On Oct 8, 4:06�pm, emeb <ebromba...@gmail.com> wrote:> On Oct 7, 6:16�pm, John <sampson...@gmail.com> wrote: > > > > > > > On Oct 7, 6:30�pm, "cinetron" <cinetron@n_o_s_p_a_m.passport.ca> > > wrote: > > > > >cinetron wrote: > > > > >> I have a newbie question. I am about to embark on a project for which I > > > am > > > >> designing a multiple channel filter bank. This device will have an > > > input > > > >> signal from 20 to 10K Hz and and 8 outputs. The outputs will split the > > > >> signal into 8 frequency bands approx. > > > >> 20 to 100 > > > >> 100 to 200 > > > >> 200 to 300 > > > >> 300 to 400 > > > >> 400 to 500 > > > >> 500 to 600 > > > >> 600 to 700 > > > >> 700 to 10k > > > > >> Since I have never tackled a DSP project I thought I would see how > > > others > > > >> might tackle this. I am quite familiar to using PIC mucrocontrollers so > > > am > > > >> leaning towards using there dsPICs. I am considering using a dsPIC for > > > the > > > >> filters and a CS42518 2 in 8 out CODEC. > > > >>http://www.cirrus.com/en/products/cs42518-28.html. I want at least 16 > > > bit > > > >> audio. Another possibility I was thinking was to use 2 ADAU1701 Analog > > > >> Devices processors as they have 4 built in DACs and their Sigma Studio > > > >> Software looks quite slick. > > > >http://www.analog.com/en/audiovideo-products/audio-signal-processors/... > > > > >> My questions with respect to these two solutions: > > > >> Can the Sigma Studio software handle 4 different filters with 4 > > > outputs. > > > >> ( I still have to determine my filter characteristics so this may be > > > hard > > > >> to answer) > > > >> Also can the dsPIC do 8 filters simultaneously and speak with the CODEC > > > in > > > >> real time. > > > >> Thanks, these may not be the best solution to the problem so I'm open > > > to > > > >> better solutions. > > > > >1. For 8 channels of processing at audio sample rate, I would take a > > > >real DSP like Blackfin-531 or TMS55xx. > > > > >2. Codec interfacing to the DSP is no problem. > > > > >3. Each band is likely to require two cascaded biquads at least. > > > > >4. The processing should be implemented with ~31 bit precision. > > > > >5. Do you need to update the filter settings during the run time? > > > > >6. dsPICs and Sigma Studios isn't an answer. > > > > >Vladimir Vassilevsky > > > >DSP and Mixed Signal Design Consultant > > > >http://www.abvolt.com > > > > Thanks Vladimir for the suggestion. > > > Presently I don't have to update the filters at run time but eventually it > > > would be nice to have that flexibility. I was thinking the processing > > > overhead of 8 channels wouldn't be huge doing an FIR based filter for > > > example since the input value doesn't change for each channel. All 8 > > > channels are processing the same input just spitting out different results > > > based on different coefficients. I'm also considering 2 of these chips from > > > quickfilter to do the filter work.http://www.quickfiltertech.com/html/content_page.php?content_id=7& > > > Jim > > > Curious, how does a common filter input value save anything when the > > filters are all different? > > > John > > if it's a bunch of FIR filters in direct form you can use the same x(n- > m) pipeline for all of them. Not much of a savings though since you > still have to do all the multiplies separately for each output SOP. > > Eric- Hide quoted text - > > - Show quoted text -Right. Another way to do the filterbank is with FFTs and inverse FFTs as described here: www.3db-labs.com/01598092_MultibandFilterbank.pdf A key thing to figure out is how many FIR taps your bandpass filter requires and whether the resulting FFT size can run on your platform. John
Started by ●October 7, 2010
Reply by ●October 9, 20102010-10-09
