Do not install the Update 9 for BlackFin Visual DSP ! It is buggy. It crashes by itself and it messes up perfectly working code, which is much worse. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
VDSP Update 9 bullshit
Started by ●March 11, 2011
Reply by ●March 11, 20112011-03-11
Thanks for the warning. Have you informed AD? Jerry -- Engineering is the art of making what you want from things you can get.
Reply by ●March 12, 20112011-03-12
> Vladimir Vassilevsky wrote: > >> >> Do not install the Update 9 for BlackFin Visual DSP ! It is buggy. It >> crashes by itself and it messes up perfectly working code, which is much >> worse.Jerry Avins wrote:> Thanks for the warning. Have you informed AD?Sure. As well as many times before. Very frustrating. When the software thing is called "update", one could expect an improvement in reliability, not vice versa. The DSP endeavors of AD make impression of nice concept, but poorly lacking realization. As the opposite, what TI does is dumb and dull, however it works within its limits. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●March 13, 20112011-03-13
On Mar 12, 10:20�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> > Vladimir Vassilevsky wrote: > > >> Do not install the Update 9 for BlackFin Visual DSP ! It is buggy. It > >> crashes by itself and it messes up perfectly working code, which is much > >> worse. > Jerry Avins wrote: > > Thanks for the warning. Have you informed AD? > > Sure. As well as many times before. > > Very frustrating. When the software thing is called "update", one could > expect an improvement in reliability, not vice versa. > > The DSP endeavors of AD make impression of nice concept, but poorly > lacking realization. As the opposite, what TI does is dumb and dull, > however it works within its limits. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comThanks a lot... I was thinking of updating VDSP from update 8 to update 9 Regards Shafi
