hi all, im unable to generate INT0 interrupt in simulator after doing the "PIN CONNECT" specified in help (Tools --> Pin connect) and the input .dat file has 55 85 99 rpt 111|EOS data,i could not see the INT0 ISR being served while Timer_ISR is being served as xpected how could generate the INT0 interrupt in simulator mode and cross check it..? Thanks, Ganesh
Unable to simulate INT0 interrupt in Code composer studio
Started by ●September 16, 2010
