hello friends, here i do my ifft coding with the help of the radix 4 algorithm formulae is y(l) = x(l) + x(l+N/2) + x(l+N/4) + x(l+3N/4); z(l) = x(l) - x(l+N/2)+j(x(l+N/4) - x(l+3N/4); g(l) = x(l) + x(l+N/2) - x(l+N/4) - x(l+3N/4); h(l) = x(l) - x(l+N/2)-j(x(l+N/4) - x(l+3N/4); with respect to above if i design for the 64 point i put N = 64.AND I first i calculate the first stage of 4 16 points and after that i do 16 point ifft for 4 times. here, i got the result of only 16 point ifft very correctly have to check with matlab and correct result is obtained. if i go to 64 point , i'm not able to obtain the output. so pls guide me,, and i post my coding tomorrow.
needed help in radix 4 algorithm
Started by ●February 13, 2004
Reply by ●February 14, 20042004-02-14
senthil wrote:> hello friends, > > here i do my ifft coding with the help of the radix 4 algorithm > > formulae is > > y(l) = x(l) + x(l+N/2) + x(l+N/4) + x(l+3N/4); > z(l) = x(l) - x(l+N/2)+j(x(l+N/4) - x(l+3N/4);^ what does this '(' match?> g(l) = x(l) + x(l+N/2) - x(l+N/4) - x(l+3N/4); > h(l) = x(l) - x(l+N/2)-j(x(l+N/4) - x(l+3N/4);^ what does this '(' match? I assume: - twiddle factors were omitted from your description - y,z,g,h correspond to f0,f1,f2,f3 - the missing parentheses above should be at the end of the line, just before the ';' If these assumptions are correct, the problem is your 'h' definition. Compare your code above to the IDFT of size 4, f0 | 1 1 1 1 | F0 f1 = | 1 j -1 -j | * F1 f2 | 1 -1 1 -1 | F2 f3 | 1 -j -1 1 | F3 I must ask, why are writing your own FFT? Take a look at http://sourceforge.net/projects/kissfft If your needs are still not met by kissfft, fftw, or any of the other fine fft libraries around, you might still need to write your own. The derivation in the files section of kissfft's project page could help. It is a one-page derivation the mixed radix,decimation-in-time forward fft. The inverse fft is roughly the same derivation with sign changes. (I guess I should mention that in the pdf.) Regards, Mark Borgerding
