Dear group, I have a question in configuring multi channel McBSP. if XMCM =01,PHASE=0, XFRLEN =0, XWDLEN =010b, and I want to enable a 16 bit channel, say channel 1, I should set XCERA = 3(enable time slot 0 and 1) or just set XCERA = 1 ? Thanks in advance! Ron
Configure multi channel McBSP
Started by ●March 4, 2011
Reply by ●March 5, 20112011-03-05
On 2011/03/04 08:47, y17476 wrote:> I have a question in configuring multi channel McBSP. > > if XMCM =01,PHASE=0, XFRLEN =0, XWDLEN =010b, and I want to enable a 16 bit > channel, say channel 1, I should set XCERA = 3(enable time slot 0 and 1) > or just set XCERA = 1 ?For this level of detail, you should probably mention which processor you are using! Also, Texas Instruments' Engineer-to-engineer forum might be a better venue for your question if you haven't already asked there. Brian Willoughby Sound Consulting
