Hi all, It's been a couple of years since I last visited comp.dsp. But now I finally have a dsp related question :) I need to generate noise with a specific crest factor, so I tested in SciLab with: 1. Generate a vector of uniformly distributed random numbers (noise if you will) in the range [-pi/2,+pi/2] 2. Feed that into sin(...) and get a vector with range [-1,+1] Seems to work pretty nicely, since the RMS of the vector from (2) is about 0.707 which would be same CF as a sine wave with +/- 1 amplitude. But I'd really like to have a generator so I can generate with an arbitrary CF (actually I have a parameterized one but the parameter maps porly to achieved CF... :( ) Ideas ? /Rob
Generate noise with specific crest factor
Started by ●January 24, 2011
Reply by ●January 24, 20112011-01-24
On 24 Jan, 16:24, Rob <robert.bie...@xponaut.se> wrote:> But I'd really like to have a generator so I can generate with an > arbitrary CF (actually I have a parameterized one but the parameter > maps > porly to achieved CF... :( )Hehe... some more fiddling with integrals, now I got a function so I can get arbitrary CF parameterized :) /Rob
Reply by ●January 26, 20112011-01-26
On Jan 24, 10:24�am, Rob <robert.bie...@xponaut.se> wrote:> > It's been a couple of years since I last visited comp.dsp. But now I > finally have a dsp related question :) I need to generate noise with > a specific crest factor, so I tested in SciLab with: > 1. Generate a vector of uniformly distributed random numbers (noise if > you will) in the range [-pi/2,+pi/2] > 2. Feed that into sin(...) and get a vector with range [-1,+1] > Seems to work pretty nicely, since the RMS of the vector from (2) is > about 0.707 which would be same CF as a sine wave with +/- 1 > amplitude. > > But I'd really like to have a generator so I can generate with an > arbitrary CF (actually I have a parameterized one but the parameter > maps poorly to achieved CF... :( ) > > Ideas ?isn't the crest factor totally determined by the p.d.f. of the random variable? assuming you have a uniform pseudo-random variable generated by the computer, you should be able to pass this through a deterministic function to send that uniform p.d.f. to the p.d.f. that has the crest factor you want. there may be many p.d.f.s that have the desired crest factor, and i am not sure how to best choose between them. r b-j
Hi Robert, On 26 Jan, 17:17, robert bristow-johnson <r...@audioimagination.com> wrote:> isn't the crest factor totally determined by the p.d.f. of the random > variable?Yes, should be.> > assuming you have a uniform pseudo-random variable generated by the > computer, you should be able to pass this through a deterministic > function to send that uniform p.d.f. to the p.d.f. that has the crest > factor you want. �there may be many p.d.f.s that have the desired > crest factor, and i am not sure how to best choose between them.Not sure you've seen my later posts where I've successfully created that deterministic function allowing me to choose crest factor arbitrarily. Thanks though :) /Rob Ps. Is Grant G still "around" ?
The lazy solution: 1. generate a "noise" consisting of random 1 and -1 (crest factor = 1) 2. insert a single randomly placed sample with the desired crest factor as its amplitude On 26.01.2011 17:21, Rob wrote:> Hi Robert, > > On 26 Jan, 17:17, robert bristow-johnson<r...@audioimagination.com> > wrote: >> isn't the crest factor totally determined by the p.d.f. of the random >> variable? > > Yes, should be. > >> >> assuming you have a uniform pseudo-random variable generated by the >> computer, you should be able to pass this through a deterministic >> function to send that uniform p.d.f. to the p.d.f. that has the crest >> factor you want. there may be many p.d.f.s that have the desired >> crest factor, and i am not sure how to best choose between them. > > Not sure you've seen my later posts where I've successfully created > that deterministic function allowing > me to choose crest factor arbitrarily. > > Thanks though :) > /Rob > Ps. Is Grant G still "around" ?
Reply by ●January 27, 20112011-01-27
On 26 Jan, 17:32, Andre <lod...@pathme.de> wrote:> The lazy solution: > 1. generate a "noise" consisting of random 1 and -1 (crest factor = 1) > 2. insert a single randomly placed sample with the desired crest factor > as its amplitudeNope, that won't work. Crest factor == Peak/RMS. I doubt that the RMS of the noise will change significantly with that single sample insertion. /Rob
On Jan 27, 11:35�am, Rob <robert.bie...@xponaut.se> wrote:> On 26 Jan, 17:32, Andre <lod...@pathme.de> wrote: > > > The lazy solution: > > 1. generate a "noise" consisting of random 1 and -1 (crest factor = 1) > > 2. insert a single randomly placed sample with the desired crest factor > > as its amplitude > > Nope, that won't work. Crest factor == Peak/RMS. I doubt that the RMS > of the noise will change significantly with > that single sample insertion. >but Andre is saying that the *peak* will change. even by a single sample. r b-j
On 27 Jan, 18:28, robert bristow-johnson <r...@audioimagination.com> wrote:> On Jan 27, 11:35�am, Rob <robert.bie...@xponaut.se> wrote: > > > On 26 Jan, 17:32, Andre <lod...@pathme.de> wrote: > > > > The lazy solution: > > > 1. generate a "noise" consisting of random 1 and -1 (crest factor = 1) > > > 2. insert a single randomly placed sample with the desired crest factor > > > as its amplitude > > > Nope, that won't work. Crest factor == Peak/RMS. I doubt that the RMS > > of the noise will change significantly with > > that single sample insertion. > > but Andre is saying that the *peak* will change. �even by a single > sample.Ah... yeah. Now I see it, my eyes kind of filtered out that the noise was just 1's and -1's (sorry Andre ;) But anyway, it is lazy as the solution will have no practical value... /R
Reply by ●January 28, 20112011-01-28
On Jan 27, 2:34�pm, Rob <robert.bie...@xponaut.se> wrote:> On 27 Jan, 18:28, robert bristow-johnson <r...@audioimagination.com> > wrote: > > > On Jan 27, 11:35�am, Rob <robert.bie...@xponaut.se> wrote: > > > > On 26 Jan, 17:32, Andre <lod...@pathme.de> wrote: > > > > > The lazy solution: > > > > 1. generate a "noise" consisting of random 1 and -1 (crest factor = 1) > > > > 2. insert a single randomly placed sample with the desired crest factor > > > > as its amplitude > > > > Nope, that won't work. Crest factor == Peak/RMS. I doubt that the RMS > > > of the noise will change significantly with > > > that single sample insertion. > > > but Andre is saying that the *peak* will change. �even by a single > > sample. > > Ah... yeah. Now I see it, my eyes kind of filtered out that the noise > was just 1's and -1's (sorry Andre ;) > > But anyway, it is lazy as the solution will have no practical value...yup. r b-j
On 27.01.2011 20:34, Rob wrote:> On 27 Jan, 18:28, robert bristow-johnson<r...@audioimagination.com> > wrote: >> On Jan 27, 11:35 am, Rob<robert.bie...@xponaut.se> wrote: >> >>> On 26 Jan, 17:32, Andre<lod...@pathme.de> wrote: >> >>>> The lazy solution: >>>> 1. generate a "noise" consisting of random 1 and -1 (crest factor = 1) >>>> 2. insert a single randomly placed sample with the desired crest factor >>>> as its amplitude >> >>> Nope, that won't work. Crest factor == Peak/RMS. I doubt that the RMS >>> of the noise will change significantly with >>> that single sample insertion. >> >> but Andre is saying that the *peak* will change. even by a single >> sample. > > Ah... yeah. Now I see it, my eyes kind of filtered out that the noise > was just 1's and -1's (sorry Andre ;) > > But anyway, it is lazy as the solution will have no practical value... > > /RIt may serve to test algorithms that do calculate the crest factor, but certainly not more... Andre
