Hi Guys, I've written some c# code to produce the MFCC from a set of floating point magnitude values returned from FFTW. Does anyone have any test data (ie, FFT magnitude values and their resulting 12 MFCC values) that I could use to verify my code is working correctly? Failing that, could I pass a set of the 64 values from the FFT for someone to run through Matlab and give me back the 12 MFCC values? I've been using this document as the basis for my code... http://mirlab.org/jang/books/audioSignalProcessing/speechFeatureMfcc.asp?title=12-2%20MFCC Thanks Ray
MFCC Test Data?
Started by ●December 15, 2010
