General DSP processing question
Started by charlyb ●January 24, 2011
Thank you for your valuable responses.
To clarify : I can stop on any frequency and process the signals in as much
time as I need (ultimately I need this to be as short as possible)
Thank you
> To clarify : I can stop on any frequency and process the signals in as much > time as I need (ultimately I need this to be as short as possible
Sweeps in wobblers are rarely linear ( fixed increment ) because that would be too slow. They are usually exponential or double-exponential, getting faster to the higher frequencies. How fast depends on the settling time of the object one is testing. As far as i remember one can do up-sweep and down-sweep and compare both results: if they do not match one should slow down. Text is in German, but pictures should be clear: http://www.embeddedforth.de/temp/sweep.pdf MfG JRD
Thanks all for responding.
I can dwell on any frequency and sample for any length of time (but this
needs to as short and quick as possible)
Thank you.
