I have to do cross correlation of two audio file to prove they are similar. I have done FFT of two audio files and have the power spectrum value of both the audio file in a separate array.how should i proceed further to do cross correlation to prove they are similar.Any basic ideas will be helpful for me to learn and apply it.Thanks.
How to implement cross correlation after FFT in DSP?
Started by ●October 29, 2010
Reply by ●October 29, 20102010-10-29
On Fri, 29 Oct 2010 02:00:55 -0500, "warrior" <prassan86@n_o_s_p_a_m.gmail.com> wrote:>I have to do cross correlation of two audio file to prove they are >similar. >I have done FFT of two audio files and have the power spectrum value of >both the audio file in a separate array.how should i proceed further to do >cross correlation to prove they are similar.Any basic ideas will be >helpful for me to learn and apply it.Thanks.Hello Warrior, You might take a look at Section III of: http://classes.engr.oregonstate.edu/eecs/winter2009/ece464/AnalyticTDE_Sept1999_SPTrans.pdf Good Luck, [-Rick-]
