IIR filter gain - where to do it?
Started by gretzteam ●August 30, 2010
Hi,
I have the current 3rd order IIR filter:
gain = 1789.111562
b = [1 3 3 1];
a = [1 -1.6009450356 0.9414772490 -0.1971027115];
I'm trying to implement this in fixed-point format, using DF1. I don't
think I need to convert to Second-Order-Section as this is not an
aggressive filter.
The first step was to quantize the coefficients, and I get get by with 12
bits.
Now I don't know what to do with this gain. If I do it at the input, I need
to add ~11 LSB to keep decent SNR. If I do it at the output, well I need to
add ~11 MSB or everything starts clipping within the filter.
Is there a good way to handle such a case or I basically just need the
bits?
Dave
On Aug 30, 10:11&#4294967295;am, "gretzteam" <gretzteam@n_o_s_p_a_m.yahoo.com>
wrote:
> Hi, > I have the current 3rd order IIR filter: > > gain = 1789.111562 > b = [1 3 3 1]; > a = [1 -1.6009450356 0.9414772490 -0.1971027115]; > > I'm trying to implement this in fixed-point format, using DF1. I don't > think I need to convert to Second-Order-Section as this is not an > aggressive filter. > > The first step was to quantize the coefficients, and I get get by with 12 > bits. > > Now I don't know what to do with this gain. If I do it at the input, I need > to add ~11 LSB to keep decent SNR. If I do it at the output, well I need to > add ~11 MSB or everything starts clipping within the filter.
don't you mean the other way around? tossing in a gain of 1789 at the input would cause the signal to be bigger inside the filter can potentially clip. tossing in the gain at the output will amplify the roundoff noise along with the signal. my suggestion is to toss it into the input and for a DF1, that would mean scaling those feedforward coefficients. maintain a double-wide accumulator and for fixed point, that affects how much right shifting you do with the accumulator result when casting that into the output states y[n-1], y[n-2], etc. r b-j
What is your hardware? Here is a biquad for a 8 bit 68HC08 controller: http://www.embeddedFORTH.de/temp/biquad.pdf ( text is in german but pictures should be clear enough ). The biquad is based on the version with one big accumulator picture 1 / Bild 1. Several 8x8->16 bit unsigned multipy-opcode of the 68HC908 are used in a basic subroutine for 16x16->32 bit unsigned multiply. The next level is the "MAC"-subroutine shown in picture 8 / Bild 8. Note there is an additional 32 bit ASL-shift controlled by a flag. Needed to patch coefficients from gain<1,0 to to gain<2,0. The flag bits for that are stored in flash in the unused coefficient a0 that is always assumed gain=1,0 The other coefficients (b0 b1 b2 a1 a2 ) in flash are 16 bit signed magnitude because that was slightly faster then 2er-complement. Coefficients & I/O data are scaled to 1,0 = 32767 signed. But inside the biquad ( picture 6 Bild 6 ) the length goes up to 32 bit and then 40 bit for the accumulator. At the output there is saturation logic to limit to 32 bit and then by reordering the word a scale back ( division ) to 16 bit. The biquad should be simple to extend to the 3pole structure. Any 16 bit controller is preferable in that application to a 8 bit controller. And i doubt a 8 bit controller without a 8x8->16 bit unsigned multipy opcode is much use.
Shift the data for the input up to 16 bit but avoid overflow. For 16 bit wordlength the filter usually has no gain. Hardly wide enough to keep noise, limit cycles down. Don?t waste too much time on matlab. A real implementation tested with real data will show the real problems. MfG JRD
On 08/30/2010 07:11 AM, gretzteam wrote:
> Hi, > I have the current 3rd order IIR filter: > > gain = 1789.111562 > b = [1 3 3 1]; > a = [1 -1.6009450356 0.9414772490 -0.1971027115]; > > I'm trying to implement this in fixed-point format, using DF1. I don't > think I need to convert to Second-Order-Section as this is not an > aggressive filter. > > The first step was to quantize the coefficients, and I get get by with 12 > bits. > > Now I don't know what to do with this gain. If I do it at the input, I need > to add ~11 LSB to keep decent SNR. If I do it at the output, well I need to > add ~11 MSB or everything starts clipping within the filter. > > Is there a good way to handle such a case or I basically just need the > bits?
Converting to a first- and a second-order section in cascade should relieve the need for so much gain all in one place, even if it doesn't buy you much in the necessary coefficient precision. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
"gretzteam" <gretzteam@n_o_s_p_a_m.yahoo.com> writes:
> Hi, > I have the current 3rd order IIR filter: > > gain = 1789.111562 > b = [1 3 3 1]; > a = [1 -1.6009450356 0.9414772490 -0.1971027115]; > > I'm trying to implement this in fixed-point format, using DF1. I don't > think I need to convert to Second-Order-Section as this is not an > aggressive filter. > > The first step was to quantize the coefficients, and I get get by with 12 > bits. > > Now I don't know what to do with this gain. If I do it at the input, I need > to add ~11 LSB to keep decent SNR. If I do it at the output, well I need to > add ~11 MSB or everything starts clipping within the filter. > > Is there a good way to handle such a case or I basically just need the > bits? > > Dave
Dave, Consider your input signal [-1, +1). If your filter's maximum passband gain is 1, then the maximum output is one. That means you would be scaled Q0.15 on the output for a 16-bit output (e.g.). Now, you can get a gain of 2^M for free! Simply shift the binary point to the right M places, M <= 15. Note that the actual integer output values remain unchanged - it's just a change in the interpretation of the output (namely, in the position of the imaginary binary point). You will neither lose precision nor chance overflow (or saturation). -- Randy Yates % "Watching all the days go by... Digital Signal Labs % Who are you and who am I?" mailto://yates@ieee.org % 'Mission (A World Record)', http://www.digitalsignallabs.com % *A New World Record*, ELO
>>Dave, > >Consider your input signal [-1, +1). If your filter's maximum passband >gain is 1, then the maximum output is one. That means you would be >scaled Q0.15 on the output for a 16-bit output (e.g.). > >Now, you can get a gain of 2^M for free! Simply shift the binary point >to the right M places, M <= 15. Note that the actual integer output >values remain unchanged - it's just a change in the interpretation of >the output (namely, in the position of the imaginary binary point). You >will neither lose precision nor chance overflow (or saturation).
Hi, I think I expressed myself incorrectly when talking about gain. This 3rd order filter: b = [1 3 3 1]; a = [1 -1.6009450356 0.9414772490 -0.1971027115]; has a gain of 1789.111562. The input to the filter is [-1:1). Now of course I want to have 0dB gain in the passband, so I need to scale everything by 1/1789.11562 at some point. Doing it on the input requires about 11 extra LSBs to keep SNR fine. Doing it on the output requires 11 extra MSBs so that the filter can handle numbers up to 1789... I'm doing this in an FPGA so I have control of the wordlength at all nodes. The 'FIR' part is trivial and requires no multiply at all. Then I was thinking to do the scaling multiply before going in the IIR part - making everything 11bits wider before we even start. I just feel like this inherent gain is costing me so much! Am I missing something? Dave
>>>Dave, >> >>Consider your input signal [-1, +1). If your filter's maximum passband >>gain is 1, then the maximum output is one. That means you would be >>scaled Q0.15 on the output for a 16-bit output (e.g.). >> >>Now, you can get a gain of 2^M for free! Simply shift the binary point >>to the right M places, M <= 15. Note that the actual integer output >>values remain unchanged - it's just a change in the interpretation of >>the output (namely, in the position of the imaginary binary point). You >>will neither lose precision nor chance overflow (or saturation). > > > Hi, > I think I expressed myself incorrectly when talking about gain. > > This 3rd order filter: > b = [1 3 3 1]; > a = [1 -1.6009450356 0.9414772490 -0.1971027115]; > has a gain of 1789.111562. > > The input to the filter is [-1:1). > Now of course I want to have 0dB gain in the passband, so I need to scale > everything by 1/1789.11562 at some point. Doing it on the input requires > about 11 extra LSBs to keep SNR fine. Doing it on the output requires 11 > extra MSBs so that the filter can handle numbers up to 1789...
Wait... This sounds wrong. If your filter gain is 1789, then you ALREADY have to have the extra MSBs to cover that gain, or you must otherwise somehow allow for the maximum necessary for the filter, e.g., by keeping some number of bits (not necessarily MORE than what you have now) with a binary point in the place that admits the max full-scale required by the filter gain.
> I'm doing this in an FPGA so I have control of the wordlength at all nodes. > The 'FIR' part is trivial and requires no multiply at all. Then I was > thinking to do the scaling multiply before going in the IIR part - making > everything 11bits wider before we even start. I just feel like this > inherent gain is costing me so much! > > Am I missing something?
Yes. Extra gain !==> extra bits. Bits are for precision. For example, you could have an 11 bit output with the binary point at 0 (i.e., integer) - that would cover your required output range. The problem you need to analyze is, what does this output width due to your feedback paths with respect to limit cycles, quantization errors, and such. I'm not an expert in IIR design, and the intuitions I'm feeling are too complex to type quickly, but I hope my intuition is correct and this limited coverage gives you an idea of where to head. -- Randy Yates % "I met someone who looks alot like you, Digital Signal Labs % she does the things you do, mailto://yates@ieee.org % but she is an IBM." http://www.digitalsignallabs.com % 'Yours Truly, 2095', *Time*, ELO
"Randy Yates" <yates@ieee.org> wrote in message
news:m3hbibk64s.fsf@ieee.org...
> Consider your input signal [-1, +1). If your filter's maximum passband > gain is 1, then the maximum output is one.
I don't get this. Surely a full amplitude step into a brick-wall will give you an output > 1.0. Pete
> This 3rd order filter: > b = [1 3 3 1]; > a = [1 -1.6009450356 0.9414772490 -0.1971027115]; > has a gain of 1789.111562. > > I'm doing this in an FPGA so I have control of the wordlength at all nodes. > The 'FIR' part is trivial and requires no multiply at all.
How are the multiplications for the IIR done ? CSD / canonical signed digit thats shift&add&subtract would be possible, but one would probably then try to thin out the bits in a1, a2, a3 too.
What is the wordlength at the input ? That would give an indication how much precision for coefficients is needed. MfG JRD
"Pete Fraser" <pfraser@covad.net> writes:
> "Randy Yates" <yates@ieee.org> wrote in message > news:m3hbibk64s.fsf@ieee.org... > >> Consider your input signal [-1, +1). If your filter's maximum passband >> gain is 1, then the maximum output is one. > > I don't get this. > Surely a full amplitude step into a brick-wall will give you > an output > 1.0.
You mean because of overshoot? I see that. Good point. I probably should have just stated that the output was assumed to be [-1, +1). The actual maximum output value (assuming you don't saturate) depends on the "impulse response area": a = sum_{n = -\infty}^{+\infty} h[n] For FIR this is computable. For IIR, I don't know of an easy way to determine that. (Or if I did I've forgotten...) -- Randy Yates % "My Shangri-la has gone away, fading like Digital Signal Labs % the Beatles on 'Hey Jude'" mailto://yates@ieee.org % http://www.digitalsignallabs.com % 'Shangri-La', *A New World Record*, ELO
