Is there anyway to get an amplitude of an ac signal averaged over time w/o some kind of rectification? This doesn't include the trivial, i.e., dc offsets or partial cycles. The rectification could be analog, digital or software. Bret Cahill
Amplitude Time Ave. w/o Rectification
Started by ●November 5, 2010
Reply by ●November 5, 20102010-11-05
Bret Cahill wrote:> Is there anyway to get an amplitude of an ac signal averaged over time > w/o some kind of rectification?Sure. Connect the AC to a heater and measure the temperature.> This doesn't include the trivial, i.e., dc offsets or partial cycles. > The rectification could be analog, digital or software.What are you really trying to do? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Nov 5, 4:00�pm, Bret Cahill <Bret_E_Cah...@yahoo.com> wrote:> Is there anyway to get an amplitude of an ac signal averaged over time > w/o some kind of rectification? > > This doesn't include the trivial, i.e., dc offsets or partial cycles. > > The rectification could be analog, digital or software. > > Bret CahillSee "Understanding DSP" by R Lyons p 366 of the second edition.. Use a Hilbert to get Real and imaginary components of the signal then, the envelope is found as the SQRT (R^2+i^2). No rectification and no low pass filtering is needed. I found this fascinating becasue as a kid playing with AM radios, i began to understand the limitations of a diode detector and this is the elegant solution... Mark
In comp.dsp Vladimir Vassilevsky <nospam@nowhere.com> wrote:> Bret Cahill wrote:>> Is there anyway to get an amplitude of an ac signal averaged over time >> w/o some kind of rectification?> Sure. Connect the AC to a heater and measure the temperature.>> This doesn't include the trivial, i.e., dc offsets or partial cycles. >> The rectification could be analog, digital or software.You need some non-linear operation, which may or may not be considered rectification. I believe the heater/temperature measurement has been used for RF power measurements for many years. -- glen
glen herrmannsfeldt wrote:> In comp.dsp Vladimir Vassilevsky <nospam@nowhere.com> wrote: > > >>Bret Cahill wrote: > > > >>>Is there anyway to get an amplitude of an ac signal averaged over time >>>w/o some kind of rectification? > > > >>Sure. Connect the AC to a heater and measure the temperature. > > > >>>This doesn't include the trivial, i.e., dc offsets or partial cycles. >>>The rectification could be analog, digital or software. > > > You need some non-linear operation, which may or may not be > considered rectification.No nonlinear operations. Just multiply the AC by a synchronous reference.> I believe the heater/temperature > measurement has been used for RF power measurements for many years.That doesn't do any rectification for sure. VLV
> > In comp.dsp Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > >>Bret Cahill wrote: > > >>>Is there anyway to get an amplitude of an ac signal averaged over time > >>>w/o some kind of rectification? > > >>Sure. Connect the AC to a heater and measure the temperature. > > >>>This doesn't include the trivial, i.e., dc offsets or partial cycles. > >>>The rectification could be analog, digital or software. > > > You need some non-linear operation, �which may or may not be > > considered rectification. > > No nonlinear operations. Just multiply the AC by a synchronous reference. > > > I believe the heater/temperature > > measurement has been used for RF power measurements for many years. > > That doesn't do any rectification for sure.Positive heat with a positive signal and positive heat with a negative signal can only be considered a form of rectification. Bret Cahill
> > Is there anyway to get an amplitude of an ac signal averaged over time > > w/o some kind of rectification? > > > This doesn't include the trivial, i.e., dc offsets or partial cycles. > > > The rectification could be analog, digital or software. > > > Bret Cahill > > See "Understanding DSP" by R Lyons �p 366 of the second edition.. > > Use a Hilbert to get Real �and imaginary components of the signal > then, the envelope is found as the SQRT (R^2+i^2).Sqrt of sum of squares = absolute value = rectification.> No rectification and no low pass filtering is needed. > > I found this fascinating becasue as a kid playing with AM radios, i > began to understand the limitations of a diode detector and this is > the elegant solution...Maybe a difference measurement of peak to peak of a known waveform wouldn't be considered rectification. Bret Cahill
In comp.dsp Vladimir Vassilevsky <nospam@nowhere.com> wrote: (snip regarding rectiification, and I wrote)>> You need some non-linear operation, which may or may not be >> considered rectification.> No nonlinear operations. Just multiply the AC by a synchronous reference.Multiplying by other than a constant is a non-linear operation.>> I believe the heater/temperature >> measurement has been used for RF power measurements for many years.> That doesn't do any rectification for sure.Instantaneous power is proportional to the square of the voltage or current, not including resistance changes due to heating, and so is always positive. Is that rectification? It seems to me that any conversion of an AC signal with the DC component removed to one that is always positive is a form of rectification, but others might disagree. -- glen
Bret Cahill wrote:>>>In comp.dsp Vladimir Vassilevsky <nos...@nowhere.com> wrote: >> >>>>Bret Cahill wrote: >> >>>>>Is there anyway to get an amplitude of an ac signal averaged over time >>>>>w/o some kind of rectification? >> >>>>Sure. Connect the AC to a heater and measure the temperature. >> >>>>>This doesn't include the trivial, i.e., dc offsets or partial cycles. >>>>>The rectification could be analog, digital or software. >> >>>You need some non-linear operation, which may or may not be >>>considered rectification. >> >>No nonlinear operations. Just multiply the AC by a synchronous reference. >> >> >>>I believe the heater/temperature >>>measurement has been used for RF power measurements for many years. >> >>That doesn't do any rectification for sure. > > > Positive heat with a positive signal and positive heat with a negative > signal can only be considered a form of rectification.1. Take 3 consequent samples x[0],x[1],x[2] 2. Solve the system of equations x[i] = A sin(Wt + Fi) 3. Now you know A, W, and Fi
> > Is there anyway to get an amplitude of an ac signal averaged over time > > w/o some kind of rectification? > > > This doesn't include the trivial, i.e., dc offsets or partial cycles. > > > The rectification could be analog, digital or software. > > > Bret Cahill > > You need a precision rectifier.. > � �couple of op-amps and maybe 1 diode .. > > http://sound.westhost.com/appnotes/an001.htmPoorly written OP. The goal is getting the amplitude _without_ rectification. Rectification" is to be very broadly construed and includes anything that results in the final "signal" being positive at all times. Maybe peak to peak wil work if you know the wave form. Bret Cahill
