Phase of sine wave using fft
Started by cpshah99 ●November 18, 2010
>On Nov 19, 11:46=A0am, "cpshah99" <cpshah99@n_o_s_p_a_m.rediffmail.com> >wrote: >> OK Guys. >> >> As Tim had said, trig should give all the angles (azimuth and
elevation).
>> >> But as he had said, there will be many solutions. I had to work a
little
>> hard but finally managed to get all the angles but it is complex and >> difficult to select a solution. It also depends a lot on which sensor
we
>> select as ref and as Fred had said, element spacing also matters. >> >> But from this TDOA exercise, it seems that I am not suppose to measure >> phase or relative phase at sensors. > >You need to select some direction as reference. The DoA of the >signal will be measured as some phase relative to this reference. >The problem with all DoA estimators lie in the mechanics of >doing these calculations. The classic beamformers use steering >vectors (not unlike the usual filters) to separate the signal >into spatial bands, and use the relative magnitudes of these >bands to determine the DoA. > >MUSIC decomposes the signal into a matrix representation and then >uses a brute-force search over all angles to find the best matching >direction(s), while ESPRIT exploits certain geometric invariants >of the array to avoid the brute-force search and instead compute >the DoAs in more direct ways. > >> The only information that I need is >> time of arrival which can be obtained using cross-correlation. Am I >> correct??? > >Not quite. The ToA is known - you already have a time stamp relating >the n'th snapshot of the array to some physical time t. > >The DoA is computed from the *spatial* cross correlation between >the signals recorded at the individual sensors. > >Rune >
%%% OK. Just one more question. For UCA, what if I use TDOA to estimate elevation angle and then use MUSIC to estimate azimuth angle? This approach should provide better result than MUSIC on its own. And from hardware implementation point, is it feasible to implement MUSIC? I mean would you prefer MUSIC or some other algorithm. Best Regards Chintan
