Hi, I am a newbie to DSP and I hope to get some help related to the following issue: Suppose I have a sampled voltage signal (sampled at fs=6400Hz): x(t)=sin(2*pi*f*t)+0.5*sin(11.4*2*pi*f*t) ... f=50Hz, t=0:0.02/128:0.02 If I take a FFT over 10 periods I will be able to find the frequency (570Hz), amplitude (0.5V) and phase (0rad) of my harmonic. The problem is to find the same components from only one period. The FFT spectrum produces leakage due to the noninteger harmonic (interharmonic) and the method that I found (which I do not understand completely unfortunately) is based on the Newton-Raphson root finding algorithm. The signal is first windowed in the time domain with a 128 samples hanning window f(t)=x(t).w(t) and F=FFT(f(t)) The algorithm takes 3 complex points from the spectrum : F[n-1] (at 500 Hz), F[n] (550 Hz) and F[n+1] (600Hz) where F[n] is the peak and the following formula is given : http://img21.imageshack.us/img21/4129/formulab.jpg fn is and initial guess frequency w is the hanning complex window. w* denotes the complex conjugate Could someone please help me understand how was that formula built. I actually found it in a Labview example (Complex Multi-tone Measurements.vi) After having G(f), the problem is easy : a simple loop that would update the guess frequency by: f[n+1]=f[n]-G(f[n])/G'(f[n]) Any help is greatly appreciated. Thanks. Daniel
spectral estimation algorithm
Started by ●October 25, 2010
Reply by ●October 26, 20102010-10-26
On Oct 25, 10:29=A0am, "dani_sb" <dan1_sb@n_o_s_p_a_m.yahoo.com> wrote:> Hi, > > I am a newbie to DSP and I hope to get some help related to the following > issue: > > Suppose I have a sampled voltage signal (sampled at fs=3D6400Hz): > > x(t)=3Dsin(2*pi*f*t)+0.5*sin(11.4*2*pi*f*t) ... f=3D50Hz, t=3D0:0.02/128:=0.02> > If I take a FFT over 10 periods I will be able to find the frequency > (570Hz), amplitude (0.5V) and phase (0rad) of my harmonic. The problem is > to find the same components from only one period. > > The FFT spectrum produces leakage due to the noninteger harmonic > (interharmonic) and the method that I found (which I do not understand > completely unfortunately) is based on the Newton-Raphson root finding > algorithm. > The signal is first windowed in the time domain with a 128 samples hannin=g> window f(t)=3Dx(t).w(t) and F=3DFFT(f(t)) > The algorithm takes 3 complex points from the spectrum : F[n-1] (at 500 > Hz), F[n] (550 Hz) and F[n+1] (600Hz) where F[n] is the peak and the > following formula is given : > > http://img21.imageshack.us/img21/4129/formulab.jpg > > fn is and initial guess frequency w is the hanning complex window. w* > denotes the complex conjugate > > Could someone please help me understand how was that formula built. > I actually found it in a Labview example (Complex Multi-tone > Measurements.vi) > > After having G(f), the problem is easy : a simple loop that would update > the guess frequency by: > > f[n+1]=3Df[n]-G(f[n])/G'(f[n]) > > Any help is greatly appreciated. =A0Thanks. > > DanielI Googled it a little bit, but couldn't find a description of the exact algorithm they're using. I think it involves a quadratic fit, based on the info I found below: http://zone.ni.com/devzone/cda/tut/p/id/3770 http://lavag.org/topic/11240-waveform-peak-detection-vi-bogus-numbers/ I don't know offhand how the equations provided in your link relate to what they're doing because I don't know how all the terms are defined. But it's easy to see that the equation for G(f) is just a reordering of the ratios above it. For the ratios shown, just multiply both sides with the product of the two denominators; you end up with G(f). Now if you let k =3D 0 and M =3D 3, you can see that the indexing works out. I think the Gprime term is a derivative, but I'm not sure. And I don't know why they're using the conjugate of the window (cross-correlation perhaps?). And the denominator terms at the top of the page certainly looks like a scaling factor. I think the 'iterate on the guess' part of their algorithm is due to the Newton- Raphson method. At any rate, there are a lot of ways of interpolating between FFT bins to estimate the location of a spectral peaks. You might, for example, consider using: https://ccrma.stanford.edu/~jos/sasp/Quadratic_Interpolation_Spectral_Peaks= .html At least it comes with and explanation. There is a significantly better method using a Gaussian ratio: http://www.edn.com/archives/1994/030394/05df1.htm It's several orders of magnitude more accurate than other methods. I've used it for many years and developed a lot of new things with it (e.g.: subtracting estimates from the raw data to 'unmask' the presence of weaker tones, using a more accurate Gaussian window, re- deriving the equations to allow for arbitrary bin spacing, estimating the rate of change of non-stationary signals, etc.). I devote some 30+ pages to it in a book I wrote, and that represents a lot of my time and effort. So I'm kind of reluctant to post any of that here. But I think you'll find that if you follow the example and code in the above, you could probably get it right. Maybe you'd try the Quadratic approach first, after which you can try the Gaussian. Kevin McGee
dani_sb wrote:> Hi, > > I am a newbie to DSP and I hope to get some help related to the following > issue: > > Suppose I have a sampled voltage signal (sampled at fs=6400Hz): > > x(t)=sin(2*pi*f*t)+0.5*sin(11.4*2*pi*f*t) ... f=50Hz, t=0:0.02/128:0.02 > > If I take a FFT over 10 periods I will be able to find the frequency > (570Hz), amplitude (0.5V) and phase (0rad) of my harmonic. The problem is > to find the same components from only one period. > > The FFT spectrum produces leakage due to the noninteger harmonic > (interharmonic) and the method that I found (which I do not understand > completely unfortunately) is based on the Newton-Raphson[...] Don't take FFT and don't do that Newton-Raphson nonsense, especially if you don't understand what it does. There is approximately a zillion of ways to accomplish the result depending on what exactly the signal is and what do you need.> Any help is greatly appreciated. Thanks.Does your great appreciation imply any real content, or is it purely imaginary? VLV
>I don't know offhand how the equations provided in your link relate to >what they're doing because I don't know how all the terms are >defined. But it's easy to see that the equation for G(f) is just a >reordering of the ratios above it. For the ratios shown, just >multiply both sides with the product of the two denominators; you end >up with G(f). Now if you let k =3D 0 and M =3D 3, you can see that the >indexing works out. I think the Gprime term is a derivative, but I'm >not sure. And I don't know why they're using the conjugate of the >window (cross-correlation perhaps?). And the denominator terms at the >top of the page certainly looks like a scaling factor. I think the >'iterate on the guess' part of their algorithm is due to the Newton- >Raphson method.The G prime term is indeed a derivative (it comes from the Newton-Raphson algorithm - which I do understand how it works). The cross correlation might have a sense because I found out that the FFT spectrum is previously shifted. I did some further reading on this topic and the issue equation (the one with the ratios) might be related to Parseval's equality which i found in another topic here : http://www.dsprelated.com/showmessage/34956/1.php>Parseval's equality tells us >the sum of the squared time sequence is related to >the sum of the squared (magnitude) of the fourier sequence >by a constant factor > >i.e. > >sum( abs(x).^2 ) == K * sum( abs(fft(x)).^2 ) > >where K depends on the fft algorithm, and the length of the dft. > >-- Markabs(fft(x)).^2 would be the squared magnitude of the FFT spectrum and so if my harmonic component "energy" is distributed in 3 fft bins (mag1) it should have an equivalent distribution in 2 bins (mag2). The K might be the denominator inverse since it's a constant value. K1 * sum( mag1.^2 )=K2 * sum( mag2.^2 ) (looks a bit like the first equation - but I'm not sure)> >At any rate, there are a lot of ways of interpolating between FFT bins >to estimate the location of a spectral peaks. You might, for example, >consider using: > >https://ccrma.stanford.edu/~jos/sasp/Quadratic_Interpolation_Spectral_Peaks= >.html > >At least it comes with and explanation. > >There is a significantly better method using a Gaussian ratio: > >http://www.edn.com/archives/1994/030394/05df1.htm > >It's several orders of magnitude more accurate than other methods. >I've used it for many years and developed a lot of new things with it >(e.g.: subtracting estimates from the raw data to 'unmask' the >presence of weaker tones, using a more accurate Gaussian window, re- >deriving the equations to allow for arbitrary bin spacing, estimating >the rate of change of non-stationary signals, etc.). I devote some >30+ pages to it in a book I wrote, and that represents a lot of my >time and effort. So I'm kind of reluctant to post any of that here. > >But I think you'll find that if you follow the example and code in the >above, you could probably get it right. Maybe you'd try the Quadratic >approach first, after which you can try the Gaussian. > >Kevin McGee >I will first try to implement the Quadratic approach which looks quite good. Further on this topic I have a new question: If my initial sampled signal would have two close harmonics, i.e. x(t)=sin(2*pi*f*t)+0.5*sin(11.4*2*pi*f*t)+0.3*sin(11*2*pi*f*t), is there any method to identify both harmonics from one cycle? (to me it looks a bit unlikely since both harmonics are spread in the same frequency bins) Thanks a lot ! Daniel
> >Don't take FFT and don't do that Newton-Raphson nonsense, especially if >you don't understand what it does. There is approximately a zillion of >ways to accomplish the result depending on what exactly the signal is >and what do you need. >I will try other methods ... Thanks>> Any help is greatly appreciated. Thanks. > >Does your great appreciation imply any real content, or is it purely >imaginary? >The content is Complex. (So it might include some real part too.) Daniel
dani_sb wrote:> >>>Any help is greatly appreciated. Thanks. >> >>Does your great appreciation imply any real content, or is it purely >>imaginary? > > The content is Complex. (So it might include some real part too.)My contact is at the web site in the signature. Please come up with the detailed description of the problem and what should be accomplished. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Oct 25, 7:29�am, "dani_sb" <dan1_sb@n_o_s_p_a_m.yahoo.com> wrote:> Hi, > > I am a newbie to DSP and I hope to get some help related to the following > issue: > > Suppose I have a sampled voltage signal (sampled at fs=6400Hz): > > x(t)=sin(2*pi*f*t)+0.5*sin(11.4*2*pi*f*t) ... f=50Hz, t=0:0.02/128:0.02 > > If I take a FFT over 10 periods I will be able to find the frequency > (570Hz), amplitude (0.5V) and phase (0rad) of my harmonic. The problem is > to find the same components from only one period. > > The FFT spectrum produces leakage due to the noninteger harmonic > (interharmonic) and the method that I found (which I do not understand > completely unfortunately) is based on the Newton-Raphson root finding > algorithm. > The signal is first windowed in the time domain with a 128 samples hanning > window f(t)=x(t).w(t) and F=FFT(f(t)) > The algorithm takes 3 complex points from the spectrum : F[n-1] (at 500 > Hz), F[n] (550 Hz) and F[n+1] (600Hz) where F[n] is the peak and the > following formula is given : > > http://img21.imageshack.us/img21/4129/formulab.jpg > > fn is and initial guess frequency w is the hanning complex window. w* > denotes the complex conjugate > > Could someone please help me understand how was that formula built. > I actually found it in a Labview example (Complex Multi-tone > Measurements.vi) > > After having G(f), the problem is easy : a simple loop that would update > the guess frequency by: > > f[n+1]=f[n]-G(f[n])/G'(f[n]) > > Any help is greatly appreciated. �Thanks.This appears to be a peak interpolation method. Note that you can get a similar kind of spectral interpolation by simply zero padding your data (1 "cycle" worth) by large enough factor (say 10X or 100X), computing the longer FFT, and looking for the local maxima there. Center the data in the zero-padded FFT aperture if you want the phase calculation to be a bit more intuitive. The result would also be equivalent to interpolation using the transform of your window function as the interpolation kernel. This interpolation is usually more accurate than parabolic interpolation, unless the transform of the window function you use is "close enough" to a parabola. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M http://www.nicholson.com/rhn/dsp.html
Reply by ●October 27, 20102010-10-27
dani_sb wrote: [...] Well, I agree with Vladimir that using the Newton-Raphson is not a very good idea. And there are other ways of getting much more accurate results. And just to avoid any confusion for anyone attempting to replicate the results in the Gaussian ratio paper, just replace the 'GetRealPowerSpectrum code with a 64 point FFT and then compute and plot the amplitudes squared - the plot will be similar to the author's graph, but not normalized or in dB. As I mentioned, I've used the technique ever since I read about it in Mar. 1994, and have been very impressed with how well it works. For instance, I have some code that uses the same 3 tones used by the author: 1*cos(2pi*(10.5 Hz)*t) + .01*cos(2pi*(16 Hz)*t + . 1*cos(2pi*(25.21 Hz)*t) (the first 2 are the same as the ones in the well-known Harris windows paper). Using a 64 point FFT and a sample rate of 64, I compute the Gaussian window, apply it to the data, take the FFT, find (via 3 'if' statements) the largest peaks in the amplitude squared results, and estimate the frequency of the strongest tone. Then, using that estimated frequency, I compute the DFT for that specific frequency and obtain amplitude and phase. Then I subtract the estimated tone from the raw input data. The process is then repeated for the second and third tones. When computing the DFTs, I use a Hann window because it gives me better phase results than when using a Gaussian. My results are: est. frequency amplitude phase (radians) 10.500000685 1.000000034 0.000000982 25.210002870 0.099999972 -0.000007120 15.999980676 0.009999999 0.000060729 The above can be tweaked to squeeze out some extra digits of accuracy by reducing the computational noise (I used a recursive FFT for the above, and the DFT could be computed differently to reduce its error contribution). As I mentioned, I've also re-derived the equations so that I can use arbitrary bin spacing. This is useful if, say, I want to compute the estimates for a single tone at, oh ...10.5 Hz. I just use 2 DFTs: one at a point below 10.5 Hz, and another at a point higher than 10.5 Hz (how far apart depends on how wide I make the beamwidth of the window in the frequency domain). Then Gaussian window the data, compute the 2 DFTs, estimate frequency, and then compute one more DFT at the estimated frequency to compute amplitude/phase. And the windowing can actually be done for free by using a modified look-up table for the DFT sine/cosine parts. So the total processing is just 3 look-up based DFTs plus the natural log calculation when doing the frequency estimate.>Further on this topic I have a new question: >If my initial sampled signal would have two close harmonics, i.e. >x(t)=sin(2*pi*f*t)+0.5*sin(11.4*2*pi*f*t)+0.3*sin(11*2*pi*f*t), >is there any method to identify both harmonics from one cycle? (to me it >looks a bit unlikely since both harmonics are spread in the same frequency >bins)Well, if your 'f' is still 50, then you'd have tones at 550 and 570 Hz. Your 'bin width' and spacing is sample_rate/N, so you've got 6400/128 = 50, which means that one tone (550) is bin-centered, and the other one (570) lies between it and the next bin up. If you use the minimal sample rate and allow N to be large enough, you can always get enough separation between them to make it work. But the moment you throw in that 'identify both harmonics from one cycle' requirement, it becomes more difficult. There are in fact things you can do (e.g: I've been able to use it for 1/2 cycle or 3/4 cycle inputs), but it becomes more sensitive to noise. And there wasn't another very close-by interfering tone. There may be some parametric model that you can use. But even then, you've got that time-bandwith problem to deal with. The more specific you make your problem statement, the better you can select a processing model to deal with it. Kevin McGee
>And just to avoid any confusion for anyone attempting to replicate the >results in the Gaussian ratio paper, just replace the >'GetRealPowerSpectrum code with a 64 point FFT and then compute and >plot the amplitudes squared - the plot will be similar to the author's >graph, but not normalized or in dB.Firstly I tried the quadratic approach whici led to quite some bad estimates so I also tried the Gaussian ratio method but I am not sure if my results are good because the link to the author's graph is broken (or the problem is at my end). My implementation and results would be the following : http://img576.imageshack.us/img576/7945/gaussianratio.png>As I mentioned, I've used the technique ever since I read about it in >Mar. 1994, and have been very impressed with how well it works. For >instance, I have some code that uses the same 3 tones used by the >author: 1*cos(2pi*(10.5 Hz)*t) + .01*cos(2pi*(16 Hz)*t + . >1*cos(2pi*(25.21 Hz)*t) (the first 2 are the same as the ones in the >well-known Harris windows paper). >Using a 64 point FFT and a sample rate of 64, I compute the Gaussian >window, apply it to the data, take the FFT, find (via 3 'if' >statements) the largest peaks in the amplitude squared results, and >estimate the frequency of the strongest tone. Then, using that >estimated frequency, I compute the DFT for that specific frequency and >obtain amplitude and phase. Then I subtract the estimated tone from >the raw input data. The process is then repeated for the second and >third tones. When computing the DFTs, I use a Hann window because it >gives me better phase results than when using a Gaussian. >My results are: >est. frequency amplitude phase (radians) > >10.500000685 1.000000034 0.000000982 > >25.210002870 0.099999972 -0.000007120 > >15.999980676 0.009999999 0.000060729 > >The above can be tweaked to squeeze out some extra digits of accuracy >by reducing the computational noise (I used a recursive FFT for the >above, and the DFT could be computed differently to reduce its error >contribution). > >As I mentioned, I've also re-derived the equations so that I can use >arbitrary bin spacing. This is useful if, say, I want to compute the >estimates for a single tone at, oh ...10.5 Hz. I just use 2 DFTs: one >at a point below 10.5 Hz, and another at a point higher than 10.5 Hz >(how far apart depends on how wide I make the beamwidth of the window >in the frequency domain). Then Gaussian window the data, compute the >2 DFTs, estimate frequency, and then compute one more DFT at the >estimated frequency to compute amplitude/phase. And the windowing can >actually be done for free by using a modified look-up table for the >DFT sine/cosine parts. So the total processing is just 3 look-up >based DFTs plus the natural log calculation when doing the frequency >estimate. > >>Further on this topic I have a new question: >>If my initial sampled signal would have two close harmonics, i.e. >>x(t)=sin(2*pi*f*t)+0.5*sin(11.4*2*pi*f*t)+0.3*sin(11*2*pi*f*t), >>is there any method to identify both harmonics from one cycle? (to me it >>looks a bit unlikely since both harmonics are spread in the samefrequency>>bins) > >Well, if your 'f' is still 50, then you'd have tones at 550 and 570 >Hz. Your 'bin width' and spacing is sample_rate/N, so you've got >6400/128 = 50, which means that one tone (550) is bin-centered, and >the other one (570) lies between it and the next bin up. If you use >the minimal sample rate and allow N to be large enough, you can always >get enough separation between them to make it work. But the moment >you throw in that 'identify both harmonics from one cycle' >requirement, it becomes more difficult. There are in fact things you >can do (e.g: I've been able to use it for 1/2 cycle or 3/4 cycle >inputs), but it becomes more sensitive to noise. And there wasn't >another very close-by interfering tone. > >There may be some parametric model that you can use. But even then, >you've got that time-bandwith problem to deal with. The more specific >you make your problem statement, the better you can select a >processing model to deal with it. > >Kevin McGee >The 'one cycle thing' is more like the ideal case. My system input is a voltage or current waveform measured to the input of a nonlinear load (i.e. an arc furnance) so the shorter the analysis window, the higher the chances of analyzing a stationary piece of signal. The fundamental frequency is 50 Hz (with some small variations) and the best I can do in terms of acquisition is 25600 S/s (512 samples/cycle). Before I found the Newton stuff and this website I had an idea based on the wavelet transform but the problems encountered were about the same as with the FFT: one tone was placed in more than one frequency band and closed up tones could not be separated. I even thought of building up some sort of mother wavelet that would translate the frequency bands resulting in multiple distributions what would allow by comparison (or some algorithm) to estimate the tones parameters. Daniel
Reply by ●October 28, 20102010-10-28
dani_sb wrote:>Firstly I tried the quadratic approach whici led to quite some bad >estimates so I also tried the Gaussian ratio method but I am not sure if my >results are good because the link to the author's graph is broken.Yes, the link does appear to be broken. And your results are off, but I'm sure we can fix it. First: what happened to pi? The McEachern code has a statement: pi = 3.1415926; Your code is missing that, and if it's not defined and the compiler sets it to zero, then all your window points are all = 1. Your power spectrum results look very much like an unwindowed 10.5 Hz tone. Perhaps you should plot the window to make sure that it's being computed correctly (it should show small numbers at first, then increase towards the middle (i.e: 32 point of the 64 total points), and then decrease towards the end point at 63). Second, you probably want to move that connection to your power spectrum box to be before the magnitude squared part. My guess is that LabView requires inputs to a power spectrum to be real/imaginary, not mag/phase. As I said, your 'power spectrum' looks very much like an unwindowed tone at 10.5, and something very small scale around the 23-26 points, and nothing at 16 (but I'm not surprised about the latter, since that tone is 40 dB down). Also check to see if Labview scales their FFT results or not. that will affect amplitude estimates. Your XY graph actually doesn't look too bad, but the amplitudes tell me that someting is not being scaled properly.>The 'one cycle thing' is more like the ideal case. My system input is a >voltage or current waveform measured to the input of a nonlinear load (i.e. >an arc furnance) so the shorter the analysis window, the higher the chances >of analyzing a stationary piece of signal.The 'one cycle' requirement coupled with the '2 close-by tones' is a very severe problem. And non-stationarity signals can be difficult at times, but there are methods for dealing with them.>Before I found the Newton stuff and this website I had an idea based on the >wavelet transform but the problems encountered were about the same as with >the FFT: one tone was placed in more than one frequency band and closed up >tones could not be separated.Yes, that time-bandwidth problem is a tough one to deal with, no matter what transform type you're dealing with. But let's burn one bridge at a time. Get that 'pi' term defined and move the power spectrum connection in LabView to before the mag squared part. The McEachern results (outputs 8 to 11) show: frequency amplitude 8 10.49958 0.999533 9 10.50005 1.00001 10 10.50005 1.000012 11 10.49977 1.000104 Kevin McGee
