Hi, Do samples per symbol and sampling rate convey the same message? I know what sampling rate is but why samples per symbol is used in certain cases instead of sampling rate? I think that samples per symbol is used in systems where the signal is processed at baseband whereas, sampling rate is used for systems where processing is done at IF.
samples per symbol Vs sampling rate - Can they be used interchangeably?
Started by ●November 14, 2010
Reply by ●November 14, 20102010-11-14
On 11/14/2010 09:50 AM, johnlovestohate wrote:> Hi, > Do samples per symbol and sampling rate convey the same message? > > I know what sampling rate is but why samples per symbol is used in certain > cases instead of sampling rate? > > I think that samples per symbol is used in systems where the signal is > processed at baseband whereas, sampling rate is used for systems where > processing is done at IF.Sampling rate is normally taken as the number of samples per _second_, and speaks to the ease of processing a signal of a given bandwidth, whether it has digital data encoded on it or not. Sampling rate per _symbol_ speaks to the ease of demodulating a digital signal. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
"johnlovestohate" <aliatolemiss@n_o_s_p_a_m.gmail.com> writes:> Hi, > Do samples per symbol and sampling rate convey the same message? > > I know what sampling rate is but why samples per symbol is used in certain > cases instead of sampling rate? > > I think that samples per symbol is used in systems where the signal is > processed at baseband whereas, sampling rate is used for systems where > processing is done at IF.Sample rate (samples / second) is a characteristic of a sampled data system (i.e., a digital system). Symbol rate (symbols / second) is a characteristic of a digital communication system. Samples per symbol arise when a digital communication signal is processed digitally, in which case samples / symbol = (samples / second) / (symbols / second) -- Randy Yates % "Though you ride on the wheels of tomorrow, Digital Signal Labs % you still wander the fields of your mailto://yates@ieee.org % sorrow." http://www.digitalsignallabs.com % '21st Century Man', *Time*, ELO
"johnlovestohate" <aliatolemiss@n_o_s_p_a_m.gmail.com> writes:> Hi, > Do samples per symbol and sampling rate convey the same message? > > I know what sampling rate is but why samples per symbol is used in certain > cases instead of sampling rate? > > I think that samples per symbol is used in systems where the signal is > processed at baseband whereas, sampling rate is used for systems where > processing is done at IF.PS: Using the definitions previously given, sample rate is used for both IF and baseband. Although not strictly true, typically we speak of samples / symbol when dealing with a baseband digital comm signal that is being processed digitally. Also, samples / symbol is an important factor in digital demodulation as it impacts the ability to equalize the signal and determine timing. -- Randy Yates % "Rollin' and riding and slippin' and Digital Signal Labs % sliding, it's magic." mailto://yates@ieee.org % http://www.digitalsignallabs.com % 'Living' Thing', *A New World Record*, ELO
Reply by ●November 15, 20102010-11-15
