What is the highest frequency that could be handled with discrete fourier transform software? Bret Cahill
Top Speed of DFT
Started by ●September 29, 2010
Reply by ●September 29, 20102010-09-29
Bret Cahill wrote:> What is the highest frequency that could be handled with discrete > fourier transform software?http://www.fftw.org/benchfft/ Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Sep 29, 1:16�pm, Bret Cahill <BretCah...@peoplepc.com> wrote:> What is the highest frequency that could be handled with discrete > fourier transform software? > > Bret CahillFs/2
On Sep 29, 1:16�pm, Bret Cahill <BretCah...@peoplepc.com> wrote:> What is the highest frequency that could be handled with discrete > fourier transform software? > > Bret CahillA simple diffraction grating will give you a dft for a single frequency bin for optical frequencies. Crystal lattices will do this for x-ray and gamma frequecies. Clay
> > >Bret Cahill wrote: > >> What is the highest frequency that could be handled with discrete >> fourier transform software? > >http://www.fftw.org/benchfft/ > > >Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com >Geez, FFTW3 seems to cream most of the other implementations in almost all tests on every architecture tested on the site. Pretty impressive. Jacob
Clay <clay@claysturner.com> wrote: (snip)> A simple diffraction grating will give you a dft for a single > frequency bin for optical frequencies. Crystal lattices will do this > for x-ray and gamma frequecies.It does seem that gamma diffraction can work. There is even a report of a gamma lens based on rings of crystals with the appropriate spacing and angle to diffract gamma rays to a small focal spot. -- glen
> > What is the highest frequency that could be handled with discrete > > fourier transform software? > > http://www.fftw.org/benchfft/Phew! What a relief! For awhile there I was concerned about 10^-36 errors but no more!> Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com
Bret Cahill wrote:>>>What is the highest frequency that could be handled with discrete >>>fourier transform software? >> >>http://www.fftw.org/benchfft/ > > > Phew! What a relief! For awhile there I was concerned about 10^-36 > errors but no more!There is no need to stick out; everybody already knew what you are. VLV
> >>>What is the highest frequency that could be handled with discrete > >>>fourier transform software? > > >>http://www.fftw.org/benchfft/ > > > Phew! �What a relief! �For awhile there I was concerned about 10^-36 > > errors but no more! > > There is no need to stick out; everybody already knew what you are.Thanks for the interesting link. Bret Cahill
On Sep 29, 2:23�pm, John <sampson...@gmail.com> wrote:> On Sep 29, 1:16�pm, Bret Cahill <BretCah...@peoplepc.com> wrote: > > > What is the highest frequency that could be handled with discrete > > fourier transform software?...> > Fs/2or maybe a millismidgen less than that. r b-j
