Hi all, I am working on the first part of the implementation of a 3D sound system in real time and I need to choose a DSP processor. So far I've checked that a 16 bit wordlength and fixed point meet my requirements. The situation is that I need to store almost 12000 fir filters, of 128th length each, as a program data (these filters correspond to head related impulse responses with a spatial resolution of 2 degree covering the whole sphere). Based on my calculations this needs around 6 MByte of memory which looks quite a lot and as far as I know the on-chip memory of a typical DSP processor is not that much. I would really appreciate some guidelines on how to do it in order to meet the memory requirements I need for this implementation. thanks in advance.
Memory requirements for a high amount of filters
Started by ●February 9, 2004
Reply by ●February 9, 20042004-02-09
Pablo F: Hoffmann wrote:> Hi all, > > I am working on the first part of the implementation of a 3D sound > system in real time and I need to choose a DSP processor. So far I've > checked that a 16 bit wordlength and fixed point meet my requirements. > The situation is that I need to store almost 12000 fir filters, of 128th > length each, as a program data (these filters correspond to head related > impulse responses with a spatial resolution of 2 degree covering the > whole sphere). Based on my calculations this needs around 6 MByte of > memory which looks quite a lot and as far as I know the on-chip memory > of a typical DSP processor is not that much. I would really appreciate > some guidelines on how to do it in order to meet the memory requirements > I need for this implementation. > > thanks in advance.ADI's TigerSharc has 24Mbits of on-chip memory, but that's only half of what you need (6MBytes*8bits/byte=48Mbits). You could consider using more than one of them in a system. You'd most likely want more than two though, because you'd need room for things other than fir coefs (like say... input data and program storage). Is there a reason you can't use off-chip memory? The penalty for using it isn't *that* heavy, and if you could entertain that idea, many, many solutions would be available to you. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 The secret to enjoying your job is to have a hobby that's even worse - Calvin's Dad
Pablo F: Hoffmann wrote:> > Hi all, > > I am working on the first part of the implementation of a 3D sound > system in real time and I need to choose a DSP processor. So far I've > checked that a 16 bit wordlength and fixed point meet my requirements. > The situation is that I need to store almost 12000 fir filters, of 128th > length each,Do you find that length 128 FIR's give an effective binaural simulation? I didn't. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Pablo F: Hoffmann wrote:> Hi all, > > I am working on the first part of the implementation of a 3D sound > system in real time and I need to choose a DSP processor. So far I've > checked that a 16 bit wordlength and fixed point meet my requirements.16bit fixed-point might be ok to represent an audio signal, but you need to look at higher bit arithemtic if you want to sustain 16bit quality.> The situation is that I need to store almost 12000 fir filters, of 128th > length each, as a program data (these filters correspond to head related > impulse responses with a spatial resolution of 2 degree covering the > whole sphere).I'm busy with a similar project (memory wise): 25 FIRs with up to 300'000 taps. The only possibility is to store the coefficients in SDRAM. While this is a bottle neck, the system is designed to cope by using a large number of DSPs. To determine the proper DSP type and the number of DSPs required, you need to also specify the number of audio streams to be filtered with the FIRs and the sample rate. Regards, Andor
Pablo F: Hoffmann <pfh@acoustics.aau.dk> wrote in news:c083vr$7bt$1 @sunsite.dk:> Hi all, > > I am working on the first part of the implementation of a 3D sound > system in real time and I need to choose a DSP processor. So far I've > checked that a 16 bit wordlength and fixed point meet my requirements. > The situation is that I need to store almost 12000 fir filters, of128th> length each, as a program data (these filters correspond to headrelated> impulse responses with a spatial resolution of 2 degree covering the > whole sphere). Based on my calculations this needs around 6 MByte of > memory which looks quite a lot and as far as I know the on-chip memory > of a typical DSP processor is not that much. I would really appreciate > some guidelines on how to do it in order to meet the memoryrequirements> I need for this implementation. > > thanks in advance.Our dspstak 21161sx has a 2M x 32 bit SDRAM that would be suitable from a memory point of view. It is based on the Analog Devices ADSP-21161N DSP. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Reply by ●February 10, 20042004-02-10
Andor wrote:> Pablo F: Hoffmann wrote: > > >>Hi all, >> >>I am working on the first part of the implementation of a 3D sound >>system in real time and I need to choose a DSP processor. So far I've >>checked that a 16 bit wordlength and fixed point meet my requirements. > > > 16bit fixed-point might be ok to represent an audio signal, but you > need to look at higher bit arithemtic if you want to sustain 16bit > quality. > > >>The situation is that I need to store almost 12000 fir filters, of 128th >>length each, as a program data (these filters correspond to head related >>impulse responses with a spatial resolution of 2 degree covering the >>whole sphere). > > > I'm busy with a similar project (memory wise): 25 FIRs with up to > 300'000 taps. > The only possibility is to store the coefficients in SDRAM. While this > is a bottle neck, the system is designed to cope by using a large > number of DSPs. > > To determine the proper DSP type and the number of DSPs required, you > need to also specify the number of audio streams to be filtered with > the FIRs and the sample rate. > > Regards, > AndorOk, Thanks for your comments. Actually what I have to do is filtering a single audio signal to a two channel filtered signal ( one for each ear) at a frequency rate of 48 kHz. I guess this means that I need to complete all the operations per sample at a rate higher than 96 kHz, is that right?. Finally the output signal must be delivered through headphones. regards, Pablo
Pablo F: Hoffmann wrote: ....> Ok, Thanks for your comments. Actually what I have to do is filtering a > single audio signal to a two channel filtered signal ( one for each ear) > at a frequency rate of 48 kHz. I guess this means that I need to > complete all the operations per sample at a rate higher than 96 kHz, is > that right?.Yup. Generating two 48kHz output channels from one 48kHz input by filtering the input with a 128 tap FIR per channel is a really low processing load. I'm sure already the cheapest 16bit DSPs will suffice. Do you want to build your own hardware or are you looking for a DSP development kit? Regards, Andor
Reply by ●February 11, 20042004-02-11
Andor wrote:> Pablo F: Hoffmann wrote: > .... > >>Ok, Thanks for your comments. Actually what I have to do is filtering a >>single audio signal to a two channel filtered signal ( one for each ear) >>at a frequency rate of 48 kHz. I guess this means that I need to >>complete all the operations per sample at a rate higher than 96 kHz, is >>that right?. > > > Yup. Generating two 48kHz output channels from one 48kHz input by > filtering the input with a 128 tap FIR per channel is a really low > processing load. I'm sure already the cheapest 16bit DSPs will > suffice. > > Do you want to build your own hardware or are you looking for a DSP > development kit? > > Regards, > AndorThanks again for your comments. My background is in Acoustics so I am not really into build my own hardware, I just wanna get a development kit that can satisfy my requirements, I was actually thinking something from the TMS320C5000 DSPs. The thing is that i have to switch between filters depending on data received by a head tracker so I can simulate the relative position of a sound in space when the user moves his/her head. regards,
If you change filters based on head rotation, then you will have all the time in the world to reload a new filter. I would keep the two adjacent filters (to the left and right) in internal memory, and the rest in some cheap off-chip EPROM or similar. Tomas "Pablo F. Hoffmann" <pfh@acoustics.aau.dk> skrev i meddelandet news:c0cuij$eff$1@sunsite.dk...> Andor wrote: > > Pablo F: Hoffmann wrote: > > .... > > > >>Ok, Thanks for your comments. Actually what I have to do is filtering a > >>single audio signal to a two channel filtered signal ( one for each ear) > >>at a frequency rate of 48 kHz. I guess this means that I need to > >>complete all the operations per sample at a rate higher than 96 kHz, is > >>that right?. > > > > > > Yup. Generating two 48kHz output channels from one 48kHz input by > > filtering the input with a 128 tap FIR per channel is a really low > > processing load. I'm sure already the cheapest 16bit DSPs will > > suffice. > > > > Do you want to build your own hardware or are you looking for a DSP > > development kit? > > > > Regards, > > Andor > Thanks again for your comments. > > My background is in Acoustics so I am not really into build my own > hardware, I just wanna get a development kit that can satisfy my > requirements, I was actually thinking something from the TMS320C5000 > DSPs. The thing is that i have to switch between filters depending on > data received by a head tracker so I can simulate the relative position > of a sound in space when the user moves his/her head. > > regards,
Tomas Ahrne wrote:> If you change filters based on head rotation, then you will have all the > time in the world to reload a new filter. I would keep the two adjacent > filters (to the left and right) in internal memory, and the rest in some > cheap off-chip EPROM or similar.OTOH, if you have all the time in the world (and maybe you don't - I dunno), you could consider having the DSP calculate the FIR coefs on the fly. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 I'm a man. But I can change. If I have to. I guess. - Red Green
