reduction of noises using FRM technique
Started by enricophpdsp October 13, 2010
hello,
I read the IEEE paper published by Yong Lian and Jiang Hong Yo ,2004 on the
topic THE REDUCTION OF NOISES IN ECG SIGNAL USING FREQUENCY RESPONSE
MASKING BASED FIR FILTER. In this paper the author has proposed a modified
FRM technique in which he is using prefilter-equalizer filter.
I want to ask that why this modified technique has been used instead of the
conventional method ?
On Oct 13, 9:47�pm, "enricophpdsp"
<enricophpdsp@n_o_s_p_a_m.yahoo.com> wrote:
> hello, > > I read the IEEE paper published by Yong Lian and Jiang Hong Yo ,2004 on the > topic THE REDUCTION OF NOISES IN ECG SIGNAL USING FREQUENCY RESPONSE > MASKING BASED FIR FILTER. In this paper the author has proposed a modified > FRM technique in which he is using prefilter-equalizer filter. > > I want to ask that why this modified technique has been used instead of the > conventional method ?
1) Quote the full citation of papers, or no one will bother looking up partial references like the above. 2) Well-written papers will contain some justification for such choises, either by explaining them in full (if in highly technical terms) or by referring to earlier works. 3) If you still can't figure out why, ask the authors. Rune
