Hello, Half band filters are good for interpolation and decimation by 2 as they have alternating 0's as their coefficients. Is there something like 1/3rd band filters for doing interpolation and decimation by 3 with in-between 2 coeffcients being 0? Regards Bharat
just like half band filters are ther 1/3 band filters too?
Started by ●February 2, 2011
Reply by ●February 2, 20112011-02-02
On 2/2/2011 6:16 AM, bharat pathak wrote:> Hello, > > Half band filters are good for interpolation and decimation by > 2 as they have alternating 0's as their coefficients. > > Is there something like 1/3rd band filters for doing interpolation > and decimation by 3 with in-between 2 coeffcients being 0? > > Regards > BharatI don't think so.... let's see: Properties of the half-band filter are that it's always odd-ordered and that it's frequency response is real because it's even in time. If you leave out the center coefficient it's an even-ordered filter with sample rate at fs/2 and it's antisymmetric H(0>fs/4) = -H(fs/2>fs/4) and H(fs>3fs/4) = -H(fs/2>3fs/4) looking sorta like a "square wave" which obviously has zero values at fs/4 and 3fs/4 Then, reintroducing the center coefficient brings the sample rate to fs and "dc biases" the frequency response (it being purely real) so that the center frequencies go from negative values to zero .. becoming the stop band. It's the antisymmetric quality that ties with the periodic zeros in the time response. So, looking at the "filter" without the center coefficient, the filter sample rate is fs/2 and you get those zeros in time that you mentioned. If you had a filter structure with those zeros in time that you want then, for starters, the underlying filter would have a sample rate of fs/3. If that's the case then the filter couldn't be antisymmetric and, it would also be difficult to figure out what to do in the center of the coefficient structure because now there'd be two zeros to fill instead of just one and I guess the filter order would remain even, eh? I'm sorry if this isn't a more robust description of the relationships betweem time and frequency but I'm in a bit of a hurry right now. One question might be then is there a similar sorta lowpass filter where the sample rate is fs/3? I just can't imagine... But there may be. Perhaps a viable approach would be to interpolate by 6 and then decimate by 2 (I have no idea .. it's just a thought as there are similar approaches I've read about) - or to just bite the bullet and forget about the zero coefficients once and for all. Or a compromise might be to have a "transition/stop" band with the first cutoff frequency at fs/6 but just keeping the normal half-band structure with half the coefficients zero. After all, this is pre-decimation or interpolation at fs, right? Fred
On Feb 2, 6:16�am, "bharat pathak" <bharat@n_o_s_p_a_m.arithos.com> wrote:> Hello, > > � � �Half band filters are good for interpolation and decimation by > � � �2 as they have alternating 0's as their coefficients. > > � � �Is there something like 1/3rd band filters for doing interpolation > � � �and decimation by 3 with in-between 2 coeffcients being 0? > > Regards > BharatNth band filters seem to have one zero coefficient in N, not N-1 zero coefficients in N. See: On half-band, third-band, and Nth-band FIR filters and their design Mintzer, F. IBM Thomas J. Watson Research Center, Yorktown Heights, NY Acoustics, Speech and Signal Processing, IEEE Transactions on Oct 1982, Volume: 30, Issue: 5, page(s): 734 - 738 Dale B. Dalrymple
Reply by ●February 4, 20112011-02-04
On 2/2/2011 6:11 PM, bharat pathak wrote:> Thanks Fred. >Well, I said" Or a compromise might be to have a "transition/stop" band with the first cutoff frequency at fs/6 but just keeping the normal half-band structure with half the coefficients zero. After all, this is pre-decimation or interpolation at fs, right? But that's not sensible because I was thinking about the fs/2 rate filter and not the fs rate filter with the center coefficient nonzero. When the frequency response is "lifted" with the center coefficient, any original stop band becomes a filter with value 0.5 or thereabouts. And that's obviously not what you want. Fred
On 2/2/2011 1:51 PM, dbd wrote:> On Feb 2, 6:16 am, "bharat pathak"<bharat@n_o_s_p_a_m.arithos.com> > wrote: >> Hello, >> >> Half band filters are good for interpolation and decimation by >> 2 as they have alternating 0's as their coefficients. >> >> Is there something like 1/3rd band filters for doing interpolation >> and decimation by 3 with in-between 2 coeffcients being 0? >> >> Regards >> Bharat > > Nth band filters seem to have one zero coefficient in N, not N-1 zero > coefficients in N. > > See: > On half-band, third-band, and Nth-band FIR filters and their design > Mintzer, F. > IBM Thomas J. Watson Research Center, Yorktown Heights, NY > Acoustics, Speech and Signal Processing, IEEE Transactions on > Oct 1982, Volume: 30, Issue: 5, page(s): 734 - 738 > > Dale B. DalrympleDale, Interesting. I'd not seen this one before. It makes me imagine this: As we well know, given some fs, the perfect reconsctruction filter has a sinc/Dirichlet time response with periodic zeros. This corresponds to a lowpass filter with cutoff at fs/2. A classic halfband filter has the same zero periodicity at twice the interval (2T=2/fs) and a cutoff at fs/4. A narrower filter with the same *type* of response will have those zeros further apart. So, it's not much of a stretch to think there are filters with periodic zeros in the coefficient structure - directly related to the frequency response. This also suggests a relationship with the Gibby-Smith criterion for bandlimited functions that aren't "brick wall" bandlimited and still have periodic zeros.R. A. Gibby and J. W. Smith, �Some extensions of Nyquist�s telegraph transmission theory,� Bell Syst. Tech. J., vol. XLIV, pp. 1487-1510, Sept. 1965. But, I'm afraid that lots of the neat properties of the classic half-band filter are lost. And, the number of zero coefficients dimishes pretty quickly as I>2. Fred
