Hi I need to know output of convolutional encoder for K = 7 means (6 memory elements), output with corresponding (transition) states. I could found this for K = 3 (means 2 memory elements) with 4 states and 4 different outputs and in other way 8 possible outputs which are written on arrows leading from one stage of trellis to another trellis stage. Its dimension should be 64 x 2 which means 64 rows and 2 columns. In other words, I want to see/create one complete trellis stage (64 states) with corresponding outputs. I need to know this because I want to calculate Euclidean distance of these outputs and received values. By using polynomial description, I know its possible to calculate output or next states etc but it's a very lengthy process. I have seen Matlab's function "poly2trellis" but "trellis.outputs" is also not useful for me. Please help me if anyone can. Thank you in advance.
Transition States for K = 7 viterbi decoder
Started by ●December 20, 2010
