On Sep 18, 2:51�am, "naumanm" <masudnauman@n_o_s_p_a_m.yahoo.com> wrote:>... > I have got an IEEE paper by H. Glisson, C. I. Black and A. P. Page, �On > Digital Replica Correlation Algorithms with Applications to Active > Sonar�.According to this paper as i understand, multiple replicas needed > only when Wideband LFM pulse condition is satisfied,i.e. when target > velocity > 2610/TW.It would be easier for people to help if you gave a complete citation by including: IEEE Transactions on Audio and Electroacoustics Sep 1969, Vol: 17 Issue:3, page(s): 190 - 197> if narrowband LFM pulse is used, then according to this paper single zero > doppler replica is enough.But how in that case target velocity/doppler can > be found?By peak picking the power in the bins of the FFT in figure 6. Dale B. Dalrymple
sonar matched filter
Started by ●September 14, 2010
Reply by ●September 18, 20102010-09-18
Reply by ●September 20, 20102010-09-20
On Sep 18, 5:51�am, "naumanm" <masudnauman@n_o_s_p_a_m.yahoo.com> wrote:> >Back to your question: It depends on what you mean by a frequency > >domain matched filter. If you are just multiplying the Fourier > >transform of the MF by the Fourier transform of the signal then, yes > >you'll need a replica for each doppler velocity you are interested in. > > I have got an IEEE paper by H. Glisson, C. I. Black and A. P. Page, �On > Digital Replica Correlation Algorithms with Applications to Active > Sonar�.According to this paper as i understand, multiple replicas needed > only when Wideband LFM pulse condition is satisfied,i.e. when target > velocity > 2610/TW. > if narrowband LFM pulse is used, then according to this paper single zero > doppler replica is enough.But how in that case target velocity/doppler can > be found? > My real intention here is to know how to find target velocity using LFM > pulse in SONAR?LFM pulse is chosen since it is more immune to reverberation > as compared to CW pulses. > If any one have read this paper, can he/she kindly clarify my confusion? > > THANKS �In Neilson's book he goes through a design example. For a NB LFM pulse the velocity tolerance is given : 435 W/f_0 (where c =3000 knots) For WB LFM the velocity tolerance is 2614/(TW). For a given pulse he calculates the two tolerances and uses the one with the lower velocity tolerance. Note: Neilson references Glisson, Black, Sage "on Sonar Signal Analysis" IEEE Trans Aerospace and Electronic Systems,Vol AES 6 No 1 Jan 1970 pp 37-49 For an LFM pulse you aren't going to get a good velocity estimate. LFM waveforms are described as velocity tolerant, so a change in velocity doesn't affect the correlation that much. What the LFM does give you is much better range resolution due to the increased bandwidth. The real reason for using multiple replicas in LFM pulses is to help ensure that targets with higher velocities are detected. Those sonar guys really don't want to miss a detection. Hope that helps. Cheers, David
