter is an approximation to a constant-delay filter, but in the digital domain, it is possible to construct FIR (finite impulse response) filters with constant delay. (For completeness, it is possible to contruct a FIR filter in the analog domain, if suitable delay elements are available). -- -TV
