I understand that the magnitude of the frequency response of an FIR filter is the intersection of a tube going down through the unit circle with the curvaceous surface created by the placement of the zeros of its roots. Is there also a simple visualization of the phase of the frequency response that's related to the zero placement? Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
FIR roots and frequency response
Started by ●February 13, 2004
Reply by ●February 13, 20042004-02-13
In article c0hi5b083c@enews2.newsguy.com, Bob Cain at arcane@arcanemethods.com wrote on 02/12/2004 23:00:> > I understand that the magnitude of the frequency response of > an FIR filter is the intersection of a tube going down > through the unit circle with the curvaceous surface created > by the placement of the zeros of its roots.wow! that's a weird, errr interesting way to look at it!> Is there also a simple visualization of the phase of the > frequency response that's related to the zero placement?for magnitude, i would multiply the distance that e^(jw) is to each zero (screw the poles since they all be at the origin) and for phase, add up the angle of the difference "vectors" that connect each zero to e^(jw). that's the only visualization i can do. r b-j
robert bristow-johnson wrote:> In article c0hi5b083c@enews2.newsguy.com, Bob Cain at > arcane@arcanemethods.com wrote on 02/12/2004 23:00: > > >>I understand that the magnitude of the frequency response of >>an FIR filter is the intersection of a tube going down >>through the unit circle with the curvaceous surface created >>by the placement of the zeros of its roots. > > > wow! that's a weird, errr interesting way to look at it!Is it accurate, though, and equivalent to what you give for it below? That equivalence isn't obvious to my visualizer.> > >>Is there also a simple visualization of the phase of the >>frequency response that's related to the zero placement? > > > for magnitude, i would multiply the distance that e^(jw) is to each zero > (screw the poles since they all be at the origin) and for phase, add up the > angle of the difference "vectors" that connect each zero to e^(jw). that's > the only visualization i can do.Do you mean for each point on the unit circle add up the angles of all the vectors joining it to the zeros? I'm trying to visualize how reflecting a zero from outside to inside the unit circle causes the phase function to become closer to zero everywhere. Actually I'm trying to understand just what it is that's minimized in minimum phase filters. If that's not it, please enlighten me. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
"robert bristow-johnson" <rbj@surfglobal.net> wrote in message news:BC51BE50.88A4%rbj@surfglobal.net...> In article c0hi5b083c@enews2.newsguy.com, Bob Cain at > arcane@arcanemethods.com wrote on 02/12/2004 23:00: > > > > > I understand that the magnitude of the frequency response of > > an FIR filter is the intersection of a tube going down > > through the unit circle with the curvaceous surface created > > by the placement of the zeros of its roots.Well, not exactly I think ... and the answer ties the phase question into it: Consider a family of frequency response vectors with orgin on each point of the unit circle and perpendicular to the unit circle. Each vector is then free to rotate about the unit circle. What's necessary is to define what the third dimension represents ... and I suppose we're free, for the moment, to make a choice. I just realized that this is easier for me to do in s-plane rather than z-plane space so let me do that first.... Envision a family of frequency response vectors with orgin on each point of the jw axis and perpendicular to the jw axis. Each vector is then free to rotate about the jw axis. What's necessary is to define what the third dimension represents ... and I suppose we're free, for the moment, to make a choice. Let's say that the real part of the vector is in the direction of "w" (which is perpendicular to the jw axis) and the imaginary part is in the new 3rd dimension we've created. The magnitude response is the magnitude of the vector. The phase response is the phase of the vector. Now, let the end points of all the vectors connect into a continuum. What you have is a sort of spiral of varying diameter (the magnitude). For example, a linear phase FIR filter will have constant angular change with frequency, so the vector rotates at a constant rate with frequency (i.e. along the jw axis). But, the magnitude, and thus the diameter of the spiral, is free to change. If you cut the jw axis with a plane, that's equivalent to cutting the z-plane unit circle with a tube. Since we selected the 3rd dimension to be the imaginary part, then the vectors project the imaginary part onto this plane. This projection isn't the magnitude - it's the imaginary part. Eventually we'll want to re-map from jw to z and we'll find the same thing except the magnitude of the vector has to be mapped to match the circular nature of the z-plane unit circle "axis". That's a good exercise for the student..... :-) Now, I can imagine there might be another mapping or assignment of dimensions that could work more along the lines you've stated (BTW, where did you get this?) but I'm hard pressed to see how a simple projection onto a plane or a tube (respectively) can yield magnitude - because magnitude isn't represented here anywhere. Let's get back to the idea of a tube: The magnitude response *specification* for a filter is a "tube" of varying diameter that surrounds the jw axis or a distorted one that surrounds the z-plane unit circle. If the magnitude response specificaton is |1.0|, then the tube has diameter of 1.0 I guess. If the magnitude response specification is < 0.000001 then the tube has a very small diameter. Something like that. If the phase specification is given then it will give the angle of the vector. Something concerns me about scaling in the z-plane here...... but I think it works otherwise. So, an all-pass filter specification, with no phase response spec, is a tube with constant diameter of 1.0 in the s-plane. The actual filter response approximates this perfect tube with a wiggly-diameter spiral that can change direction of rotation. Oh... Maybe you were thinking that the real part of the frequency response could be projected on that unit circle tube. It could. Maybe you were thinking that a *symmetric* FIR filter has only real response - which it does. And, maybe you were thinking that a symmetric FIR filter with no zeros, or only even ordered multiple zeros, on the unit circle will have only a positive real response - which it can have with a usually trivial constraint that the sum of the coefficients is positive rather than negative (a simple sign change on all of them). In that case, then plotting the real part onto the new 3rd dimension will project the magnitude onto the tube. If there are odd-ordered zeros on the unit circle then you will have to take the magnitude of the negative values - so the more general statement doesn't work does it? So, I backed into it.... and it only applies to the more narrowly defined case: Symmetric, real, FIR with no odd-ordered zeros on the unit circle. The placement of poles or other zeros doesn't matter - as long as it's a symmetric FIR filter. They are constrained by that structure of course so that the poles are at the orgin and the zeros are in complex conjugate pairs and those pairs are in reciprocal pairs to form quads. I think that's all correct..... Fred
Fred Marshall wrote: ...> I just realized that this is easier for me to do in s-plane rather than > z-plane space so let me do that first....Yes. See "Spirule" Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
In article <c0holl016fs@enews1.newsguy.com>, Bob Cain <arcane@arcanemethods.com> wrote:>>>I understand that the magnitude of the frequency response of >>>an FIR filter is the intersection of a tube going down >>>through the unit circle with the curvaceous surface created >>>by the placement of the zeros of its roots....>>>Is there also a simple visualization of the phase of the >>>frequency response that's related to the zero placement?...>I'm trying to visualize how reflecting a zero from outside >to inside the unit circle causes the phase function to >become closer to zero everywhere. Actually I'm trying to >understand just what it is that's minimized in minimum phase >filters. If that's not it, please enlighten me.The location of both the poles and the zeros is important. Imagine a crank handle at the location of every pole or zero on the complex plane. These crank handles are attached to rotation counters (funny counters that count by 2*pi instead of just once per revolution). The counters count up for zeros, but count down for poles. Every crank handle is automated to aim at where you are standing on the a unit circle (perhaps operated by little demons who are tired of playing with all those doors over in the thermodynamics lab). First consider a single pole or zero. If it's inside the unit circle then the counter will count up or down an entire 2*pi every time you complete a walk around the entire circle. If the pole or zero is outside the unit circle (say far away) then the handle may only wiggle back and forth, but never move in a complete revolution, no matter how many times you walks around in unit circles. Consider not just one pole or zero, but the sum of several. Say you are plotting the sum of all the rotation counters on the cylinder wall as you take a walk around the unit circle. Unless you have a handy time machine, all the poles will be inside the unit circle. So for every trip around, the sum will go down by 2*pi*number_of_poles. If all the zeros are also inside the unit circle the the sum will go up by 2*pi*number_of_zeros. If the the number of poles is the same as the number of zeros, then the sum will be zero after a round trip, which is usually considered a fairly small value. But if some of the zeros are outside the unit circle, and you have the same number of zeros as poles (why?), then the sum of the positive and negative counters will not cancel after one round trip. The sum will continue to diverge as you walk around and around the unit circle, and you will eventually need a ladder to keep plotting points. For some reason, this ever-rising curve is unlikely to be called "minimum". An interesting question might be whether, if you actually came across a working handy-dandy (z^+1) time machine, and could move some of the poles outside the unit circle, would a minimum phase design also require moving an equal number of zeros outside? Whether or not these demons standing on a complex plane and operating funny crank handles with counters attached has anything to do with frequency response, and if so under what conditions, is left as an exercise for the student. IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
Ronald H. Nicholson Jr. wrote: ...> Whether or not these demons standing on a complex plane and operating > funny crank handles with counters attached has anything to do with > frequency response, and if so under what conditions, is left as an > exercise for the student. > > > IMHO. YMMV.Nifty! -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●February 15, 20042004-02-15
Bob Cain wrote:> I understand that the magnitude of the frequency response of > an FIR filter is the intersection of a tube going down > through the unit circle with the curvaceous surface created > by the placement of the zeros of its roots.With the surface defined by the modulus of the complex value assigned to each point in the z-plane, yes. Since few are able to imagine objects of the four spatial dimensions the actual situation calls for, something's got to give. Fred threw out the real direction of the s-plane to make room for his spirals; you kept that over the response's phase component. Your choice is in line with the answer to your question -- with practice in using the sum-of-angles rule Robert stated, one may do reasonably well. But IMHO it's not going to get as intuitive as for magnitude. Incidentally, note that Robert's rules simply break down the complex product that is the factored form of the FIR transfer function. I did a little experiment just to convince myself that you might want to carry further. I plotted magnitude and phase response of a few filters with one through three spaced, conjugate zero pairs. The magnitudes are rather well-behaved, as you know -- just seeing some plots quickly enables one to predict what moving the zeros around will do. Now, each zero introduces a phase jump (of pi, at its frequency, when the radius is unity), but whether it will be up or down and exactly how the pieces look is hardly deducible from my few examples. Still, further experimentation could lead to more of a gut feel there. Martin -- Please help refine my English usage! -= Send your critique by email. =- Quidquid latine dictum sit, altum viditur.
"Martin Eisenberg" <martin.eisenbergNOS@PAMudo.edu> wrote in message news:1076894877.106551@ostenberg.wh.uni-dortmund.de...> Bob Cain wrote: > > > I understand that the magnitude of the frequency response of > > an FIR filter is the intersection of a tube going down > > through the unit circle with the curvaceous surface created > > by the placement of the zeros of its roots. > > With the surface defined by the modulus of the complex value assigned > to each point in the z-plane, yes. Since few are able to imagine > objects of the four spatial dimensions the actual situation calls > for, something's got to give. Fred threw out the real direction of > the s-plane to make room for his spirals;Well, I don't think I "threw it out", I rather thought that I'd superimposed... Fred
Reply by ●February 16, 20042004-02-16
In article c0holl016fs@enews1.newsguy.com, Bob Cain at arcane@arcanemethods.com wrote on 02/13/2004 00:51:> robert bristow-johnson wrote: > >> In article c0hi5b083c@enews2.newsguy.com, Bob Cain at >> arcane@arcanemethods.com wrote on 02/12/2004 23:00: >> >> >>> I understand that the magnitude of the frequency response of >>> an FIR filter is the intersection of a tube going down >>> through the unit circle with the curvaceous surface created >>> by the placement of the zeros of its roots. >> >> >> wow! that's a weird, errr interesting way to look at it! > > Is it accurate, though, and equivalent to what you give for > it below? That equivalence isn't obvious to my visualizer. > >> >> >>> Is there also a simple visualization of the phase of the >>> frequency response that's related to the zero placement? >> >> >> for magnitude, i would multiply the distance that e^(jw) is to each zero >> (screw the poles since they all be at the origin) and for phase, add up the >> angle of the difference "vectors" that connect each zero to e^(jw). that's >> the only visualization i can do. > > Do you mean for each point on the unit circle add up the > angles of all the vectors joining it to the zeros?yes and you do the same for the poles but subtract all of those angles.> I'm trying to visualize how reflecting a zero from outside > to inside the unit circle causes the phase function to > become closer to zero everywhere.it's a lot easier visualizing it on the s-plane for continuous-time LTI systems ( arg(jw-q) < arg(jw+q) for q<0 and real ) but i think it's true for the z-plane, too. i can think of a round-about justification of that by using the previous result for the s-plane and the BiLinear Transform and warped frequency mapping of the BLT. do you want me to go through the hand waving?> Actually I'm trying to > understand just what it is that's minimized in minimum phase > filters. If that's not it, please enlighten me.oh, it is it. this is much easier to see for the s-plane. given a particular magnitude response that can be attained with poles and zeros in the s-plane, the only "constellations" of poles and zeros that will give you *that* particular magnitude response (let's not consider different constant gain factors) is the set of constellations that have the poles and zeros in some position or in reflections about the jw axis. of course poles must be in the left-half plane so they can't be reflected to the other side of the jw axis. but zeros can. but if they are reflected from the left-hand plane to the right-hand plane, you can see that their angle will always be greater than 90 degrees whereas they were always less than 90 degrees before. so to get the smallest set of angles on those zeros, you gotta have them all in the left-half plane. now if you consider the BiLinear Transform and the frequency warping property of it, for some continuous-time filter with poles and zeros in the s-plane, there is an equal order discrete-time filter with the same number of poles and zeros in the z-plane. (if the original number of zeros was less than the number of poles, then those "missing" zeros get mapped to z=-1 in the z-plane. think of them as zeros out at s=-inf.) now the frequency warping property says that the discrete-time filter will have exactly the same frequency response (that is the same magnitude and phase) BUT AT DIFFERENT FREQUENCIES defined by that arctan() relationship. so that means if, at some frequency, reflecting some s-plane zero to the right-half plane increases the phase angle, then, at some other frequency, reflecting the corresponding z-plane zero to outside the unit circle will do the same and increase the phase angle. does that do it, Bob? r b-j I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output I am universally the best MIDI output
