Hi there, I have two sets of data which are irregularly sampled. These two sets are two measurements of the same product but on different places. Eg: Sensor 1: time 1, 3, 7, 8, 10, 15 ... Sensor 2: time 1, 2, 3, 5, 9, 10, 11, 14 ... The measurements are irregular because they are done by people, not by an automatic sampled system. I would like to calculate the cross correlation between these signals to obtain an estimate for a time delay. The question however is how to do this because of this missing data. The only thing I would come up with is interpolating the missing data, but I hardly believe that this is the best solution. Thanks in advance!
Calculating a cross correlation (to find delay) on irregulary sampled data
Started by ●September 4, 2010
Reply by ●September 6, 20102010-09-06
On Sep 4, 8:03�am, "webinn" <da_junk2@n_o_s_p_a_m.telenet.be> wrote:> Hi there, > > I have two sets of data which are irregularly sampled. These two sets are > two measurements of the same product but on different places. > > Eg: > Sensor 1: time 1, 3, 7, 8, 10, 15 ... > Sensor 2: time 1, 2, 3, 5, 9, 10, 11, 14 ... > > The measurements are irregular because they are done by people, not by an > automatic sampled system. > > I would like to calculate the cross correlation between these signals to > obtain an estimate for a time delay. > > The question however is how to do this because of this missing data. The > only thing I would come up with is interpolating the missing data, but I > hardly believe that this is the best solution. > > Thanks in advance!Seems like a difficult problem. Chatfield's book "The Analysis of Time Series: An Introduction", which I had for a graduate course in the early 80's only mentions unequal spaced data in passing. He suggests using splines to interpolate in the time domain. I'm not an expert at non-uniform sampling, but I briefly looked into it many years ago. I seem to recall that it was possible to compute uniformly spaced frequency domain outputs, even if your time data was not uniformly sampled. Consider a simple 4x4 DFT matrix for uniform samples: X0 | 0 0 0 0 | | x0 | X1 = | 0 1 2 3 | | x1 | X2 | 0 2 4 6 | | x2 | X3 | 0 3 6 9 | | x3 | The 4x4 matrix are your twiddles (the k*n in e(-j*twopi*k*n/N), the Xk column to the left are the (complex) DFT results, and the xn column are the uniformly spaced inputs. I find it helpful to put a visual interpretation to the above. The topmost row of twiddles are a constant '0' frequency waveform (1 - j0), the next row down is a 1 cycle (1f) complex waveform, the next is 2 cycles, and the bottom is 3 cycles. Now suppose your xn are not uniformly sampled in time. x0 is still your zero point, but let's say x1 was actually x1.1, x2 is really x1.9, and x3 is x2.9 (samples at times 0, 1.1, 1.9 and 2.9). We'd have to modify the DFT twiddles to accommodate the unequal spacing by changing the 'k*n' in the above, because 'n' is no longer an integer. The 'k' will remain the same (k = 0,1, 2 or 3), but 'n' will now be 1, 1.1, 1.9 and 2.9. And as I recall, it can be quite tricky to figure out exactly how to do this. What I did years ago was to generate 16 points of a single cycle sine wave (no noise), sample it unequally (e.g.: at 0, 1.2, 1.8, 2.1, ... 14.9, 15.1), and then figure out what twiddles to use in the DFT matrix. It helps to visualize it by drawing the twiddle matrix as waveforms, and then drawing vertical lines down on them to represent the time points corresponding to your sample times. Then I programmed it to make sure that I was doing things correctly. The results were pretty good, but my samples were only spaced a little bit off-center from the uniform case (e.g: +/- .1 to .3). And it makes sense in that the DFT is a least-mean-squares estimator. If you inverse transform your equally spaced frequency domain estimates using a 'normal' DFT, you should see what your (interpolated) uniform time samples look like. If you go that route, at least you'd have uniformly spaced frequency domain points (based on non-uniform time samples), and you could cross- correlate in the regular way. But I also seem to recall that the specifics of non-uniform time samples can adversely affect the variance of your frequency domain estimates (e.g.: sparse samples over some regions, and dense over others). So I don't really know if the above would be useful to you. Perhaps you could elaborate on the kind of data you're dealing with. Maybe some others here have dealt with similar problems and can suggest better solutions. Kevin McGee
webinn wrote:> Hi there, > > I have two sets of data which are irregularly sampled. These two sets are > two measurements of the same product but on different places. > > Eg: > Sensor 1: time 1, 3, 7, 8, 10, 15 ... > Sensor 2: time 1, 2, 3, 5, 9, 10, 11, 14 ... > > The measurements are irregular because they are done by people, not by an > automatic sampled system. > > I would like to calculate the cross correlation between these signals to > obtain an estimate for a time delay. > > The question however is how to do this because of this missing data. The > only thing I would come up with is interpolating the missing data, but I > hardly believe that this is the best solution.If the data source can be described by a model, you can approach this as a system identification problem. If nothing is known about the system, interpolation is the only solution. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●September 7, 20102010-09-07
On Sep 6, 6:05�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> webinn wrote: > > Hi there, > > > I have two sets of data which are irregularly sampled. These two sets are > > two measurements of the same product but on different places. > > > Eg: > > Sensor 1: time 1, 3, 7, 8, 10, 15 ... > > Sensor 2: time 1, 2, 3, 5, 9, 10, 11, 14 ... > > > The measurements are irregular because they are done by people, not by an > > automatic sampled system. > > > I would like to calculate the cross correlation between these signals to > > obtain an estimate for a time delay. > > > The question however is how to do this because of this missing data. The > > only thing I would come up with is interpolating the missing data, but I > > hardly believe that this is the best solution. > > If the data source can be described by a model, you can approach this as > a system identification problem. If nothing is known about the system, > interpolation is the only solution.I suggest using several different interpolation schemes and compare the results. If you use DFT interpolation be aware that, for nonuniform spacing, the reconstruction is based on Least-Squares and not on the IDFT formula. Search in comp.soft-sys.matlab using greg heath dftgh6 for matlab code containing relevant pseudoinverse and QR reconstruction formulae. High frequency zero padding will yield the interpolation. Hope this helps. Greg
