HEre is my question ... I have 20 acquistions to realise on a TMS320F28xx (100 Mips) The sample rate is 1khz. If i don t use the ADC of the TMS230F28xx , Is it possible to use 20 external ADC linked with the TMS320 with SPI ? But especially, is the GPIO Mux able to manage silmunatous input acquisition? Or do i have to use a time delay between 2 acquistions? Thank you
How to manage several acqusitions on TMS320
Started by ●February 13, 2004
Reply by ●February 15, 20042004-02-15
X-No-Archive: Yes domistep@free.fr (domistep) wrote:>HEre is my question ... >I have 20 acquistions to realise on a TMS320F28xx (100 Mips) >The sample rate is 1khz. > >If i don t use the ADC of the TMS230F28xx , >Is it possible to use 20 external ADC linked with the TMS320 with SPI ? >But especially, is the GPIO Mux able to manage silmunatous input acquisition? >Or do i have to use a time delay between 2 acquistions?I would think that you would need some sort of multiplexer arrangement, where you are running the ADC's into the inputs of multiplexer, and then the TMS is used to sample it's output. An additional port on the TMS can be used to change the multiplexer settings, to select the different ADC to be connected to the multiplexer output. Robert www.gldsp.com ( modify address for return email ) www.numbersusa.com www.americanpatrol.com
