Formula to Find Resonant Frequencies?
Started by Raeldor March 12, 2011
On Sun, 13 Mar 2011 13:33:24 -0700, Jerry Avins wrote:
> Tim's setup -- a microphone, amplifier, and speaker -- provides an easy > to find the dominant resonance. Just turn the gain up until acoustic > feedback makes the system howl. The frequency of the howl is the > strongest resonance. A notch filter that blocks that frequency will show > the next weaker resonance.
You're crediting me with more sense than I showed -- mine was the "guy with education and no experience" approach, i.e. do a measurement and then do some system ID. (Although, if you use a swept sine wave for the measurement, then the resonances will pop out at you when you make a Bode plot). -- http://www.wescottdesign.com
On Mar 14, 9:33&#4294967295;am, Jerry Avins <j...@ieee.org> wrote:
> Tim's setup -- a microphone, amplifier, and speaker -- &#4294967295;provides an easy to find the dominant resonance. Just turn the gain up until acoustic feedback makes the system howl. The frequency of the howl is the strongest resonance. A notch filter that blocks that frequency will show the next weaker resonance. > > Jerry > -- > Engineering is the art of making what you want from things you can get.
Wonder if you can demolish a house that way if the dB level is strong enough? (from the inside!) Hardy
On Mar 13, 12:01&#4294967295;am, Raeldor <rael...@gmail.com> wrote:
> Hi All, > > Is there a formula or mathematical concept to find the resonant > frequencies in a sound wave?
No. Resonance moght be a property of the scenario in which the sound propagates. I say 'might be' because resonance may or may not exist (it usually doesn't). Rune
I don't know about from the inside, but consider the walls of Jericho. :-)
Jerry
Jerry Avins wrote:
> I don't know about from the inside, but consider the walls of Jericho. :-) > > Jerry
Or more recently the Tacoma Narrows bridge. Youngsters see http://en.wikipedia.org/wiki/Tacoma_Narrows_Bridge_(1940)
Rune Allnor wrote:
> Resonance moght be a property of the scenario in which the > sound propagates. I say 'might be' because resonance may > or may not exist (it usually doesn't). > > Rune
I had such a case once in a 'Discothek'; At certain Frequencies the 50x40cm metal casing of the aircondition canal, at a certain distance from the speakers, was just _SCREAMING_ at you :-P -rasp
Well,
94 dB SPL (sound pressue level) is 1 Pa.
Athmospheric pressure is about 100.000 Pa.
Therefore, 194 dB SPL would result in cavitation, probably crashing a
house...
On 14.03.2011 06:56, HardySpicer wrote:
> On Mar 14, 9:33 am, Jerry Avins<j...@ieee.org> wrote: >> Tim's setup -- a microphone, amplifier, and speaker -- provides an easy to find the dominant resonance.
>> >> Jerry >> -- >> Engineering is the art of making what you want from things you can get. > > Wonder if you can demolish a house that way if the dB level is strong > enough? (from the inside!) > > > Hardy
