Hello I have developed a 50 Hz low pass filter. Now I would understand if work good.... So please can you download and test it? This is the link: http://dl.dropbox.com/u/1992699/50%20Hz%20Low%20Pass%20Filter.zip Note that you could add more than one waveform. 10 Hz --> Generate base waveform 100 Hz --> Add Noise For measure Gain change waveform to 1 volt and filter.... Thanks
Can you download and test my low pass filter?
Started by ●August 27, 2010
Reply by ●August 27, 20102010-08-27
On Aug 27, 5:08�am, "gpezzella" <gpezzella@n_o_s_p_a_m.yahoo.com> wrote:> Hello > > I have developed a 50 Hz low pass filter. > > Now I would understand if work good.... > > So please can you download and test it? > > This is the link: > > http://dl.dropbox.com/u/1992699/50%20Hz%20Low%20Pass%20Filter.zip > > Note that you could add more than one waveform. > > 10 Hz --> Generate base waveform > 100 Hz --> Add Noise > > For measure Gain change waveform to 1 volt and filter.... > > ThanksI could, but why would I want to? Is there something special about this particular lowpass filter?
On 08/27/2010 02:08 AM, gpezzella wrote:> Hello > > I have developed a 50 Hz low pass filter. > > Now I would understand if work good.... > > So please can you download and test it?Not unless you pay me. Why? First, because I have to draw the line _somewhere_ between giving out free samples of my work on USENET vs. actually making money, and second, because it's tedious, always takes more time than one thinks it will, and does little to advance the state of human understanding. But if you'll start a thread outlining what you're doing to test it, and your results, I'll review your procedure and give you suggestions. Not only will that take far less of my time, but I'll be teaching you how to fish instead of giving you fish.> This is the link: > > http://dl.dropbox.com/u/1992699/50%20Hz%20Low%20Pass%20Filter.zip > > Note that you could add more than one waveform. > > 10 Hz --> Generate base waveform > 100 Hz --> Add Noise > > For measure Gain change waveform to 1 volt and filter.... > > Thanks > >-- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On Fri, 27 Aug 2010 04:08:54 -0500, "gpezzella" <gpezzella@n_o_s_p_a_m.yahoo.com> wrote:>Hello > >I have developed a 50 Hz low pass filter. > >Now I would understand if work good.... > >So please can you download and test it? > >This is the link: > >http://dl.dropbox.com/u/1992699/50%20Hz%20Low%20Pass%20Filter.zip > >Note that you could add more than one waveform. > >10 Hz --> Generate base waveform >100 Hz --> Add Noise > >For measure Gain change waveform to 1 volt and filter.... > >ThanksIt's risky to download and open a zip file from a stranger. I doubt you'll get many takers on this. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
eric.jacobsen@ieee.org (Eric Jacobsen) writes:> [...] > It's risky to download and open a zip file from a stranger.Why? It may be risky, e.g., to open an MSWord or Excel document that's inside a zip file, but I don't see any risk in the act of simply opening the zip file. -- Randy Yates % "...the answer lies within your soul Digital Signal Labs % 'cause no one knows which side mailto://yates@ieee.org % the coin will fall." http://www.digitalsignallabs.com % 'Big Wheels', *Out of the Blue*, ELO
Reply by ●August 28, 20102010-08-28
Thanks Jacobsen! The ligth win always on the dark!>eric.jacobsen@ieee.org (Eric Jacobsen) writes: >> [...] >> It's risky to download and open a zip file from a stranger. > >Why? It may be risky, e.g., to open an MSWord or Excel document that's >inside a zip file, but I don't see any risk in the act of simply opening >the zip file. >-- >Randy Yates % "...the answer lies within your soul >Digital Signal Labs % 'cause no one knows which side >mailto://yates@ieee.org % the coin will fall." >http://www.digitalsignallabs.com % 'Big Wheels', *Out of the Blue*, ELO >
Reply by ●August 29, 20102010-08-29
Hello curagious man need...>Thanks Jacobsen! >The ligth win always on the dark! > > >>eric.jacobsen@ieee.org (Eric Jacobsen) writes: >>> [...] >>> It's risky to download and open a zip file from a stranger. >> >>Why? It may be risky, e.g., to open an MSWord or Excel document that's >>inside a zip file, but I don't see any risk in the act of simply opening >>the zip file. >>-- >>Randy Yates % "...the answer lies within your soul >>Digital Signal Labs % 'cause no one knows which side >>mailto://yates@ieee.org % the coin willfall.">>http://www.digitalsignallabs.com % 'Big Wheels', *Out of the Blue*, ELO >> >
Reply by ●September 5, 20102010-09-05
On Fri, 27 Aug 2010 17:37:54 GMT, eric.jacobsen@ieee.org (Eric Jacobsen) wrote:>On Fri, 27 Aug 2010 04:08:54 -0500, "gpezzella" ><gpezzella@n_o_s_p_a_m.yahoo.com> wrote: > >>Hello >> >>I have developed a 50 Hz low pass filter. >> >>Now I would understand if work good.... >> >>So please can you download and test it? >> >>This is the link: >> >>http://dl.dropbox.com/u/1992699/50%20Hz%20Low%20Pass%20Filter.zip >> >>Note that you could add more than one waveform. >> >>10 Hz --> Generate base waveform >>100 Hz --> Add Noise >> >>For measure Gain change waveform to 1 volt and filter.... >> >>Thanks > >It's risky to download and open a zip file from a stranger. I doubt >you'll get many takers on this. > >Eric JacobsenHi Eric, I agree with you. In gpezzella's ZIP file is a ".exe" file. There's no darned way I'm gonna run that ".exe" file. See Ya', [-Rick-]
Reply by ●September 8, 20102010-09-08
Hi Eric have you registered the ocx? Please read instruction>On Fri, 27 Aug 2010 17:37:54 GMT, eric.jacobsen@ieee.org (Eric >Jacobsen) wrote: > >>On Fri, 27 Aug 2010 04:08:54 -0500, "gpezzella" >><gpezzella@n_o_s_p_a_m.yahoo.com> wrote: >> >>>Hello >>> >>>I have developed a 50 Hz low pass filter. >>> >>>Now I would understand if work good.... >>> >>>So please can you download and test it? >>> >>>This is the link: >>> >>>http://dl.dropbox.com/u/1992699/50%20Hz%20Low%20Pass%20Filter.zip >>> >>>Note that you could add more than one waveform. >>> >>>10 Hz --> Generate base waveform >>>100 Hz --> Add Noise >>> >>>For measure Gain change waveform to 1 volt and filter.... >>> >>>Thanks >> >>It's risky to download and open a zip file from a stranger. I doubt >>you'll get many takers on this. >> >>Eric Jacobsen > >Hi Eric, > I agree with you. >In gpezzella's ZIP file is a ".exe" file. >There's no darned way I'm gonna run that >".exe" file. > >See Ya', >[-Rick-] >
Why on earth would you think that people who are intelligent enough not to go around running strange .exe files are dumb enough to go in and register a strange .ocx? Bluntly, I will be shocked if you can manage to find anyone who is willing to run your executable code just for the sake of helping you with your ill-defined problem. And the more you insist that the only thing that will help is for people to do so the more the inescapable conclusion arises that you're yet another virus writer who thinks he's more clever than he is. On 9/8/2010 2:44 AM, gpezzella wrote:> Hi Eric > > have you registered the ocx? > > Please read instruction > >> On Fri, 27 Aug 2010 17:37:54 GMT, eric.jacobsen@ieee.org (Eric >> Jacobsen) wrote: >> >>> On Fri, 27 Aug 2010 04:08:54 -0500, "gpezzella" >>> <gpezzella@n_o_s_p_a_m.yahoo.com> wrote: >>> >>>> Hello >>>> >>>> I have developed a 50 Hz low pass filter. >>>> >>>> Now I would understand if work good.... >>>> >>>> So please can you download and test it? >>>> >>>> This is the link: >>>> >>>> http://dl.dropbox.com/u/1992699/50%20Hz%20Low%20Pass%20Filter.zip >>>> >>>> Note that you could add more than one waveform. >>>> >>>> 10 Hz --> Generate base waveform >>>> 100 Hz --> Add Noise >>>> >>>> For measure Gain change waveform to 1 volt and filter.... >>>> >>>> Thanks >>> >>> It's risky to download and open a zip file from a stranger. I doubt >>> you'll get many takers on this. >>> >>> Eric Jacobsen >> >> Hi Eric, >> I agree with you. >> In gpezzella's ZIP file is a ".exe" file. >> There's no darned way I'm gonna run that >> ".exe" file. >> >> See Ya', >> [-Rick-] >>-- Rob Gaddi, Highland Technology Email address is currently out of order
