Hi All, I am trying to implement a Fast Fourier Transform, followed by an Inverse FFT on the iPhone in Objective-C. To do this I am using the functions within the 'rvfft.cpp' file available here: http://www.musicdsp.org/archive.php?classid=2#79 I am trying to perform the operation on an array of doubles of length 131072 (padded with zeros to ensure it is divisible by 2). My code is below, and the operation seems to be working, Theoretically performing the IFFT directly on the output of the FFT (with no additional processing) should reproduce the original signal (obviously not in infinite precision detail, but this is irrelevant at the moment). However, the output (which I have written to a WAV file using a function i know to work correctly) contains a LOT of noise. You can hear the content from the original array of doubles (which is a sine wave sweep), but under the sound of what appears to be noise. My Code is below, I wonder if any of you kind people have any suggestions? double * CFArray3; CFArray3 = (double *)malloc((CFArray1Size)* sizeof(double)); CFArray3 = CFArray1; long size = CFArray1Size; //FFT Algo's //TODO: Currently introduce noise?! realfft_radix2(CFArray3,CFArray1Size); //IFFT irealfft_split(CFArray3,CFArray1Size); The realfft_radix2 function: void realfft_radix2(double *data,long n){ float pi = 3.141592653589793238462643; double xt,a,e, t1, t2, cc, ss; long i, j, k, n1, n2, n3, n4, i1, i2, i3, i4; n4=n-1; //data shuffling for (i=0,j=0,n2=n/2; i<n4 ; i++){ if (i<j){ xt=data[j]; data[j]=data[i]; data[i]=xt; } k=n2; while (k<=j){ j-=k; k>>=1; } j+=k; } /* -------------------- */ for (i=0; i<n; i += 2) { xt = data[i]; data[i] = xt + data[i+1]; data[i+1] = xt - data[i+1]; } /* ------------------------ */ n2 = 1; for (k=n;k>2;k>>=1){ n4 = n2; n2 = n4 << 1; n1 = n2 << 1; e = 2*pi/(n1); for (i=0; i<n; i+=n1){ xt = data[i]; data[i] = xt + data[i+n2]; data[i+n2] = xt-data[i+n2]; data[i+n4+n2] = -data[i+n4+n2]; a = e; n3=n4-1; for (j = 1; j <=n3; j++){ i1 = i+j; i2 = i - j + n2; i3 = i1 + n2; i4 = i - j + n1; cc = cos(a); ss = sin(a); a += e; t1 = data[i3] * cc + data[i4] * ss; t2 = data[i3] * ss - data[i4] * cc; data[i4] = data[i2] - t2; data[i3] = -data[i2] - t2; data[i2] = data[i1] - t1; data[i1] += t1; } } } //division with array length for(i=0;i<n;i++) data[i]/=n; } The irealfft_split function: void irealfft_split(double *data,long n){ long i,j,k,i5,i6,i7,i8,i0,idd,i1,i2,i3,i4,n2,n4,n8,n1; double t1,t2,t3,t4,t5,a3,ss1,ss3,cc1,cc3,a,e,sqrt2; float pi = 3.141592653589793238462643; sqrt2=sqrt(2.0); n1=n-1; n2=n<<1; for(k=n;k>2;k>>=1){ idd=n2; n2>>=1; n4=n2>>2; n8=n2>>3; e = 2*pi/(n2); i1=0; do{ for (; i1<n; i1+=idd){ i2=i1+n4; i3=i2+n4; i4=i3+n4; t1=data[i1]-data[i3]; data[i1]+=data[i3]; data[i2]*=2; data[i3]=t1-2*data[i4]; data[i4]=t1+2*data[i4]; if (n4!=1){ i0=i1+n8; i2+=n8; i3+=n8; i4+=n8; t1=(data[i2]-data[i0])/sqrt2; t2=(data[i4]+data[i3])/sqrt2; data[i0]+=data[i2]; data[i2]=data[i4]-data[i3]; data[i3]=2*(-t2-t1); data[i4]=2*(-t2+t1); } } idd<<=1; i1=idd-n2; idd<<=1; } while ( i1<n1 ); a=e; for (j=2; j<=n8; j++){ a3=3*a; cc1=cos(a); ss1=sin(a); cc3=cos(a3); ss3=sin(a3); a=j*e; i=0; idd=n2<<1; do{ for (; i<n; i+=idd){ i1=i+j-1; i2=i1+n4; i3=i2+n4; i4=i3+n4; i5=i+n4-j+1; i6=i5+n4; i7=i6+n4; i8=i7+n4; t1=data[i1]-data[i6]; data[i1]+=data[i6]; t2=data[i5]-data[i2]; data[i5]+=data[i2]; t3=data[i8]+data[i3]; data[i6]=data[i8]-data[i3]; t4=data[i4]+data[i7]; data[i2]=data[i4]-data[i7]; t5=t1-t4; t1+=t4; t4=t2-t3; t2+=t3; data[i3]=t5*cc1+t4*ss1; data[i7]=-t4*cc1+t5*ss1; data[i4]=t1*cc3-t2*ss3; data[i8]=t2*cc3+t1*ss3; } idd<<=1; i=idd-n2; idd<<=1; } while(i<n1); } } /*----------------------*/ i0=0; idd=4; do{ for (; i0<n1; i0+=idd){ i1=i0+1; t1=data[i0]; data[i0]=t1+data[i1]; data[i1]=t1-data[i1]; } idd<<=1; i0=idd-2; idd<<=1; } while ( i0<n1 ); /*----------------------*/ //data shuffling for (i=0,j=0,n2=n/2; i<n1 ; i++){ if (i<j){ t1=data[j]; data[j]=data[i]; data[i]=t1; } k=n2; while (k<=j){ j-=k; k>>=1; } j+=k; } }
IFFT
Started by ●March 15, 2011
Reply by ●March 16, 20112011-03-16
On Mar 15, 2:45�pm, Sam Harman <samm...@gmail.com> wrote:> Hi All, > > I am trying to implement a Fast Fourier Transform, followed by an > Inverse FFT on the iPhone in Objective-C. To do this I am using the > functions within the 'rvfft.cpp' file available here:http://www.musicdsp.org/archive.php?classid=2#79 > > I am trying to perform the operation on an array of doubles of length > 131072 (padded with zeros to ensure it is divisible by 2). My code is > below, and the operation seems to be working, Theoretically performing > the IFFT directly on the output of the FFT (with no additional > processing) should reproduce the original signal (obviously not in > infinite precision detail, but this is irrelevant at the moment). > > However, the output (which I have written to a WAV file using a > function i know to work correctly) contains a LOT of noise. You can > hear the content from the original array of doubles (which is a sine > wave sweep), but under the sound of what appears to be noise.Those are two steps that mighe be messed up: The FFT/IFFT pair and writing the data back to .wav file. Are you sure the file I/O functions work as expected? Did you remember to only export the real part of the resulting data set? Apart from that, test your code with some other mans than your ears. Use a small signal (length 8 or so) and do a numerical comparision between the input signal and the output of the IFFT. Rune
On Mar 16, 12:27�am, Rune Allnor <all...@tele.ntnu.no> wrote:> On Mar 15, 2:45�pm, Sam Harman <samm...@gmail.com> wrote: > > > > > > > Hi All, > > > I am trying to implement a Fast Fourier Transform, followed by an > > Inverse FFT on the iPhone in Objective-C. To do this I am using the > > functions within the 'rvfft.cpp' file available here:http://www.musicdsp.org/archive.php?classid=2#79 > > > I am trying to perform the operation on an array of doubles of length > > 131072 (padded with zeros to ensure it is divisible by 2). My code is > > below, and the operation seems to be working, Theoretically performing > > the IFFT directly on the output of the FFT (with no additional > > processing) should reproduce the original signal (obviously not in > > infinite precision detail, but this is irrelevant at the moment). > > > However, the output (which I have written to a WAV file using a > > function i know to work correctly) contains a LOT of noise. You can > > hear the content from the original array of doubles (which is a sine > > wave sweep), but under the sound of what appears to be noise. > > Those are two steps that mighe be messed up: The FFT/IFFT pair and > writing the data back to .wav file. Are you sure the file I/O > functions > work as expected? Did you remember to only export the real part > of the resulting data set? > > Apart from that, test your code with some other mans than your ears. > Use a small signal (length 8 or so) and do a numerical comparision > between the input signal and the output of the IFFT. > > Rune- Hide quoted text - > > - Show quoted text -Your forward/inverse code produces errors starting at about the 8th decimal digit. Changing �float pi = 3.14.....� to �double pi = 3.14...� shows errors starting at about the 16th decimal digit. I don't know if this is the source of your problem � there could be other(s). Kevin McGee
