if you were designing a decimation filter for a baseband wcdma signal that was oversampled, what target (decimated) bandwidth would you choose? -- Randy Yates % "Maybe one day I'll feel her cold embrace, Digital Signal Labs % and kiss her interface, mailto://yates@ieee.org % til then, I'll leave her alone." http://www.digitalsignallabs.com % 'Yours Truly, 2095', *Time*, ELO
wcdma bandwidth
Started by ●November 12, 2010
Reply by ●November 12, 20102010-11-12
>if you were designing a decimation filter for a baseband wcdma signal >that was oversampled, what target (decimated) bandwidth would you >choose?Somewhere between 2.5 MHz and 4 MHz at baseband? Steve
spope33@speedymail.org (Steve Pope) writes:>>if you were designing a decimation filter for a baseband wcdma signal >>that was oversampled, what target (decimated) bandwidth would you >>choose? > > Somewhere between 2.5 MHz and 4 MHz at baseband?How could it possibly be 2.5 MHz? The chip rate is 3.84 Mc/s. -- Randy Yates % "Maybe one day I'll feel her cold embrace, Digital Signal Labs % and kiss her interface, mailto://yates@ieee.org % til then, I'll leave her alone." http://www.digitalsignallabs.com % 'Yours Truly, 2095', *Time*, ELO
In article <m3d3qajfy6.fsf@ieee.org>, Randy Yates <yates@ieee.org> wrote:>spope33@speedymail.org (Steve Pope) writes: > >>>if you were designing a decimation filter for a baseband wcdma signal >>>that was oversampled, what target (decimated) bandwidth would you >>>choose? >> >> Somewhere between 2.5 MHz and 4 MHz at baseband? > >How could it possibly be 2.5 MHz? The chip rate is 3.84 Mc/s.You said "at baseband". We could get into a philosophical discussion as to what "2.5 MHz bandwidth at baseband" means, but I meant each of the I and Q channels has a bandwidth from 0 to 2.5 MHz. Steve
spope33@speedymail.org (Steve Pope) writes:> In article <m3d3qajfy6.fsf@ieee.org>, Randy Yates <yates@ieee.org> wrote: >>spope33@speedymail.org (Steve Pope) writes: >> >>>>if you were designing a decimation filter for a baseband wcdma signal >>>>that was oversampled, what target (decimated) bandwidth would you >>>>choose? >>> >>> Somewhere between 2.5 MHz and 4 MHz at baseband? >> >>How could it possibly be 2.5 MHz? The chip rate is 3.84 Mc/s. > > You said "at baseband". > > We could get into a philosophical discussion as to what > "2.5 MHz bandwidth at baseband" means, but I meant each > of the I and Q channels has a bandwidth from 0 to 2.5 MHz.Doh! Right. (I was thinking of complex bandwidth). I agree with 2.5 (5 MHz complex) based on a chip rate of 3.84 Mc/s and (according to the 3GPP spec) a RRC rolloff factor of 0.22. Is that where your numbers come from? -- Randy Yates % "So now it's getting late, Digital Signal Labs % and those who hesitate mailto://yates@ieee.org % got no one..." http://www.digitalsignallabs.com % 'Waterfall', *Face The Music*, ELO
Randy Yates <yates@ieee.org> writes:> spope33@speedymail.org (Steve Pope) writes: > >> In article <m3d3qajfy6.fsf@ieee.org>, Randy Yates <yates@ieee.org> wrote: >>>spope33@speedymail.org (Steve Pope) writes: >>> >>>>>if you were designing a decimation filter for a baseband wcdma signal >>>>>that was oversampled, what target (decimated) bandwidth would you >>>>>choose? >>>> >>>> Somewhere between 2.5 MHz and 4 MHz at baseband? >>> >>>How could it possibly be 2.5 MHz? The chip rate is 3.84 Mc/s. >> >> You said "at baseband". >> >> We could get into a philosophical discussion as to what >> "2.5 MHz bandwidth at baseband" means, but I meant each >> of the I and Q channels has a bandwidth from 0 to 2.5 MHz. > > Doh! Right. (I was thinking of complex bandwidth). > > I agree with 2.5 (5 MHz complex) based on a chip rate of 3.84 Mc/s > and (according to the 3GPP spec) a RRC rolloff factor of 0.22. Is > that where your numbers come from?PS: And just rounding from 4.685 to 5. -- Randy Yates % "Rollin' and riding and slippin' and Digital Signal Labs % sliding, it's magic." mailto://yates@ieee.org % http://www.digitalsignallabs.com % 'Living' Thing', *A New World Record*, ELO
Randy Yates <yates@ieee.org> wrote:>spope33@speedymail.org (Steve Pope) writes:>> In article <m3d3qajfy6.fsf@ieee.org>, Randy Yates <yates@ieee.org> wrote: >>>spope33@speedymail.org (Steve Pope) writes: >>> >>>>>if you were designing a decimation filter for a baseband wcdma signal >>>>>that was oversampled, what target (decimated) bandwidth would you >>>>>choose? >>>> >>>> Somewhere between 2.5 MHz and 4 MHz at baseband? >>> >>>How could it possibly be 2.5 MHz? The chip rate is 3.84 Mc/s.>> You said "at baseband".>> We could get into a philosophical discussion as to what >> "2.5 MHz bandwidth at baseband" means, but I meant each >> of the I and Q channels has a bandwidth from 0 to 2.5 MHz. > >Doh! Right. (I was thinking of complex bandwidth). > >I agree with 2.5 (5 MHz complex) based on a chip rate of 3.84 Mc/s >and (according to the 3GPP spec) a RRC rolloff factor of 0.22. Is >that where your numbers come from?That's approximately my thinking. Steve
