<lathe_biosas@hotmail.com> wrote in message news:f3fb6877.0410111118.366bfd1@posting.google.com...> "Mike Yarwood" <mpyarwood@btopenworld.com> wrote in message news: > > > I only have a very vague idea what you mean by finding the area andsuspect> > that you should be looking for the average area in some unit of time. > > Hi Mike > > Thanks for answering. > > The signal x(t) is a signal with Fourier transform X(f) such that > X(f)=0 |f|>=W > The signal x(t) is bandlimited to [-W,W] > The area is defined as: > > Area=\int_{-infty}^{infty} x(t)dt > > What is the slowest possible rate at which we can sample x(t) and > still be able to find the Area? > How do we find the Area from the samples? > > Best RegardsSorry Lathe - I forgot to ask if you were sure what you meant by the area of the signal. Most times people seem to want the energy or the energy per unit time (power or energy per bit or something) in which case you will most probably need to look at the area of the square of your signal. Again best of luck - Mike
Area of Bandlimited Signal
Started by ●October 10, 2004
Reply by ●October 11, 20042004-10-11
