Windowed sinc
Started by Vladimir Vassilevsky September 2, 2010
  When making a filter for a time domain interpolation of a signal using
a windowed sinc kernel, what should be the right way of aligning the
window towards sinc?
I can think of three possibilities:
  1) The center of the window could be set at 0.
  2) The center of the window could be set to the value of the time
domain shift of the interpolator.
  3) The center if the window could be aligned to the "center of mass"
of the set of sinc coefficients.
What is the best option ?
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
On Sep 2, 7:55&#4294967295;pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:
> &#4294967295; When making a filter for a time domain interpolation of a signal using > a windowed sinc kernel, what should be the right way of aligning the > window towards sinc? > > I can think of three possibilities: > > &#4294967295; 1) The center of the window could be set at 0. > &#4294967295; 2) The center of the window could be set to the value of the time > domain shift of the interpolator. > &#4294967295; 3) The center if the window could be aligned to the "center of mass" > of the set of sinc coefficients. > > What is the best option ? > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com
I would align the center of the window with the center of the sinc then sample as necessary. Dale B. Dalrymple
On 9/2/2010 7:55 PM, Vladimir Vassilevsky wrote:
> > When making a filter for a time domain interpolation of a signal using a > windowed sinc kernel, what should be the right way of aligning the > window towards sinc? > > I can think of three possibilities: > > 1) The center of the window could be set at 0. > 2) The center of the window could be set to the value of the time domain > shift of the interpolator. > 3) The center if the window could be aligned to the "center of mass" of > the set of sinc coefficients. > > What is the best option ? > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultant > http://www.abvolt.com > >
Vlad, Not sure I understand the question - although I probably do well understand the answer! I get that you want to use a windowed sinc to interpolate a signal in time. What I don't get is "aligning the window towards sinc"... ?? Also, I presume that you have a windowed sinc that is sampled at a rate higher than the time signal sequence. Thus it behaves as an interpolator when convolved. The original "window" is a perfect lowpass filter ("brick wall") and, thus, the windowing function serves to smooth the edges of the brick wall, maybe a lot. So the window and the lowpass filter functions are centered at f=0. I don't think it's an option. Help me understand better and I'll try to do better as well. Fred
On Thu, 2 Sep 2010 20:19:55 -0700 (PDT), dbd <dbd@ieee.org> wrote:
>On Sep 2, 7:55=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: >> =A0 When making a filter for a time domain interpolation of a signal usin= >g >> a windowed sinc kernel, what should be the right way of aligning the >> window towards sinc? >> >> I can think of three possibilities: >> >> =A0 1) The center of the window could be set at 0. >> =A0 2) The center of the window could be set to the value of the time >> domain shift of the interpolator. >> =A0 3) The center if the window could be aligned to the "center of mass" >> of the set of sinc coefficients. >> >> What is the best option ? >> >> Vladimir Vassilevsky >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > >I would align the center of the window with the center of the sinc >then sample as necessary. > >Dale B. Dalrymple
I think I agree with Dale, but there's an easy experiment to sort it out. Since the effect of the multiplication of the window in the time domain is convolution in the frequency domain, in order to assess the effect of the positions of the window just take the FFT of the combinations you're interested in. Intuitively from this perspective the window can easily be applied centered over the "window" of non-zero sinc samples. It's then easy to move it around and see what the effects are in the frequency domain. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
On Sep 2, 10:55&#4294967295;pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:
i'm sorta with Fred. Vlad, is it reasonable to expect that interpolating the time-reversed signal should result in the same as what you get when interpolating the original signal, except time reversed? i don't get why any interpolation wouldn't be symmetrical and constant delay (w.r.t. frequency), unless maybe you wanted less delay for some frequencies. but i don't really get the unsymmetrical interpolater response. r b-j
dbd wrote:
> On Sep 2, 7:55 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >> When making a filter for a time domain interpolation of a signal using >>a windowed sinc kernel, what should be the right way of aligning the >>window towards sinc? >> >>I can think of three possibilities: >> >> 1) The center of the window could be set at 0. >> 2) The center of the window could be set to the value of the time >>domain shift of the interpolator. >> 3) The center if the window could be aligned to the "center of mass" >>of the set of sinc coefficients. >> >>What is the best option ? >> > I would align the center of the window with the center of the sinc > then sample as necessary. > > Dale B. Dalrymple
I.e. the option (2). That was my thought, too; however there is a subtlety. Let's say we have signal sampled at the points -3, -2, -1, 0, 1, 2, 3 and we need to get the interpolated value at the point 0.5. So we calculate the coefficients as Window(x) sinc(x) centered at 0.5. We have 3 filter coefficients at the right from 0.5, and 4 coefficients at the left from 0.5. I can either make the window of the length = 6 and drop the extra coefficient from the left, or make the window of the length = 7, which is not going to be symmetric. When working with the windows of the length ~ 10, the +/- one coefficient could make substantial difference. VLV
>> When making a filter for a time domain interpolation of a signal using a >> windowed sinc kernel, what should be the right way of aligning the >> window towards sinc?
>> 1) The center of the window could be set at 0. >> 2) The center of the window could be set to the value of the time domain >> shift of the interpolator. >> 3) The center if the window could be aligned to the "center of mass" of >> the set of sinc coefficients. >> >> What is the best option ?
>Not sure I understand the question - although I probably do well >understand the answer!
I am opposite; I understand the question, but do not know the answer and would have to simulate it. To me, (1) only makes sense if the effect of the windowing is to interpolate from an odd number of points. (2) is how I would initially choose to do it, and (3) is interesting and I would want to see the results. Steve
On Sep 2, 9:18&#4294967295;pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:
> ... > there is a > subtlety. Let's say we have signal sampled at the points -3, -2, -1, 0, > 1, 2, 3 and we need to get the interpolated value at the point 0.5. So > we calculate the coefficients as Window(x) sinc(x) centered at 0.5. We > have 3 filter coefficients at the right from 0.5, and 4 coefficients at > the left from 0.5. I can either make the window of the length = 6 and > drop the extra coefficient from the left, or make the window of the > length = 7, which is not going to be symmetric. When working with the > windows of the length ~ 10, the +/- one coefficient could make > substantial difference. > > VLV
The continuous weighted sinc designed waveform is symmetric. Your interpolator samples can only be symmetric if you are calculating the output value at the time of an input sample or at a time half way between input sample times. Dale B. Dalrymple
On Sep 3, 1:29&#4294967295;am, dbd <d...@ieee.org> wrote:
> On Sep 2, 9:18&#4294967295;pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > > ... > > there is a > > subtlety. Let's say we have signal sampled at the points -3, -2, -1, 0, > > 1, 2, 3 and we need to get the interpolated value at the point 0.5. So > > we calculate the coefficients as Window(x) sinc(x) centered at 0.5. We > > have 3 filter coefficients at the right from 0.5, and 4 coefficients at > > the left from 0.5. I can either make the window of the length = 6 and > > drop the extra coefficient from the left, or make the window of the > > length = 7, which is not going to be symmetric. When working with the > > windows of the length ~ 10, the +/- one coefficient could make > > substantial difference. > > The continuous weighted sinc designed waveform is symmetric.
at least it *should* be. if you want to have the property of "reverse time invariance". Vlad, i asked you a question. care to address it?
> Your > interpolator samples can only be symmetric if you are calculating the > output value at the time of an input sample or at a time half way > between input sample times.
not if you're exactly half way *and* you are using 4 coefficients on the left and 3 coefficients on the right. r b-j
robert bristow-johnson wrote:
> On Sep 3, 1:29 am, dbd <d...@ieee.org> wrote: > >>On Sep 2, 9:18 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: >> >> >>>... >>>there is a >>>subtlety. Let's say we have signal sampled at the points -3, -2, -1, 0, >>>1, 2, 3 and we need to get the interpolated value at the point 0.5. So >>>we calculate the coefficients as Window(x) sinc(x) centered at 0.5. We >>>have 3 filter coefficients at the right from 0.5, and 4 coefficients at >>>the left from 0.5. I can either make the window of the length = 6 and >>>drop the extra coefficient from the left, or make the window of the >>>length = 7, which is not going to be symmetric. When working with the >>>windows of the length ~ 10, the +/- one coefficient could make >>>substantial difference. >> >>The continuous weighted sinc designed waveform is symmetric.
Continuous has to be sampled to make a filter, hence the coefficients are generally not going to be symmetric.
> at least it *should* be. if you want to have the property of "reverse > time invariance". Vlad, i asked you a question. care to address it?
"Vlad, is it reasonable to expect that interpolating the time-reversed signal should result in the same as what you get when interpolating the original signal, except time reversed?" If the filter is symmetric, yes. Otherwise the filter has to be time reversed also. What is the point?
>>Your >>interpolator samples can only be symmetric if you are calculating the >>output value at the time of an input sample or at a time half way >>between input sample times. > > not if you're exactly half way *and* you are using 4 coefficients on > the left and 3 coefficients on the right.
VLV
