On 10/14/2010 8:14 AM, Fred Marshall wrote:> On 10/14/2010 7:47 AM, Dirk Bell wrote: >> On Oct 13, 8:07 pm, Fred Marshall<fmarshall_xremove_the...@xacm.org> >> wrote: >>> On 10/13/2010 4:44 PM, Tim Wescott wrote: >>> >>> >>> >>>> On 10/13/2010 03:01 PM, Dirk Bell wrote: >>>>> On Oct 13, 12:37 pm, "bendous"<samir@n_o_s_p_a_m.eee.strath.ac.uk> >>>>> wrote: >>>>>> Hi all, >>> >>>>>> I am not a DSP expert so please go easy on me. I have a VLF radio >>>>>> signal >>>>>> centred at 3KHz. The signal is corrupted with the mains harmonics, >>>>>> which >>>>>> seem to be over 20dB higher than the signal! >>> >>>>>> I am trying to implement an algorithm that isolates an out-of-band >>>>>> harmonic >>>>>> using a band-pass filter, resamples it several times to obtain the >>>>>> in-band >>>>>> harmonics, and subtracts them from the corrupted signal. >>> >>>>>> Let's say I have a reference harmonic x with N samples and I do >>> >>>>>> y = resample(x,I,Q); >>> >>>>>> the length of y will be N*I/Q samples. >>> >>>>>> I need then to take the the fft of y and z (the corrupted signal), >>>>>> subtract >>>>>> them and reconstruct z using the ifft. >>> >>>>>> My understanding is that I need to use the same Nfft for both ffts in >>>>>> order >>>>>> to be able to subtract one from the other. >>> >>>>>> What value should that be? N or N*I/Q? >>>>>> And what should the ifft factor be? >>> >>>>>> I would be very grateful if someone could give me some pointers. I am >>>>>> doing >>>>>> this in Matlab and any pieces of code will be very much appreciated. >>> >>>>>> Kind regards, >>>>>> Samir. >>> >>>>> Samir, >>> >>>>> Keep in mind that the phase of the subsampled signals may not be >>>>> correct; if you were going to actually subtract the complex FFTs, that >>>>> would effect the amount of cancellation. Since the harmonics would >>>>> probably (almost guaranteed) fall in more than a single FFT bin there >>>>> are multiple FFT bin phases per harmonic to deal with. >>> >>>> Which is why I suggested a comb filter (inverse comb filter? >>>> multiple-notch filter?). By the time you figure out the phase and >>>> amplitude of each harmonic and inject them back into the signal "in >>>> reverse" to cancel them, you've essentially built a comb filter but >>>> in a >>>> really wacky and hard-to-understand way. >>> >>>>> Is the signal bandwidth sufficiently low that significant low >>>>> frequency harmonics can be removed by a lowpass filter? >>> >>>>> The best solution if it is possible, as Tim says below, is don't let >>>>> the power line harmonics get in the signal in the first place. >>> >>>>> Dirk >>> >>> I agree with Tim and Dirk. Depending on how much data you have, this >>> seems like relatively natural application for an automatic line >>> canceller ALC. That is if the mains harmonics are relatively stable and >>> the VLF signal has some dynamics that would not cause it to be >>> cancelled. Effectively this is close to what you were trying to do with >>> subtraction but without the FFT / IFFT. >>> >>> Comments anyone? >>> >>> If the harmonics are of 50/60Hz then there will be a lot of them around >>> 3kHz, right? >>> >>> Fred- Hide quoted text - >>> >>> - Show quoted text - >> >> You would think the level of the harmonics would be pretty low at 3kHz >> (20th/30th harmonic at 50/60 Hz). That is why I was asking about the >> bandwidth and a highpass filter (originally typed lowpass while >> thinking highpass) since the signal is centered at 3 KHz. >> >> A simple comb filter is potentially going to remove a lot of the >> signal and the high attenuation part of the all of the notches is so >> narrow that the first notch being off a little from the signal means >> that the attenuation isn't nearly as good. It also means the >> attenuation decreases as the harmonics go up because the mistuning >> increases, so harmonics can be missed altogether. If the notch >> frequencies are static, then power line frequency may wander into and >> out of the deep part of the notches over time. >> >> With audio (not the target signal here) I have seen improvements in >> descreasing the power line frequency and harmonics signals, but the >> problem isn't solved as far as I know. >> >> Dirk > > That's why I was suggesting a line canceller. The objective is to get > the adaptive FIR filter in the block diagram to become a comb passband > filter for the interference only - for subsequent subtraction. To the > extent that this block isn't too selective (i.e. long transient > response) it will track noise phase because that's based on the input. > Then, if the signal dynamics are OK, the signal won't be subtracted at > the output. > > Depending on signal and noise dynamics (e.g. if the signal has a short > correlation time relative to the noise) then one might delay one of the > paths so that the signal isn't cancelled (because the two paths are > uncorrelated) but the noise is. > > I'm sure I'm being a bit cryptic here but it's something that would have > to be worked out with real signals. > > FredBy "noise" I meant the *interfering* line signal that's actually not noiselike. Fred
Resampling for interference cancellation
Started by ●October 13, 2010
Reply by ●October 14, 20102010-10-14
