levinson durbin algorithm
Started by John McDermick March 14, 2011
Why does the 10th order levinson durbin algorithm return these LP
coefficients
LPC
                         1
         -141.987085255646
          379.380008989783
         -652.562624856013
          914.226857127382
         -1069.00679555295
          1068.49193530997
         -912.915274765544
          650.564278635448
         -377.394102649473
           140.21469138077
for this autocorrelation sequence :
                         1
         0.954887218045113
         0.892857142857143
         0.887218045112782
         0.892857142857143
          0.87406015037594
         0.862781954887218
         0.868421052631579
         0.862781954887218
         0.849624060150376
         0.847744360902256
If I use this (similar) autocorrelation sequence
                         1
         0.955932203389831
                       0.9
         0.896610169491525
         0.903389830508475
         0.884745762711864
         0.871186440677966
         0.869491525423729
         0.855932203389831
         0.838983050847458
         0.832203389830508
I get these LP coefficients:
                         1
         -1.34686071095947
          1.06567003975718
         -0.75978856644957
        0.0294126810016533
         0.258696591668145
        -0.319917626183194
        0.0360131660377147
         0.155615320440029
        -0.201467558173645
         0.101029788353466
Normally, the LP coefficients are in the range from -12 to 12 ...but
for certain autocorrelation sequences the numbers just blow
up....What's the reason? How do you handle these special cases?
On Mar 14, 9:47&#2013266080;pm, John McDermick <johnthedsp...@gmail.com> wrote:
> Why does the 10th order levinson durbin algorithm return these LP > coefficients
> Normally, the LP coefficients are in the range from -12 to 12 ...but > for certain autocorrelation sequences the numbers just blow > up....What's the reason? How do you handle these special cases?
Use some sort of order estimator. Rune
Rune Allnor wrote:
> On Mar 14, 9:47 pm, John McDermick <johnthedsp...@gmail.com> wrote: > >>Why does the 10th order levinson durbin algorithm return these LP >>coefficients > > .... > >>Normally, the LP coefficients are in the range from -12 to 12 ...but >>for certain autocorrelation sequences the numbers just blow >>up....What's the reason? How do you handle these special cases? > > > Use some sort of order estimator.
In the audio applications, they usually apply some fudge factors to the ACF coefficients, decreasing ACF from lower to higher orders. This could be thought of as an addition of the colored noise to the signal, making LPC model dull and stable. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
The Levinson recursion involves inverting the covariance matrix
toeplitz(r), and the first one is poorly conditioned. You can see this in
matlab by setting the first autocorrelation vector to r, and the second one
to r2.
You will find that cond(toeplitz(r)) = 9.3491e+004, and cond(toeplitz(r2))
= 3.0142e+003. The first condition value is much larger, which indicates
the accuracy of the results of a matrix inversion.
>Why does the 10th order levinson durbin algorithm return these LP >coefficients > > >LPC > > 1 > -141.987085255646 > 379.380008989783 > -652.562624856013 > 914.226857127382 > -1069.00679555295 > 1068.49193530997 > -912.915274765544 > 650.564278635448 > -377.394102649473 > 140.21469138077 > >for this autocorrelation sequence : > > 1 > 0.954887218045113 > 0.892857142857143 > 0.887218045112782 > 0.892857142857143 > 0.87406015037594 > 0.862781954887218 > 0.868421052631579 > 0.862781954887218 > 0.849624060150376 > 0.847744360902256 > > >If I use this (similar) autocorrelation sequence > > > 1 > 0.955932203389831 > 0.9 > 0.896610169491525 > 0.903389830508475 > 0.884745762711864 > 0.871186440677966 > 0.869491525423729 > 0.855932203389831 > 0.838983050847458 > 0.832203389830508 > >I get these LP coefficients: > > 1 > -1.34686071095947 > 1.06567003975718 > -0.75978856644957 > 0.0294126810016533 > 0.258696591668145 > -0.319917626183194 > 0.0360131660377147 > 0.155615320440029 > -0.201467558173645 > 0.101029788353466 > > >Normally, the LP coefficients are in the range from -12 to 12 ...but >for certain autocorrelation sequences the numbers just blow >up....What's the reason? How do you handle these special cases? > >
