Reducing noise impact in FFT: averaged segment method
Started by shinchan75034 ●October 5, 2010
On Oct 9, 12:20&#4294967295;pm, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:
> > Sorry that I don't have a reference for you but, > somewhere I read the writing of DSP guru fred harris > and he said that a time overlap of up to 50% > yields acceptable FFT results in reducing the > variance when averaging multiple FFTs. >
Try section 5.2 "How much overlap" in: http://www.signumconcepts.com/download/paper033.pdf WINDOWS: Finite Aperture Effects and Applications in Signal Processing by fred j. harris Dale B. Dalrymple
On Oct 8, 11:03&#4294967295;am, dbd <d...@ieee.org> wrote:
> On Oct 6, 11:03&#4294967295;am, Dirk Bell <bellda2...@cox.net> wrote: > > > On Oct 5, 11:05&#4294967295;pm, dbd <d...@ieee.org> wrote: > > ... > > > The rest of the paper may also be useful to you. > > > > Dale B. Dalrymple > > > Dale, > > > You might want to steer the OP away from "measurement" flat-top > > windows for the OP's application. I don't think that part of the rest > > of the paper will be useful to the OP. > > > Dirk > > I might want to know more about the OP's signals, noise and > applications before jumping to conclusions. > > Dale B. Dalrymple
Dale, The OP said that he/she wanted to find the spectrum of a signal, not the magnitude of a test tone (a single one or several tones further apart than the flat-top window's spectral width). Implying that a flat-top window, which smears the spectrum, but is good for accurate tone magnitude measurement, would be useful for spectral estimation is certainly jumping to conclusions that contradict the OP's original problem statement. So I agree with you, you don't want to do that. Dirk
On Oct 9, 3:24&#4294967295;pm, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:
> On Wed, 6 Oct 2010 10:49:37 -0700 (PDT), Dirk Bell > > <bellda2...@cox.net> wrote: > > &#4294967295; &#4294967295;[Snipped by Lyons] > > > > > > >> Rick Lyons recently reminded me of a paper on flattop windows that > >> begins with a nice explanation of the issues you have asked about. > >> Look at pages 5-21 of the paper at: > > >>http://www.rssd.esa.int/SP/LISAPATHFINDER/docs/Data_Analysis/GH_FFT.pdf > > >> The rest of the paper may also be useful to you. > > >> Dale B. Dalrymple > >> There is a paper you can > > >Wow Dale, > > >For the life of me I can't figure out why you would recommend a > >"measurement" flat-top window for the OP's application. A > >"measurement" flat-top produces &#4294967295;a lot of smearing in the spectrum, > >and has the property that it gets rid of the scalloping loss in the > >measurement of an isolated sinusoid/sinusoidal component, where the > >smearing doesn't efect the measurement value, but certainly effects > >the computed spectrum (see page 38 of your recommended article). > >Doesn't sound like the OP wants that. > > >Why did you pick a "measurement" flat-top window to suggest? > > >Where you thinking of a "time doman" flat-top window (quite > >different)? > > >Maybe you are just poking fun at the OP? > > >Dirk > > Hi Dirk, > &#4294967295; I don't think Dale was recommending that the OP > used flat-top windowing. &#4294967295;Rather, I think Dale > was merely giving an easily obtained refeence that > discussed "overlapped-in-time" spectrum analysis. > > Another place to read about "overlapped-in-time" > spectrum analysis is under the heading of > "Welch's Method" at: > > http://www.mathworks.com/help/toolbox/signal/f12-6587.html&#4294967295; > > See Ya', > [-Rick-]
Hi Rick, I didn't say Dale was stating that a flat-top window was appropriate, but with his description of the paper as being on flat-top windows (which are not appropriate to the OP's problem) and the large amount time spent in the article on flat-top windows, I think Dale should have steered the OP away from the irrelevant part and towards the relevant part. Since the OP is asking such a question, I don't think it helpful to let him/her just sort it out. If Dale didn't want to take the time to do this, he could have picked a far better reference. Dirk
On Oct 9, 3:20&#4294967295;pm, Dirk Bell <bellda2...@cox.net> wrote:
>... > Dale, > > The OP said that he/she wanted to find the spectrum of a signal, not > the magnitude of a test tone (a single one or several tones further > apart than the flat-top window's spectral width). &#4294967295;Implying that a > flat-top window, which smears the spectrum, but is good for accurate > tone magnitude measurement, would be useful for spectral estimation is > certainly jumping to conclusions that contradict the OP's original > problem statement. So I agree with you, you don't want to do that. > > Dirk
I stated the section I thought useful for the immediate question. As to the rest of the reference, most of it deals with non-flattop windows. As to the OP's future needs and applications I lack your crystal ball, so I didn't claim that all of it will be useful. The reference is a good review of the use of windows of a variety of forms, whatever the content of it's title. I think that if you were interested in generating light for the OP instead of heat for me you would have explained your concern in your first post and supplied a better reference, if you think there is one as freely available. You are still free to do that now. Dale B. Dalrymple
On Oct 9, 7:54&#4294967295;pm, dbd <d...@ieee.org> wrote:
> On Oct 9, 3:20&#4294967295;pm, Dirk Bell <bellda2...@cox.net> wrote: > > >... > > Dale, > > > The OP said that he/she wanted to find the spectrum of a signal, not > > the magnitude of a test tone (a single one or several tones further > > apart than the flat-top window's spectral width). &#4294967295;Implying that a > > flat-top window, which smears the spectrum, but is good for accurate > > tone magnitude measurement, would be useful for spectral estimation is > > certainly jumping to conclusions that contradict the OP's original > > problem statement. So I agree with you, you don't want to do that. > > > Dirk > > I stated the section I thought useful for the immediate question. As > to the rest of the reference, most of it deals with non-flattop > windows. As to the OP's future needs and applications I lack your > crystal ball, so I didn't claim that all of it will be useful. The > reference is a good review of the use of windows of a variety of > forms, whatever the content of it's title. > > I think that if you were interested in generating light for the OP > instead of heat for me you would have explained your concern in your > first post and supplied a better reference, if you think there is one > as freely available. You are still free to do that now. > > Dale B. Dalrymple
I think you are overly sensitive Dale. What possible real problem could you have had with my post? You called it a flat-top article and now you say it has little about that subject in it. I think calling it that might make the OP think that is something he/she needs to address their stated problem. It isn't. As for the future needs of the OP, apparently your crystal balls can anticipate that, but I was just responding to their stated present need. No crystal ball needed to see the present. Actually your reference explains why flat-top windows would be bad if the OP reads and understands the article. And information to largely answer the questions is contained in the article. I was suggesting that since it has a mix of OP usable and a significant amount of OP unusable information, you might help him/her sort it out better since you pointed the OP to it. This is sounding a little repetative, but some people need that. Dirk
On Oct 9, 10:14&#4294967295;pm, Dirk Bell <bellda2...@cox.net> wrote:
> On Oct 9, 7:54&#4294967295;pm, dbd <d...@ieee.org> wrote: > > > > > On Oct 9, 3:20&#4294967295;pm, Dirk Bell <bellda2...@cox.net> wrote: > > > >... > > > Dale, > > > > The OP said that he/she wanted to find the spectrum of a signal, not > > > the magnitude of a test tone (a single one or several tones further > > > apart than the flat-top window's spectral width). &#4294967295;Implying that a > > > flat-top window, which smears the spectrum, but is good for accurate > > > tone magnitude measurement, would be useful for spectral estimation is > > > certainly jumping to conclusions that contradict the OP's original > > > problem statement. So I agree with you, you don't want to do that. > > > > Dirk > > > I stated the section I thought useful for the immediate question. As > > to the rest of the reference, most of it deals with non-flattop > > windows. As to the OP's future needs and applications I lack your > > crystal ball, so I didn't claim that all of it will be useful. The > > reference is a good review of the use of windows of a variety of > > forms, whatever the content of it's title. > > > I think that if you were interested in generating light for the OP > > instead of heat for me you would have explained your concern in your > > first post and supplied a better reference, if you think there is one > > as freely available. You are still free to do that now. > > > Dale B. Dalrymple > > I think you are overly sensitive Dale. What possible real problem > could you have had with my post? You called it a flat-top article and > now you say it has little about that subject in it. &#4294967295;I think calling > it that might make the OP think that is something he/she needs to > address their stated problem. It isn't. As for the future needs of the > OP, apparently your crystal balls can anticipate that, but I was just > responding to their stated present need. No crystal ball needed to see > the present. > > Actually your reference explains why flat-top windows would be bad if > the OP reads and understands the article. And information to largely > answer the questions is contained in the article. I was suggesting > that since it has a mix of OP usable and a significant amount of OP > unusable information, you might help him/her sort it out better since > you pointed the OP to it. This is sounding a little repetative, but > some people need that. > > Dirk
You still haven't addressed anything to the OP in this thread. You continue to misrepresent what I have posted.No light yet, just more trolling. Dale B. Dalrymple
On Oct 10, 1:41&#4294967295;am, dbd <d...@ieee.org> wrote:
> On Oct 9, 10:14&#4294967295;pm, Dirk Bell <bellda2...@cox.net> wrote: > > > > > > > On Oct 9, 7:54&#4294967295;pm, dbd <d...@ieee.org> wrote: > > > > On Oct 9, 3:20&#4294967295;pm, Dirk Bell <bellda2...@cox.net> wrote: > > > > >... > > > > Dale, > > > > > The OP said that he/she wanted to find the spectrum of a signal, not > > > > the magnitude of a test tone (a single one or several tones further > > > > apart than the flat-top window's spectral width). &#4294967295;Implying that a > > > > flat-top window, which smears the spectrum, but is good for accurate > > > > tone magnitude measurement, would be useful for spectral estimation is > > > > certainly jumping to conclusions that contradict the OP's original > > > > problem statement. So I agree with you, you don't want to do that. > > > > > Dirk > > > > I stated the section I thought useful for the immediate question. As > > > to the rest of the reference, most of it deals with non-flattop > > > windows. As to the OP's future needs and applications I lack your > > > crystal ball, so I didn't claim that all of it will be useful. The > > > reference is a good review of the use of windows of a variety of > > > forms, whatever the content of it's title. > > > > I think that if you were interested in generating light for the OP > > > instead of heat for me you would have explained your concern in your > > > first post and supplied a better reference, if you think there is one > > > as freely available. You are still free to do that now. > > > > Dale B. Dalrymple > > > I think you are overly sensitive Dale. What possible real problem > > could you have had with my post? You called it a flat-top article and > > now you say it has little about that subject in it. &#4294967295;I think calling > > it that might make the OP think that is something he/she needs to > > address their stated problem. It isn't. As for the future needs of the > > OP, apparently your crystal balls can anticipate that, but I was just > > responding to their stated present need. No crystal ball needed to see > > the present. > > > Actually your reference explains why flat-top windows would be bad if > > the OP reads and understands the article. And information to largely > > answer the questions is contained in the article. I was suggesting > > that since it has a mix of OP usable and a significant amount of OP > > unusable information, you might help him/her sort it out better since > > you pointed the OP to it. This is sounding a little repetative, but > > some people need that. > > > Dirk > > You still haven't addressed anything to the OP in this thread. You > continue to misrepresent what I have posted.No light yet, just more > trolling. > > Dale B. Dalrymple- Hide quoted text - > > - Show quoted text -
I just made a suggestion that you point out something I thought was misleading in your response to the OP. My initial response to you was informative to the OP wether it was addressed to you or not. I have posted enough here over the years that I don't think I qualify as a troll. You are proving to be boring and childish and a waste of time and bandwidth. You may have the last word. Dirk
On Oct 10, 10:30&#4294967295;am, Dirk Bell <bellda2...@cox.net> wrote:
> > I just made a suggestion that you point out something I thought was > misleading in your response to the OP. &#4294967295;My initial response to you was > informative to the OP wether it was addressed to you or not. &#4294967295;I have > posted enough here over the years that I don't think I qualify as a > troll. &#4294967295;You are proving to be boring and childish and a waste of time > and bandwidth. &#4294967295;You may have the last word. > > Dirk
Anyone interested in evaluating current behavior can do so by reading the posts in this thread. Dale B. Dalrymple
