Hey all, Recently at work I've come upon an interesting challenge (luckily it's not something I need to do FOR work, so there is no hard deadline). Some of you might be aware of the old "teletext" system that was used to convey reasonably static "pages" of information to television sets, during the Vertical Blanking Interval - a period of time in which the electron gun is moving from the bottom corner of the screen back up to the top corner to commence drawing the next field of vision - because there is no need to transmit visual information at this point, other forms of information (such as lines of teletext pages) may be transmitted. Very very briefly, there are approx. 16 video lines per field of vision available to carry data. For PAL-SD video, there are 720 pixels (or samples) per line. The EBU-WST specification defines the parameters for encoding 45 bytes (360 bits) of data into these 720 samples (actually, a number of samples at the beginning and end of the line are not utilised). I'm keen to learn how to generate the 720 samples from the original 45 bytes (and preferably to also work backwards from a line of 720 samples to 45 bytes of data). Previously I have seen this conversion done using an FIR filter. This has lead me to start reading "Understanding digital signal processing", as I think this is the right place to start. Having started to read this book, I've realized my general knowledge of mathematics is pretty poor these days. I guess the questions I have right now are: - What are the mathematical topics generally required when learning / working with DSP? - Can anyone recommend a good book for re-learning these topics? - Am I on the right track, studying DSP (esp. FIR filters) to eventually understand how to go from 360 bits to 720 samples? Cheers, James
Where should I begin
Started by ●March 6, 2011
Reply by ●March 6, 20112011-03-06
james.fysh <james.fysh@gmail.com> wrote:> Recently at work I've come upon an interesting challenge (luckily it's > not something I need to do FOR work, so there is no hard deadline). > Some of you might be aware of the old "teletext" system that was used > to convey reasonably static "pages" of information to television sets, > during the Vertical Blanking Interval - a period of time in which the > electron gun is moving from the bottom corner of the screen back up to > the top corner to commence drawing the next field of vision - because > there is no need to transmit visual information at this point, other > forms of information (such as lines of teletext pages) may be > transmitted.Some of that is still there. One use is for closed captions. Also, I have a DVD recorder connected to the output of a DTV converter box, and it knows the name of the programs it records. That must be somewhere in the analog signal, and VBI seems a good place. -- glen
On Mar 7, 11:41=A0am, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> james.fysh <james.f...@gmail.com> wrote: > > Recently at work I've come upon an interesting challenge (luckily it's > > not something I need to do FOR work, so there is no hard deadline). > > Some of you might be aware of the old "teletext" system that was used > > to convey reasonably static "pages" of information to television sets, > > during the Vertical Blanking Interval - a period of time in which the > > electron gun is moving from the bottom corner of the screen back up to > > the top corner to commence drawing the next field of vision - because > > there is no need to transmit visual information at this point, other > > forms of information (such as lines of teletext pages) may be > > transmitted. > > Some of that is still there. =A0 One use is for closed captions.Indeed - that's what we're using it for at work. I think closed captions are one of the few reasons that VBI has held on for so long. Recent standards for digital broadcast (DVB) include methods for carrying the 45-byte VBI data in a digital representation, and presumably most modern DVB-Set-top boxes have software/hardware in them for re-creating the 720-luma samples to output as composite/ component video so that the tv set may then capture and decode those samples back into teletext pages/captions for display!> > Also, I have a DVD recorder connected to the output of a DTV > converter box, and it knows the name of the programs it records. > That must be somewhere in the analog signal, and VBI seems a > good place.Very interesting - so it is connected via composite / component and no digital (e.g. EIT / EPG) information can possibly be making its way to the DVD recorder?> > -- glen
Reply by ●March 7, 20112011-03-07
On Sun, 06 Mar 2011 13:55:26 -0800, james.fysh wrote:> Hey all, > > Recently at work I've come upon an interesting challenge (luckily it's > not something I need to do FOR work, so there is no hard deadline). Some > of you might be aware of the old "teletext" system that was used to > convey reasonably static "pages" of information to television sets, > during the Vertical Blanking Interval - a period of time in which the > electron gun is moving from the bottom corner of the screen back up to > the top corner to commence drawing the next field of vision - because > there is no need to transmit visual information at this point, other > forms of information (such as lines of teletext pages) may be > transmitted. > > Very very briefly, there are approx. 16 video lines per field of vision > available to carry data. For PAL-SD video, there are 720 pixels (or > samples) per line. The EBU-WST specification defines the parameters for > encoding 45 bytes (360 bits) of data into these 720 samples (actually, a > number of samples at the beginning and end of the line are not > utilised). I'm keen to learn how to generate the 720 samples from the > original 45 bytes (and preferably to also work backwards from a line of > 720 samples to 45 bytes of data). > > Previously I have seen this conversion done using an FIR filter. This > has lead me to start reading "Understanding digital signal processing", > as I think this is the right place to start. Having started to read > this book, I've realized my general knowledge of mathematics is pretty > poor these days. > > I guess the questions I have right now are: - What are the mathematical > topics generally required when learning / working with DSP?Algebra, trigonometry, and calculus. Knowing differential equations doesn't hurt.> - Can anyone recommend a good book for re-learning these topics? -That's a Really Good question -- and I have no clue for the answers! If you find any titles with previews, post them here and if I'm not inundated with work I'll see if I can help out. Here's the title you want: "All That Math You Thought You'd Never Need, and Now You Do".> Am I > on the right track, studying DSP (esp. FIR filters) to eventually > understand how to go from 360 bits to 720 samples?Without knowing just how they're massaging the data to get samples -- maybe. It's probably simpler than that. Certainly if you have the grounding to know enough DSP to understand FIR filters, you'll have the grounding you need to understand the modulation of digital data. -- http://www.wescottdesign.com
The data is just binary encoded and resampled to just under 2 samples per b= it (check the standard for the exact number, it won't be the entire 720 sam= ples). What you need to do for generating this stuff is just create the binary rep= resentation of the data and whatever headers, etc. are necessary. Then resa= mple it to the right rate. That's about it. It's a fractional upsampling ra= te, so you can either upsample by (lets say it's 1.9 samples/bit) 19 then d= ownsample by 10 (read up on requirements for filters for resampling) or lea= rn about polyphase filters if you want to do it on the fly. The standard mi= ght also call for something like manchester encoding - see wikipedia - but = I don't believe teletext uses that, I think it's just binary - check the st= andard to be sure. Chris
james.fysh <james.fysh@gmail.com> wrote: (snip, I wrote)>> Also, I have a DVD recorder connected to the output of a DTV >> converter box, and it knows the name of the programs it records. >> That must be somewhere in the analog signal, and VBI seems a >> good place.> Very interesting - so it is connected via composite / component and no > digital (e.g. EIT / EPG) information can possibly be making its way to > the DVD recorder?S-video, so the resolution isn't so bad as composite. It would be nice to know the name for the actual signal, as the local PBS station doesn't seem to use it. It isn't the one used for the DISPLAY feature of HDTVs. -- glen
Tons of it is still there. The broadcast world is chock full of data packet= s for all sorts of stuff, AFD, closed captions, timecode, audio, various au= tomation standards, etc. SMPTE, the standards body for most of this stuff, = has 75 different packet types registered. Except audio, closed captions, an= d a couple others, much of it never leaves the broadcast facility, but it's= critical in that space. H and V blanking are never going away at least par= tially for that reason. In the standard definition world, some of that stuff is encoded as analog w= aveforms (i.e. closed captions), effectively as PCM, in what is otherwise h= andled by broadcasters as a digital stream. Chris
Thanks for all the info - I think I'll just bury my head in books for a while. Speaking of that, I'm trying to work through the problems sections in Understanding Digital Signal Processing and getting stuck. There don't seem to be any solutions in the book, or elsewhere that I can find (googling for "understanding digital signal processing" just brings up hundreds of sites offering pirated copies of the book.. sad :(). Is there anywhere in particular I can look for solutions or hints - otherwise my self-study sessions are going to be very long and slow!
On Mar 6, 4:55=A0pm, "james.fysh" <james.f...@gmail.com> wrote:> Hey all, > > Recently at work I've come upon an interesting challenge (luckily it's > not something I need to do FOR work, so there is no hard deadline). > Some of you might be aware of the old "teletext" system that was used > to convey reasonably static "pages" of information to television sets, > during the Vertical Blanking Interval - a period of time in which the > electron gun is moving from the bottom corner of the screen back up to > the top corner to commence drawing the next field of vision - because > there is no need to transmit visual information at this point, other > forms of information (such as lines of teletext pages) may be > transmitted. > > Very very briefly, there are approx. 16 video lines per field of > vision available to carry data. =A0For PAL-SD video, there are 720 > pixels (or samples) per line. =A0The EBU-WST specification defines the > parameters for encoding 45 bytes (360 bits) of data into these 720 > samples (actually, a number of samples at the beginning and end of the > line are not utilised). =A0I'm keen to learn how to generate the 720 > samples from the original 45 bytes (and preferably to also work > backwards from a line of 720 samples to 45 bytes of data). > > Previously I have seen this conversion done using an FIR filter. =A0This > has lead me to start reading "Understanding digital signal > processing", as I think this is the right place to start. =A0Having > started to read this book, I've realized my general knowledge of > mathematics is pretty poor these days. > > I guess the questions I have right now are: > - What are the mathematical topics generally required when learning / > working with DSP? > - Can anyone recommend a good book for re-learning these topics? > - Am I on the right track, studying DSP (esp. FIR filters) to > eventually understand how to go from 360 bits to 720 samples? > > Cheers, > > JamesYou can try my website: www.fourier-series.com It covers fourier series, complex numbers, DFT, Fourier transform, convolution, digital convolution and some basic FIR theory.
On Mar 6, 10:55=A0pm, "james.fysh" <james.f...@gmail.com> wrote:> I guess the questions I have right now are: > - What are the mathematical topics generally required when learning / > working with DSP? > - Can anyone recommend a good book for re-learning these topics?Any maths book by Gilbert Strang: http://www.amazon.com/s/ref=3Dnb_sb_noss?url=3Dsearch-alias%3Daps&field-key= words=3Dgilbert+strang Rune
