On Tuesday, February 8, 2011 11:39:55 AM UTC-5, Tim Wescott wrote: ...> Robert, there's a heck of a lot more different types of phase detectors==20> than just multiplying the two waveforms together. Each one has its own==20> impact on how the loop behaves, some making it easier to design the=20 > loop, some harder. So far you seem stuck on the "phase detector=20 > multiplies signals" concept, and can't seem to move beyond it.I will amplify that. Again, the CD4046 provides elementary examples. The ch= ip has two phase detectors and pins to connect either of them. One is an XO= R with, IIRC, Schmidt-trigger inputs, and the other is a state machine that= compares the timing of rising edges. The XOR provides a quadrature lock an= d the characteristics you know. The edge detector provides an in-phase lock= and guaranteed eventual lock-up provided the oscillator's range makes that= possible. You notes your needs and you makes your choice. I think you'll f= ind the data sheet worth looking at. Jerry
Re: Software PLL - the math that i did looks too simple to be true - please confrim
Started by ●February 9, 2011
