Fred Marshall <fmarshall_xremove_the_xs@xacm.org> wrote:>On 10/28/2010 6:45 PM, dbd wrote: >Dale, >I do have a little trouble with your treatment of the sliding DFTs in an >analyzer context:>Let's suppose we have streaming input data samples. >Let's suppose the samples are at fs=1.024kHz with sampling interval >.999023438 msec. >Let's suppose we will grab 1,024 samples for a DFT. >So the temporal span of the grab is 0.999023438 seconds and represents >1.000... seconds in a DFT/IDFT temporal period context.>So, the period in time is 1.0000.. seconds and the period in frequency >is 1,024 Hz and the frequency sample interval is 1 Hz.>[snip]>I don't see how there being a 1Hz temporal period implicit in the DFT >nor a 1024 Hz frequency period implicit in the DFT have any impact or >bearing on this..... either the 400Hz is there or it isn't and, yes, it >may fade and one can generate waterfalls, etc. etc. but that really has >nothing to do with the 1024Hz period here. > >But, if the signal component of interest had a period that's longer than >1 second then there are all kinds of things going on that go beyond this >discussion because of aliasing, etc. Your examples were sorta like >this. If the *underlying signal period* is longer than the sample >sequence interval then there will be aliasing and under-resolution.This is one of the reasons you use a window in the first place... to achieve data reduction without (much) aliasing.>For example, if I had 400.5 Hz above then I wouldn't be able to resolve >to 400.5 Hz with the parameters given without computing an estimate. If >noiseless then I might be able to do a reasonable estimate with a single >frequency sequence. If noisy then I might want to have more frequency >sequences to work on. But, the 1Hz limit looms large in this endeavor.This goes back to what I explained earlier: if the analysis being performed is a PSD, then it is well-defined at 400.5 Hz in your example. You can certainly argue that if you've computed PSD(n) for all integers n (in units of Hz), there is no _added_ information to be gained by computing PSD(400.5). But you can't really argue that PSD(400.5), by itself, is any less meaningful than PSD(400) or PSD(401). Steve
help -- Windzilla (high dynamic range windows)
Started by ●October 21, 2010
Reply by ●October 29, 20102010-10-29
Fred Marshall <fmarshall_xremove_the_xs@xacm.org> wrote:> Well, it's clear that we're each stuck on a particular perspective. > I don't think there's anything wrong with your perspective but I believe > it leads to some unfortunate terminology.> When you say "a period", it appears you're referring to actual periodic > content in a signal of some length. That's very understandable and fine.> When I've been saying "a period" in the context of this thread, I'm > referring to the implicit period determined by the number of samples > used in the DFT.Well, you could use a PLL to lock the sampling clock to a multiple of the fundamental frequency of a system being sampled. As an example, to understand the vibrations of a rotating piece of machinery one could measure the position at the appropriate rate. -- glen
On 10/29/2010 1:15 PM, glen herrmannsfeldt wrote:> Fred Marshall<fmarshall_xremove_the_xs@xacm.org> wrote: > >> Well, it's clear that we're each stuck on a particular perspective. >> I don't think there's anything wrong with your perspective but I believe >> it leads to some unfortunate terminology. > >> When you say "a period", it appears you're referring to actual periodic >> content in a signal of some length. That's very understandable and fine. > >> When I've been saying "a period" in the context of this thread, I'm >> referring to the implicit period determined by the number of samples >> used in the DFT. > > Well, you could use a PLL to lock the sampling clock to a > multiple of the fundamental frequency of a system being sampled. > > As an example, to understand the vibrations of a rotating piece > of machinery one could measure the position at the appropriate rate. > > -- glenglen, Yes. I like that trick. What's it got to do with DFTs? Red
Reply by ●October 31, 20102010-10-31
On 10/28/2010 6:58 PM, dbd wrote:> On Oct 28, 4:07 pm, Fred Marshall<fmarshall_xremove_the...@xacm.org> > wrote: >> On 10/27/2010 10:38 PM, dbd wrote: >> >>> No, only the continuous/infinite Fourier Transform (FT) must have a >>> periodicity in one domain to be non-zero only at discrete values in >>> the other domain. >> >> This confuses me. Does this mean that the DFT need not have a >> periodicity in one domain to be non-zero only at discrete values in the >> other domain or what exactly? >> >> I'm not being dense, I just don't get it yet. >> >> Fred > > If the FT has non-zero values at the sample times and zero values in > between sample times the continuous time signal must have been > periodic. Infinitely extending periodicity is what is required for the > intervals between sample times to be zero. In the DFT there are no > values between sample times. There is neither need nor justification > for a periodic constraint. > > Dale B. DalrympleDale, OK. I think I understand what you're saying at least. Sorry it's taken so long to ponder. How about this? N-1 X(k+N) =def= sum [x(n)*e^[(-j*2*pi/N)*(k+N)*n] where k>N-1 n=0 so N-1 X(k+N) = sum x(n) e^[(-j*2*pi/N)*k*n * d^[-j*2*pi] n=0 so N-1 X(k+N) = sum x(n)*e^[-j*2*pi*k*n/N] = X(k) n=0 which is a periodicity property. I guess it depends on how one views the sequences, eh? Just as in *circular convolution*, I view the sequences on a circle (representing the period). I think that's a "need". I find it handy to consider multiple periods on an expanded circle when dealing with things like interpolation/decimation. So, whether I need to do this or not, it helps rather tremendously. The circular representation is just another way of dealing with the periodicity. And, one may "unwrap" a sequence on a circle into a linear, infinite sequence. That's another mapping. So, that's how I justify it. But, I can see another viewpoint: One could envision the sequence being finite on a linear axis. In that case it's just a sequence. And the DFT or IDFT is just a mapping. I don't see anything wrong with that but I don't find it as useful as a model. Is it more general and lends to more insight or less so? Another thing that biases me is this: One can view the DFT as a special case of the FT. Start with the FT. Input a periodic sequence (thus infinite). Observe: with this constraint, the formulation can simplify to the DFT. Thus, given a sequence and a DFT one can generalize it back out to a FT of a periodic sequence. Why deny this relationship? So, there are two apparent models for the DFT and I'm trying to evaluate them. At least I think I'm getting there now..... Thanks for continuing with me! Fred
Reply by ●November 1, 20102010-11-01
On Oct 31, 6:19 am, Fred Marshall <fmarshall_xremove_the...@xacm.org> wrote:>... > > Dale, > > OK. I think I understand what you're saying at least. Sorry it's taken > so long to ponder. > > How about this? > ... > > N-1 > X(k+N) = sum x(n)*e^[-j*2*pi*k*n/N] = X(k) > n=0 > > which is a periodicity property.Yes, in the frequency domain, not the time domain which we have been discussing.> ... > > But, I can see another viewpoint: > One could envision the sequence being finite on a linear axis. In that > case it's just a sequence. And the DFT or IDFT is just a mapping. > I don't see anything wrong with that but I don't find it as useful as a > model. Is it more general and lends to more insight or less so? > > Another thing that biases me is this: > One can view the DFT as a special case of the FT.No, the DFT and the FT are not even defined in the same domains.> Start with the FT. > Input a periodic sequence (thus infinite). > Observe: with this constraint, the formulation can simplify to the DFT. > Thus, given a sequence and a DFT one can generalize it back out to a FT > of a periodic sequence. > Why deny this relationship?Because it isn't a property of the DFT and FT. They are defined in different domains sepatated by the process of sampling, among other things. There -are- signals for which it is true that the DFT of a finite set of samples of the signal will produce a finite set of samples of the FT of the signal. Those signals are periodic -and- the set of samples must span one period of the signal. Few real data sets have this property. Some useful ones are close. Many data sets aren't even in the neighborhood. When we have enough of the data set, we can test for the property. For my examples, perform a DFT of the first 8 samples. Calculate a DFT of the next 8 samples and compare. For the first sequence, the DFTs are the same, so for the region tested, the signal has the property of periodic extension. The next two sequences do not have this property. The second sequence may even represent samples of a signal that continues to grow without limit and does not even have a FT. Yet we can still calculate a DFT of portions of it. The DFT is not a "special case" of the FT. There -are- signals that have properties that can be related across domains. There seem to be a number of people who have been mis-educated into the defective meme that when the DFT has been applied to a set of samples, the signal has been automagically transmografied into having the time domain property of periodic extension. Those possessing the defective meme exhibit an irrepressible knee-jerk reflex to express the assumed periodicity as fact even for data sets where it is demonstably invalid. Perhaps their educators came from the era when the newly advertised DFT was seen as the door to real calculations of the FT, but before the properties and limitations of the DFT were commonly understood and applied. The real world is full of data sets that approximate the property to varying degrees. For a signal consisting of the sum of a periodic component and a stochastic noise component, it is useful for a digital spectrum analyzer to apply Welch's method (WOSA) to reduce the variance of the estimate of the power spectrum of the periodic component. But if the cyclic signal component has a continuing linear FM, the process will smear the power spectrum across frequency. Useful or damaging? It depends on the -data- which model applies, not on the transforms. There are data sets like this where different components require different models. In the real world we can often collect the data to test. Much DSP troubleshooting effort has been wasted of the cases of non-periodic data sets feed to applications that must have periodicity to function to specs and vice versa.> > So, there are two apparent models for the DFT and I'm trying to evaluate > them. At least I think I'm getting there now........ There are processes and applications that may assume the models and there are data sets that consist of components that may or may not exhibit the characteristics of the models. It is the data that determines what the relationship between the FT and DFT of the signal is. I think that number theorists would suggest that the true number of useful models for the DFT is greater than two, but they might not limit their interests to such domains as time. space or frequency. Dale B. Dalrymple
On 11/1/2010 12:59 AM, dbd wrote:> On Oct 31, 6:19 am, Fred Marshall<fmarshall_xremove_the...@xacm.org> > wrote: >> ... >> >> Dale, >> >> OK. I think I understand what you're saying at least. Sorry it's taken >> so long to ponder. >> >> How about this? >> ... >> >> N-1 >> X(k+N) = sum x(n)*e^[-j*2*pi*k*n/N] = X(k) >> n=0 >> >> which is a periodicity property. > > Yes, in the frequency domain, not the time domain which we have been > discussing. > >> ... >> >> But, I can see another viewpoint: >> One could envision the sequence being finite on a linear axis. In that >> case it's just a sequence. And the DFT or IDFT is just a mapping. >> I don't see anything wrong with that but I don't find it as useful as a >> model. Is it more general and lends to more insight or less so? >> >> Another thing that biases me is this: >> One can view the DFT as a special case of the FT. > > No, the DFT and the FT are not even defined in the same domains.***time/frequency are domains. Space/wave number are domains. etc. I guess you mean continuous vs. discrete.> >> Start with the FT. >> Input a periodic sequence (thus infinite). >> Observe: with this constraint, the formulation can simplify to the DFT. >> Thus, given a sequence and a DFT one can generalize it back out to a FT >> of a periodic sequence. >> Why deny this relationship? > > Because it isn't a property of the DFT and FT. They are defined in > different domains sepatated by the process of sampling, among other > things.***I see that I didn't express the thought intended. So, I'll try again: - Start with the FT. - Input a periodic sequence (thus infinite). - Observe: with this constraint, the formulation can simplify to the Fourier's integral over one period (thus *appearing to be finite* but not finite in that sense) to generate the Fourier coefficients. - Observe: with this constraint, the resulting coefficients (sequence) is discrete - perhaps not finite but discrete. AND, vice versa ... one could start with frequency and go to time or from spatial frequency to space, etc. the physical domain isn't the point here. Now, we can take this discrete sequence and reverse the transform using the familiar Fourier Series or IDFT both are discrete sums over the number of coefficients. Nothing limits the IDFT formulation to being finite except how we usually use it - just like the Fourier Series summation. Thus the pair: periodic/discrete. But, that's not very convenient for DSP in a couple of ways. We'd like the sequences to be of limited size (I'll avoid using "finite" here just to avoid confusion but it would be OK) and we'd like to work with discrete samples in both transform domains. So, as in any practical Fourier Series application, we limit the series to some number of terms. That limits the size and doesn't affect the periodicity in the transform domain. We start with a set of coefficients as in a Fourier Series and are able to construct the continuous periodic function. And, this series may be infinite. But, now we want to sample the constructed function. So, we do that, choosing some desirable sample rate. (And here I'm purposefully ignoring aliasing which isn't really to the point right now). When we do this, the Fourier Transform of the samples becomes periodic on fs (and whatever aliasing may be presumed to have occurred, occurs). So, now we have the pair: discrete/periodic Since we started with periodic/discrete, now we have: periodic discrete / periodic discrete. But, so far we haven't dealt with the periodicity in frequency (just to keep some context I use "frequency" here) as far as reconstruction goes. Observing that the frequency samples are now periodic, we can apply a summation over a single period which generates a period's worth of samples in time - which is the IDFT.>There -are- signals for which it is true that the DFT of a > finite set of samples of the signal will produce a finite set of > samples of the FT of the signal. Those signals are periodic -and- the > set of samples must span one period of the signal. Few real data sets > have this property. Some useful ones are close. Many data sets aren't > even in the neighborhood. When we have enough of the data set, we can > test for the property. For my examples, perform a DFT of the first 8 > samples. Calculate a DFT of the next 8 samples and compare. For the > first sequence, the DFTs are the same, so for the region tested, the > signal has the property of periodic extension. The next two sequences > do not have this property. The second sequence may even represent > samples of a signal that continues to grow without limit and does not > even have a FT. Yet we can still calculate a DFT of portions of it. > The DFT is not a "special case" of the FT. There -are- signals that > have properties that can be related across domains.***Yes. I agree with that but I don't see where it gets to.> > There seem to be a number of people who have been mis-educated into > the defective meme that when the DFT has been applied to a set of > samples, the signal has been automagically transmografied into having > the time domain property of periodic extension. Those possessing the > defective meme exhibit an irrepressible knee-jerk reflex to express > the assumed periodicity as fact even for data sets where it is > demonstably invalid. Perhaps their educators came from the era when > the newly advertised DFT was seen as the door to real calculations of > the FT, but before the properties and limitations of the DFT were > commonly understood and applied. >***Ad hominem arguments fall flat. ***Well, I don't think that I'd ever suggested any automagic transmogrification. That a signal may have some periodic character and that a transform may introduce some periodic character in an anlytical sense are, to me, two entirely different things. And, I tried to say that earlier - that the underlying signal is of no consequence here. But, you've suggested the opposite. Just sample a signal at pi Hz for 1 second. The underlying signal has a period of 1/pi and the transform has a period of 1 second. Never the twain shall meet for sample lengths that are an integer number of seconds long (except in a practical sense if the number of samples is large enough and such that "K seconds" nearly meets an integral number of periods of 1/pi).> The real world is full of data sets that approximate the property to > varying degrees. For a signal consisting of the sum of a periodic > component and a stochastic noise component, it is useful for a digital > spectrum analyzer to apply Welch's method (WOSA) to reduce the > variance of the estimate of the power spectrum of the periodic > component. But if the cyclic signal component has a continuing linear > FM, the process will smear the power spectrum across frequency. Useful > or damaging? It depends on the -data- which model applies, not on the > transforms. There are data sets like this where different components > require different models. In the real world we can often collect the > data to test. Much DSP troubleshooting effort has been wasted of the > cases of non-periodic data sets feed to applications that must have > periodicity to function to specs and vice versa. > >> >> So, there are two apparent models for the DFT and I'm trying to evaluate >> them. At least I think I'm getting there now..... > ... > > There are processes and applications that may assume the models and > there are data sets that consist of components that may or may not > exhibit the characteristics of the models. It is the data that > determines what the relationship between the FT and DFT of the signal > is.***OK but I wasn't trying to relate the signal at all. Just properties of the transform.> > I think that number theorists would suggest that the true number of > useful models for the DFT is greater than two, but they might not > limit their interests to such domains as time. space or frequency. > > Dale B. DalrympleI'm not saying that there aren't pitfalls in anything we do. Once I was building a sound source that was supposed to sound like a machine. So, we recorded some of the machine sound and put it into one of those "new" digital shift-register memories to play it in an endless loop. All we had to do was match up the ends (like matching the time span of samples of a periodic signal). Oh! But oops. The length of the memory was too short and the resulting spectral analysis looked like a herringbone. I think we need to use models that are meaningful for each of us. I'll leave it at that. Fred
On Nov 1, 10:54�am, Fred Marshall <fmarshall_xremove_the...@xacm.org> wrote:> On 11/1/2010 12:59 AM, dbd wrote: > ... > > > There seem to be a number of people who have been mis-educated into > > the defective meme that when the DFT has been applied to a set of > > samples, the signal has been automagically transmografied into having > > the time domain property of periodic extension. Those possessing the > > defective meme exhibit an irrepressible knee-jerk reflex to express > > the assumed periodicity as fact even for data sets where it is > > demonstably invalid. Perhaps their educators came from the era when > > the newly advertised DFT was seen as the door to real calculations of > > the FT, but before the properties and limitations of the DFT were > > commonly understood and applied. > > ***Ad hominem arguments fall flat.This is an observation on the nature of some discussions on usenet and elsewhere. The fact that you recognize that there exists a linear arrangement of data that might be of some use indicates that it doesn't apply to you.> > ***Well, I don't think that I'd ever suggested any automagic > transmogrification.You haven't.>�That a signal may have some periodic character and > that a transform may introduce some periodic character in an anlytical > sense are, to me, two entirely different things. �That is a rare distinction and much appreciated. I was pointing out the difference between you interpretation and another common one. Dale B. Dalrymple
Reply by ●November 2, 20102010-11-02
On Nov 1, 11:13 am, Fred Marshall <fmarshall_xremove_the...@xacm.org> wrote:> On 11/1/2010 12:59 AM, dbd wrote: > > > On Oct 31, 6:19 am, Fred Marshall<fmarshall_xremove_the...@xacm.org> > > wrote: > >> ... > ...> >> Another thing that biases me is this: > >> One can view the DFT as a special case of the FT. > > > No, the DFT and the FT are not even defined in the same domains. > ... > I guess you mean continuous vs. discrete.Yes.> > >> Start with the FT. > >> Input a periodic sequence (thus infinite).This is the key point, you must chose a periodic sequence to demonstrate the relationship.> >> Observe: with this constraint, the formulation can simplify to the DFT. > >> Thus, given a sequence and a DFT one can generalize it back out to a FT > >> of a periodic sequence. > >> Why deny this relationship? > > > Because it isn't a property of the DFT and FT. They are defined in > > different domains separated by the process of sampling, among other > > things.I see that I didn't express the thought intended. I agree with the property of periodic signals. I deny that the relationship is a characteristic of the DFT and FT. It is necessary for you to assume signals that have a special relationship between discrete and continuous domains to even present the argument.> > ***I see that I didn't express the thought intended. So, I'll try again: > - Start with the FT. > - Input a periodic sequence (thus infinite).Again, as you correctly state, you must use a periodic sequence.> ... > Observing that the frequency samples are now periodic, we can apply a > summation over a single period which generates a period's worth of > samples in time - which is the IDFT.What do you mean "now periodic"?!!? You assumed the signal periodic in the first place. Your reasoning is circular. You have demonstrated your assumption.> > It is the data that > > determines what the relationship between the FT and DFT of the signal > > is. > > ***OK but I wasn't trying to relate the signal at all. Just properties > of the transform. >But in each case you do "relate to the signal" by specifying a periodic signal. Properties of the transform are independent of the signal. The property we are discussing is not independent of the signal, so it is not a property of the transform. I'm not denying the property (of periodic signals), I'm claiming that the describing the property as a characteristic of the transforms has mislead many people who fail to carry along the necessary initial assumption of periodicity. It is the people who have forgotten, or never been taught, about the limitation of the property to the periodic assumption who have been mis-educated. It is these people that I pointed out the existence of in my first post on Nov. 1. Dale B. Dalrymple
On 11/2/2010 10:59 AM, dbd wrote:> On Nov 1, 11:13 am, Fred Marshall<fmarshall_xremove_the...@xacm.org> > wrote: >> On 11/1/2010 12:59 AM, dbd wrote: >> >>> On Oct 31, 6:19 am, Fred Marshall<fmarshall_xremove_the...@xacm.org> >>> wrote: >>>> ... >> ... > >>>> Another thing that biases me is this: >>>> One can view the DFT as a special case of the FT. >> >>> No, the DFT and the FT are not even defined in the same domains. >> ... >> I guess you mean continuous vs. discrete. > > Yes. > >> >>>> Start with the FT. >>>> Input a periodic sequence (thus infinite). > > This is the key point, you must chose a periodic sequence to > demonstrate the relationship. > >>>> Observe: with this constraint, the formulation can simplify to the DFT. >>>> Thus, given a sequence and a DFT one can generalize it back out to a FT >>>> of a periodic sequence. >>>> Why deny this relationship? >> >>> Because it isn't a property of the DFT and FT. They are defined in >>> different domains separated by the process of sampling, among other >>> things. > > I see that I didn't express the thought intended. I agree with the > property of periodic signals. I deny that the relationship is a > characteristic of the DFT and FT. It is necessary for you to assume > signals that have a special relationship between discrete and > continuous domains to even present the argument. > >> >> ***I see that I didn't express the thought intended. So, I'll try again: >> - Start with the FT. >> - Input a periodic sequence (thus infinite). > > Again, as you correctly state, you must use a periodic sequence. > >> ... >> Observing that the frequency samples are now periodic, we can apply a >> summation over a single period which generates a period's worth of >> samples in time - which is the IDFT. > > What do you mean "now periodic"?!!? You assumed the signal periodic in > the first place. Your reasoning is circular. You have demonstrated > your assumption. > >>> It is the data that >>> determines what the relationship between the FT and DFT of the signal >>> is. >> >> ***OK but I wasn't trying to relate the signal at all. Just properties >> of the transform. >> > > But in each case you do "relate to the signal" by specifying a > periodic signal. Properties of the transform are independent of the > signal. The property we are discussing is not independent of the > signal, so it is not a property of the transform. > > I'm not denying the property (of periodic signals), I'm claiming that > the describing the property as a characteristic of the transforms has > mislead many people who fail to carry along the necessary initial > assumption of periodicity. It is the people who have forgotten, or > never been taught, about the limitation of the property to the > periodic assumption who have been mis-educated. It is these people > that I pointed out the existence of in my first post on Nov. 1. > > Dale B. Dalrymple >Dale, You make some great points! I'll have to ponder this further. I sure hope this isn't leading us into one of those silly arguments about delta functions!! I'm a believer. Maybe that's why I relate the FT and DFT so readily? I do view them rather as "the same thing", if you will, because the integrals become sums going from continous to discrete and one can approach this in a "limit" sense, no? Is that agreeable at least? If not, then one would have to be able to argue that the discrete versions with sums have some special properties - is that reasonable? But, OK. I'll try to paraphrase what we're saying: I've said that discrete finite sequences (and I'll say now "arbitrary sequences" to get away from any underlying signal periodicity issue), connected by a DFT, have a periodicity property that is assumed or implied or .... (Well, of course, only the initial sequence can be arbitrary and the other follows from the transform - chicken and egg). You've said that the periodicity assumption is unnecessary and "harmful"? I don't want to put words in your mouth here. I guess I'm biased by the z transform approach to things where frequency is represented on a circle rather than a straight line. And, I carry that notion into DFTs as well. And, I find it handy to do so. I agree that one can view the sequence pair associated by a DFT as a pair of strictly finite sequences. That seems an abstraction to me but OK - I can't say the perspective is invalid for some reason. But, I don't view it as being very useful. On the other hand, viewing each sequence in the pair as representing a single period of an infinite, periodic sequence does seem useful. Again, this has nothing to do with the particular sequences which can be arbitrary. And, the two can be tied together by a simple mapping. If I have a function or sequence in x on a linear scale, I can map it to r on a circular scale using r=sin(x). And, as long as we're clear that the linear scale contains only finite sequences such that [0 <= x <= 2pi) so that (-1 <+ r <= +1] (or some scaled versions thereof) then dealing with the finite sequences on a linear scale or dealing with them on a circular scale amounts to the same thing. Then, if one wants to do things like sample rate conversion, either one visualization (er... mapping) or the other might be handy. So, I guess I've been stuck on the circular version in this thread (even though in my mind's eye it's projected onto a linear scale) and that's about all there is to it. I shouldn't have been so pedantic to insist that it is the only way to look at it. Fred
