Jake wrote:>> It is one of these kernel programming functions, like bcopy(), >> that nobody simulating a filter has any business using. >> >> It fills a given range of memory with a constant. > > Ok, but _why_ ? I am just asking because I want to learn so I can explain > to the next "lamer" why he/she shouldn't use it. I mean what's the point of > just accepting postulates without understanding the reasons behind.The reason why I don't like memset/memcpy in DSP code is that it breaks type safety. I often have various different fract types (1.15, 4.28, etc.). I can easily catch accidental mistakes (using a debugging version with each type defined as an individual struct) when the code reads for (i = 0; i < N; ++i) dest[i] = src[i]; but not when the code just stomps around the raw memory. Other than that, memset is surely fine to initialize big buffers upon system start. And it's definititely better than code using unreadable, inefficient countdown loops. Stefan
memset or not ?
Started by ●September 15, 2010
Reply by ●September 16, 20102010-09-16
On Sep 15, 4:23 pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Tim Wescott <t...@seemywebsite.com> wrote: > > (snip) > > > '83?!? Wow -- I'm moving up! Of course, that's when it found it's way > > into a book. > > I remember the first time I thought of some cool and 'unique' innovation > > in sampled data systems, only to find it in the literature -- for > > implementation on vacuum tubes. > > Better than Cooley and Tukey who found out, years later, that their > algorithm had been published by Gauss in 1805. (Without looking > it up, I believe 1805 is before vacuum tubes.)I will never forget the look on my PhD advisor's (Oscar Buneman) face in 1965 when he learned that Cooley and Tukey had published Gauss' Algorithm. Oscar had been using the algorithm since the 1930s. Quite a bit of his voluminous body of work involved fast methods of computer simulation via particle-field interactions (microwave electronics, plasma physics, gravitation, weather, fluids, etc). The FFT was used to convert space-time to wavenumber-time. The fast computation of the field at time t was then used to calculate particle positions at time t+dt, etc. Some of the readers may be more familiar with his later work on the Fast Hartley Transform. Searching on Google Web Buneman Hartley 3,440 hits Greg
On 16/09/2010 17:54, Stefan Reuther wrote:> Jake wrote: >>> It is one of these kernel programming functions, like bcopy(), >>> that nobody simulating a filter has any business using. >>> >>> It fills a given range of memory with a constant. >> >> Ok, but _why_ ? I am just asking because I want to learn so I can explain >> to the next "lamer" why he/she shouldn't use it. I mean what's the point of >> just accepting postulates without understanding the reasons behind. > > The reason why I don't like memset/memcpy in DSP code is that it breaks > type safety.Type safety is a general concern to programmers in any context - it is not something exclusive or even particularly special to dsp. The void pointer is the beast that compromises type safety - not any one library function in particular. Richard Dobson
Richard Dobson <richarddobson@blueyonder.co.uk> wrote:>On 16/09/2010 17:54, Stefan Reuther wrote:>> The reason why I don't like memset/memcpy in DSP code is that it breaks >> type safety.>Type safety is a general concern to programmers in any context - it is >not something exclusive or even particularly special to dsp.Sure, but memset() harks back to a non-type-safe style of kernel programming. So it's reasonally correct to say DSP programmers should not be using it, in the modern world. I would go further and say DSP programmers should be using C++ containers and not plain C arrays anymore, but there is probably less consensus on that. Steve
"Jake" <jake@nospam.invalid.com> wrote in message news:4c90d33f$0$50442$14726298@news.sunsite.dk...>I have a workbuffer with values that needs to be re-arranged, >so...initially...I did it like this: > > for (i = (N - 1); i >= 0; i--) > { > workbuffer[Q * i] = workbuffer[i]; > memset(&workbuffer[(Q * i) + 1], 0, (Q-1) * sizeof(int16)); > } > > but I was told not to use memset. I don't know exactly why I am not > allowed to use memset in a loop.Perhaps they meant it's not to be used in that particular algorithm? Anyway, I've come across a couple of instants where a loop is faster than the library function. I don't know about modern compilers, as this was a few years ago. But if you have 128 bit registers, or any special media registers like that, then maybe creating your own memset could be quicker. As you can blat as much memory as possible with each write. Although you'll need to make sure you align your allocated memory to 16 bytes. Cheers, Dave.
VelociChicken <turn@invalid.com> wrote: (snip)> Anyway, I've come across a couple of instants where a loop is > faster than the library function.> I don't know about modern compilers, as this was a few years ago. > But if you have 128 bit registers, or any special media registers > like that, then maybe creating your own memset could be quicker. > As you can blat as much memory as possible with each write. > Although you'll need to make sure you align your allocated > memory to 16 bytes.Well, in that case memset() should store enough to get to the next 16 byte boundary, loop for as many such blocks as possible, then store bytes to the end. I believe that S/370 MVCL is supposed to do that internally (maybe in microcode). The IA32 manuals specify that REP STOS is the fastest way to set large blocks of memory, even though it seems to do it a byte at a time. It might be that there is internal optimization for REP STOS and aligned blocks. As I said, memset() is intended to be efficient for large blocks, but maybe less efficient for smaller blocks. -- glen
Reply by ●September 17, 20102010-09-17
Richard Dobson wrote:> On 16/09/2010 17:54, Stefan Reuther wrote: >> Jake wrote: >>> Ok, but _why_ ? I am just asking because I want to learn so I can >>> explain to the next "lamer" why he/she shouldn't use it. I mean >>> what's the point of just accepting postulates without >>> understanding the reasons behind. >> >> The reason why I don't like memset/memcpy in DSP code is that it breaks >> type safety. > > Type safety is a general concern to programmers in any context - it is > not something exclusive or even particularly special to dsp.True, of course. But it happens that DSP is the field where I most often face the problem of zeroing or copying large arrays :-) (And where I'm needing the raw iron performance, and cannot hide everything behind nice C++ classes that do everything for me.) Stefan
robert bristow-johnson wrote:> > Vlad, am i a lamer because i didn't know about memset()?Sure. As well as anyone who got involved in this stupid thread. VLV
Stefan Reuther <stefan.news@arcor.de> wrote:>Richard Dobson wrote:>> Type safety is a general concern to programmers in any context - it is >> not something exclusive or even particularly special to dsp.>True, of course. But it happens that DSP is the field where I most often >face the problem of zeroing or copying large arrays :-) (And where I'm >needing the raw iron performance, and cannot hide everything behind nice >C++ classes that do everything for me.)True, but the incidence of not practicing type-safety when one should is far higher than the incidence of not being able to do so for performance reasons. Steve
Reply by ●September 28, 20102010-09-28
In article <4c90d33f$0$50442$14726298@news.sunsite.dk>, Jake <jake@nospam.invalid.com> wrote:>I have a workbuffer with values that needs to be re-arranged, >so...initially...I did it like this: > >for (i = (N - 1); i >= 0; i--) >{ > workbuffer[Q * i] = workbuffer[i]; > memset(&workbuffer[(Q * i) + 1], 0, (Q-1) * sizeof(int16)); >}Serves you right for using workbuffer in two different ways. /* The safety provided by comparing two sizes here is unsurpassed */ workbuffer = malloc( Q*N*sizeof(int16) ); memset(workbuffer, 0, Q*N*sizeof(int16)); /* Here you need to be careful */ for (i = 0; i<N; i++ ) { workbuffer[Q * i] = workbuffer_input[i]; } It all depends on trade offs, copying words one by one may be both safe and fast and have a small enough foot print.>Comments about not using memset in a loop are also welcomed.Some will argue to not use memset at all. I wouldn't care a bit. In the end you may look at the assembler output. I would care about what *that* has to say.> >Thank you. >Others argue to use C++: Any safety provided by the type system of C++ is offset by the unreliability of implementing an inherently ill-defined language and the problems to cope with its complexity. (Hell, I should save that for my thesis.) Groetjes Albert -- -- Albert van der Horst, UTRECHT,THE NETHERLANDS Economic growth -- being exponential -- ultimately falters. albert@spe&ar&c.xs4all.nl &=n http://home.hccnet.nl/a.w.m.van.der.horst
