Under the same circumstances, I get 15 X ray images I1, I2, I3, …,I15. Then two methods were used to get the noise only image. First method: Noise image=(I1-I2)/sqrt(2). They said that subvided by sqrt(2) can maintain the variance of the Noise image identical to I1 and I2. Second method: Noise image=I1-(I1+I2+I3+…+I15)/15. Can this method maintain the variance of noise image identical to original images? If I don't consider the coefficient of sqrt(2), I think first method can also be explained as Noise image=I1-(I1+I2)/2. The above equation is similar to second method. Please give me some suggestion, Thank you.
Are these two methods identical to get the noise only image
Started by ●November 19, 2010
Reply by ●November 20, 20102010-11-20
On 11/19/2010 07:26 PM, tjucruiser wrote:> Under the same circumstances, I get 15 X ray images I1, I2, I3, …,I15. > Then two methods were used to get the noise only image. > > First method: > Noise image=(I1-I2)/sqrt(2). > They said that subvided by sqrt(2) can maintain the variance of the Noise > image identical to I1 and I2. > > Second method: > Noise image=I1-(I1+I2+I3+…+I15)/15. Can this method maintain the variance > of noise image identical to original images? > > If I don't consider the coefficient of sqrt(2), I think first method can > also be explained as > Noise image=I1-(I1+I2)/2. > The above equation is similar to second method. > > Please give me some suggestion, Thank you.Assuming that the images are perfectly registered, of the same scale, has the same contrast & brightness, etc., etc.: The first method gives you noise that's a combination of the noise in image 1 and the noise in image 2. Assuming that the noise in image 1 and image 2 have the same variance and is independent, then the variance of the noise you compute will be the same. If the images start out with Gaussian noise then the noise you compute will have the same statistics -- but I doubt that the noise in an x-ray image will be Gaussian, given that you're looking at intensity. The second method gives you a much closer approximation to the noise in I1, although it is still not exact. When you calculate the average image you'll be reducing the variance significantly, but there will still be some, and the noise statistics will tend toward Gaussian. You'll also have a general whitening of the image, as I suspect that the noise is not zero-mean. So you'll need to divide by something like sqrt(1 + 1/15), or some similar factor (I would have to do some math to know). _And_, you won't have noise statistics that end up the same, unless you started with Gaussian noise. Note that image registration, contrast, brightness, etc., problems, will sink this technique deeper than deep. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 11/19/2010 7:26 PM, tjucruiser wrote:> Under the same circumstances, I get 15 X ray images I1, I2, I3, …,I15. > Then two methods were used to get the noise only image. > > First method: > Noise image=(I1-I2)/sqrt(2). > They said that subvided by sqrt(2) can maintain the variance of the Noise > image identical to I1 and I2. > > Second method: > Noise image=I1-(I1+I2+I3+…+I15)/15. Can this method maintain the variance > of noise image identical to original images? > > If I don't consider the coefficient of sqrt(2), I think first method can > also be explained as > Noise image=I1-(I1+I2)/2. > The above equation is similar to second method. > > Please give me some suggestion, Thank you. > >If you superimpose two equal random noises together then the resulting standard deviation (the root mean square value) increases as the sqrt of 2. So, maybe that's what "they" mean. Note that these are average measurements. Also note that since the noises are random and since we're using averages of one sort or another then "subtracting" makes little sense. That's why is said "superimpose" above. But you can subtract the constant stuff - so subtraction makes sense - although I'd be careful of any systemic differences in scale from one image to another. I know you said "under the same circumstances" but this would be a key point in having "the same circumstances". Also, that the underlying images are equal spatially as well of course. I don't know what a "noise image" is in the context of random noise - other than measuring some parameters of it. Calling it an "image" connotes a degree of stability which eludes me. But, I suppose it could be common language that I'm not familiar with. Your second method was garbled in the text here. Did you mean: N I1 - (1/N)sum I(n) i=1 ? If all you're interested in is an "image" of noise then I guess the scale factor might not matter. It depends a lot on what you're trying to do. One finds: http://ip.com/patent/US7834918 Anyway, it appears that it's useful to do noise averaging in images to reduce the random noise. So, I can imagine doing something like this: N (1/N)sum I(n) i=1 Which is the average of a number of images. If they are of the same subject then the noise would be averaged down. If the noise is zero mean then I suppose eventually or theoretically, with enough images, one would see the noise mean at each pixel and that would be zero. Somehow I have to think there would be a practical point of diminishing returns. I've tried to figure out what your objective is here. If you define a noise image by subtracting the average of a number of images (with the subject being constant and with presumed zero or reduced noise) from a single image then the result would be an estimate of the noise in that single image. Then you could repeat the process for each image and get a statistic of the image noises. Is that what you're trying to measure? In other words, this would be a noise enhancement / subject suppression scheme, eh? Surely one would not calculate a "noise image" and then subtract it from any image with the idea of reducing the noise. That would only make things worse - even if the "noise image" were taken from the same set of images. Fred
