help -- Windzilla (high dynamic range windows)
Started by Steve Pope October 21, 2010
On 10/25/2010 10:08 AM, Steve Pope wrote:
> > In my case I probably could use something very much like a Nuttall, but > which decays even faster. >
> Steve
Steve, The rate of decay is related to the edges of the window. In particular, if the edges are zero-valued, the decay is related to the *order* of the zeros of the window function at the edge of the window. And, there are well-known window functions that exploit this or similar ideas. I found this that looks pretty good and uses some of the same terminology: http://archive.chipcenter.com/dsp/DSP000308F1.html and this: http://zone.ni.com/reference/en-XX/help/371361B-01/lvanlsconcepts/char_smoothing_windows/ Fred
On Oct 25, 10:08 am, spop...@speedymail.org (Steve Pope) wrote:
>... Selecting the length is the less tricky part: the > resolution bandwith is proportional to 1 / (window length), and may > even be equal to (1 / (window length)) mutliplied by a metric > quoted by Dale in his presentatoin (the 3dB bandwith in "bins"). > (But I'm trying to better understand this and other metrics in > Dale's work.)
The correct parameter for resolution bandwidth is the effective noise bandwidth (ENBW). The -3dB bandwidth is close.
> ,,, > In my case I probably could use something very much like a Nuttall, but > which decays even faster. > ...
As we have discussed before, saying "Nuttall" for a window is gibbrish, unless possibly, you are referring to the two parameter family of Bessel windows he suggested as a multidimensional extension of the van der Mass class of optimal windows. (OK, I didn't mention Nuttall's two parameter Bessel family before.) Nuttall clearly and correctly (but not simply) labeled the windows he described in the 1981 ASSP Transactions paper. If you want people understand your statement tell us which you mean from the 18 windows in the table in his most frequency cited windows paper. Nuttall's descriptions are descriptive and functional. References that don't understand the windows well enough to name them correctly probably don't understand the window choices. Look for better. Nuttall's paper is available at http://www.ingelec.uns.edu.ar/pds2803/Materiales/Articulos/0084nutt.pdf The last page of my posting at the 2010 comp.dsp conference has an assortment of windows papers and where they are available on the web. If any succumb to web rot, let me know and I'll try to find new sources. In my writeup, the term bin is used to refer to the members of the set of basis function correlations calculated in a dft. If you want to use frequency units, the separation between adjacent bins is Fs/window size. I default Fs to 1.0. The paper figures are not labeled with frequency units because they are applicable to transforms of spacial sampling as well as temporal sampling. Dale B. Dalrymple
>>... Selecting the length is the less tricky part: the >> resolution bandwith is proportional to 1 / (window length), and may >> even be equal to (1 / (window length)) mutliplied by a metric >> quoted by Dale in his presentatoin (the 3dB bandwith in "bins"). >> (But I'm trying to better understand this and other metrics in >> Dale's work.)
>The correct parameter for resolution bandwidth is the effective noise >bandwidth (ENBW). The -3dB bandwidth is close.
Thanks
>> In my case I probably could use something very much like a Nuttall, but >> which decays even faster.
>As we have discussed before, saying "Nuttall" for a window is >gibbrish, unless possibly, you are referring to the two parameter >family of Bessel windows he suggested as a multidimensional extension >of the van der Mass class of optimal windows. (OK, I didn't mention >Nuttall's two parameter Bessel family before.)
Oops. Yes, I now remember the objections to referring to the most commonly used of Nuttall's window as "The Nuttall Window". I'll avoid this in the future.
>In my writeup, the term bin is used to refer to the members of the set >of basis function correlations calculated in a dft. If you want to use >frequency units, the separation between adjacent bins is Fs/window >size.
Thanks, that was my assumption.
>I default Fs to 1.0. The paper figures are not labeled with >frequency units because they are applicable to transforms of spacial >sampling as well as temporal sampling.
My only objection, and it's a mild one, to the "bin" terminology is that these is nothing inherent about these window functions that leads one to using a discrete transform either when studying them or when using one; in particular the definition and computaation of a PSD using a window does not involve using a discrete transform, even when the data being analyzed is discrete-time. Specifically, the PSD of a continous time signal is defined at all non-negative real frequencies, and the PSD of a discrete-time signal is defined all frequencies in [0,pi). "bins" suggests (to me) the frequencies being considered are also discrete. Perhaps I am being nit-picky. Steve
On Oct 26, 6:47&#4294967295;pm, spop...@speedymail.org (Steve Pope) wrote:
> ... > > Oops. &#4294967295;Yes, I now remember the objections to referring to the > most commonly used of Nuttall's window as "The Nuttall Window". > I'll avoid this in the future. >
The most commonly used windows in Nuttall's survey are the ones labeled: "Hanning", "Hamming" and "Blackman". Which of these is it that you use? Which of it's parameters would you like to improve and which are you willing to ease of on?
> >In my writeup, the term bin is used to refer to the members of the set > >of basis function correlations calculated in a dft. If you want to use >...
> My only objection, and it's a mild one, to the "bin" terminology > is that these is nothing inherent about these window functions that > leads one to using a discrete transform either when studying them or > when using one; in particular the definition and computaation of a PSD > using a window does not involve using a discrete transform, even when > the data being analyzed is discrete-time. > > Specifically, the PSD of a continous time signal is defined at > all non-negative real frequencies, and the PSD of a discrete-time > signal is defined all frequencies in [0,pi). &#4294967295;"bins" suggests (to me) > the frequencies being considered are also discrete. &#4294967295; > > Perhaps I am being nit-picky.
Perhaps you are confused.
> Steve
Outside of symbolic manipulation, how do -you- calculate a "PSD" of a finite discrete sequence that is not equivalent to a calculation by a discrete transform? Dale B. Dalrymple
>> My only objection, and it's a mild one, to the "bin" terminology >> is that these is nothing inherent about these window functions that >> leads one to using a discrete transform either when studying them or >> when using one; in particular the definition and computaation of a PSD >> using a window does not involve using a discrete transform, even when >> the data being analyzed is discrete-time.
>Outside of symbolic manipulation, how do -you- calculate a "PSD" of a >finite discrete sequence that is not equivalent to a calculation by a >discrete transform?
You slipped the word "finite" in there, right before "discrete". So leave out the "finite". Do you then agree with me? (This is not academic; very typically one computes the PSD of rather long input series.) Steve
>> Oops. &#4294967295;Yes, I now remember the objections to referring to the >> most commonly used of Nuttall's window as "The Nuttall Window". >> I'll avoid this in the future.
>The most commonly used windows in Nuttall's survey are the ones >labeled: "Hanning", "Hamming" and "Blackman". >Which of these is it that you use?
I have used the 4-term window in your "Hamming minimum sidelobe" table, with coefficients: 0.3635819, -0.4891775, 0.1365995, -0.0106411 But I have also used the following similar window coefficients which (at least sometimes) has given me slightly better results relative to my originally stated problem in this thread: 0.355768, -0.487396, 0.144232, -0.012604 Either has been called "Nuttall", in different places.
>Which of it's parameters would you >like to improve and which are you willing to ease of on?
That is what I need to study further, relating my results to the parameters of these windows. Steve
> Perhaps I am being nit-picky. > > Steve
Steve, I don't think you're being nit-picky as there are a number of different spaces and Fourier transform pairs that can be considered very legitimately: continuous / continuous as in "Fourier Transform" discrete / continuous as in Fourier Series taken in the opposite direction but I didn't want to say "inverse Fourier Series" continuous / discrete as in Fourier series. discrete / discrete as in Discrete Fourier Transform. Which expands to: continuous / continuous as in "Fourier Transform" discrete / continuous periodic, infinite as in opposite Fourier Series continuous periodic, infinite / discrete as in Fourier Series. discrete periodic infinite / discrete periodic infinite as in DFT. And: continuous, finite / continuous infinite as in Finite Fourier Transform. continuous, infinite / continuous finite as in inverse Finite Fourier Transform discrete (may be finite) / continuous periodic, infinite as in Discrete (maybe finite) Fourier Transform continuous periodic, infinite / discrete (may be finite) As in Fourier Series discrete periodic infinite / discrete periodic infinite as in Discrete Fourier Transform well .... I hope I got those OK or close enough. So, interestingly I guess, a finite discrete sequence considered initially may only be Fourier Transformed into a continous periodic, infinite function. There is no other option in this context. And your use seems to favor discrete / continous. But, if we decide to *force* the Fourier Transform of a finite discrete sequence to be a Discrete Fourier Transform then we are also forcing the time sequence to be periodic, infinite instead of finite. So, I think Dale's use of "bins" is fine as long as one understands we are talking about: discrete / discrete Both are fine .. if I didn't miss something. Fred
On Oct 26, 7:36&#4294967295;pm, spop...@speedymail.org (Steve Pope) wrote:
> dbd &#4294967295;<d...@ieee.org> wrote: > ... > >Outside of symbolic manipulation, how do -you- calculate a "PSD" of a > >finite discrete sequence that is not equivalent to a calculation by a > >discrete transform? > > You slipped the word "finite" in there, right before "discrete".
The real world enforces the "finite" there. No one has sampled or calculated an infinite data set.
> > So leave out the "finite". &#4294967295; Do you then agree with me? >
Without the "finite" it isn't DSP. You have claimed to describe a calculation you actually intend to perform. That enforces the "finite".
> (This is not academic; very typically one computes the PSD of > rather long input series.)
If you can calculate over the size of the data set, it is finite even if "rather long". It is a characteristic of the DFT of samples of stochastic processes that N does not gracefully approach infinity. Confusing the two is misleading.
> > Steve
Dale B. Dalrymple
On Oct 26, 8:56&#4294967295;pm, spop...@speedymail.org (Steve Pope) wrote:
>... > > I have used the 4-term window in your "Hamming minimum sidelobe" > table, with coefficients: > > 0.3635819, -0.4891775, 0.1365995, -0.0106411
In my "Minimum Sidelobe" table, Hamming is the 2 term entry. Hamming is the 2 term cosine -sum minimum sidelobe window. These coefficients are the 4 term cosine-sum minimum sidelobe window. In a DSP context, "4 term minimum sidelobe window" would probably by clear.
> > But I have also used the following similar window coefficients > which (at least sometimes) has given me slightly better results > relative to my originally stated problem in this thread: > > 0.355768, -0.487396, 0.144232, -0.012604
These are the 4 term cosine-sum continuous 1st derivative window. It sometimes appears abbreviated as "CS4C1D".
So you were aware of the ambiguity and chose to inflict it upon us?
> ... > Steve
Dale B. Dalrymple
> On Oct 26, 7:36&#4294967295;pm, spop...@speedymail.org (Steve Pope) wrote: >> dbd &#4294967295;<d...@ieee.org> wrote:
>> >Outside of symbolic manipulation, how do -you- calculate a "PSD" of a >> >finite discrete sequence that is not equivalent to a calculation by a >> >discrete transform?
> The real world enforces the "finite" there. No one has sampled or > calculated an infinite data set.
Well, you can sample a periodic data set. Most likely that still counts as finite, but one should probably note the difference.
> Without the "finite" it isn't DSP. You have claimed to describe a > calculation you actually intend to perform. That enforces the > "finite".
-- glen
