Hello all, I started studying ADC design and FPGA clocking and I have a lot of questions. I would like to know if small signals that is in between the voltage full-scale measurement range digitized with the same amount of resolution? If it isn't so, is there a way such that the ADC is designed so that no matter what the input amplitude is, the adc always digitizes it at full (or near full to avoid saturation) resolution (ie vary the reference voltage to the ADC)? As for the interface between ADC and FPGA, if the ADC is running at 150 MHz, at what clock frequency does the FIFO have to be (I believe it is going to be the same thing). Can DSP blocks inside an FPGA be higher (or lower) than the input? For instance if I create a 2x upsampling block, followed by a low-pass filter, then 2x decimation (I'm just making stuff up) can they run at different frequencies? Does it makes sense for an FPGA run at its maximum frequency, higher than the ADC frequency? Thank you for your inputs.
ADC design and FPGA clocking (timing)
Started by ●March 23, 2011
Reply by ●March 23, 20112011-03-23
On 03/23/2011 09:43 AM, pacman101 wrote:> Hello all, > > I started studying ADC design and FPGA clocking and I have a lot of > questions. > > I would like to know if small signals that is in between the voltage > full-scale measurement range digitized with the same amount of resolution?So, for instance, if full range is 2.5V, then can you convert a 1V signal with the full resolution of the ADC? How? You need the ADC to know that the signal is at 1V, then you need to -- well, you get the idea.> If it isn't so, is there a way such that the ADC is designed so that no > matter what the input amplitude is, the adc always digitizes it at full (or > near full to avoid saturation) resolution (ie vary the reference voltage to > the ADC)?In theory you can do this. In practice, many stages in the ADC are sensitive to absolute voltage differences rather than ratiometric ones. Noise and offsets, in particular, are going to be in volts (or amps), not in proportions of the full range. So if you measure thingsn in ADC counts, then your noise and offset would certainly go up, and I would expect your integral and differential nonlinearities to go up, too.> As for the interface between ADC and FPGA, if the ADC is running at 150 > MHz, at what clock frequency does the FIFO have to be (I believe it is > going to be the same thing).If the ADC is _converting_ 150 Msps (mega samples/sec), then the FIFO needs to be able to accept that. For most FPGAs this means clocking the FIFO logic with a minimum of 150MHz.> Can DSP blocks inside an FPGA be higher (or lower) than the input? For > instance if I create a 2x upsampling block, followed by a low-pass filter, > then 2x decimation (I'm just making stuff up) can they run at different > frequencies?Yes they can. Running more than one clock domain in an FPGA means that you have to pay careful attention to the signals that cross those clock domains -- but it not only can be done, it is often done.> Does it makes sense for an FPGA run at its maximum frequency, higher than > the ADC frequency?FPGAs don't really have "maximum frequencies". They have a number of different delays for various paths in the device (short paths generally being faster than long ones, kind of). So vendors sell them in "speed grades", and what clock frequencies can be reliably attained with a particular part is heavily dependent on the details of the design. Usually when an FPGA vendor advertises an FPGA speed it's because they've benchmarked the thing with some application that is inherently a good fit for the part, which lets them advertise the highest clock they can. It may indeed make sense for an FPGA to run at a higher frequency than the ADC (and perhaps to run all the FPGA at a high frequency, to avoid multiple clock domains). But the higher you push the frequency of operation, the harder it will be for the design to meet timing. Consistently reaching timing closure with an aggressively fast FPGA design is one of the things that separates the men from the boys when it comes to FPGA design. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
pacman101 <janpac01@n_o_s_p_a_m.yahoo.com> wrote:> I started studying ADC design and FPGA clocking and I have a lot of > questions.> I would like to know if small signals that is in between the voltage > full-scale measurement range digitized with the same amount of resolution? > If it isn't so, is there a way such that the ADC is designed so that no > matter what the input amplitude is, the adc always digitizes it at full (or > near full to avoid saturation) resolution (ie vary the reference voltage to > the ADC)?In the case of DVMs (Digital Volt Meters) this is called autoranging. It was rare for analog meters, but is common for digital meters. It takes some time, and normally comes in discrete steps. In audio systems, it is called AGC or ALC, Automatic (Gain or Level) Control. In this case, unlike the DVM case, one is less concerned with absolute level, and more with the variation of the signal. Consider those two, and compare to the problem you are working on. -- glen
Could you please explain to me exactly what FPGA experts mean by timing or timing closure? Does it have to do with the fact that in reality there are delays as signals pass through the logic circuits? Also, I do not understand how a dsp block processes data rates faster than the input. So say there is a 150 MHz input coming in and I generate a low-pass filter that runs at 200 Mhz, I would think that at the output at certain cycles there is nothing coming out since there isn't enough data coming in. Am I visualizing this correctly?>On 03/23/2011 09:43 AM, pacman101 wrote: >> Hello all, >> >> I started studying ADC design and FPGA clocking and I have a lot of >> questions. >> >> I would like to know if small signals that is in between the voltage >> full-scale measurement range digitized with the same amount ofresolution?> >So, for instance, if full range is 2.5V, then can you convert a 1V >signal with the full resolution of the ADC? > >How? You need the ADC to know that the signal is at 1V, then you need >to -- well, you get the idea. > >> If it isn't so, is there a way such that the ADC is designed so that no >> matter what the input amplitude is, the adc always digitizes it at full(or>> near full to avoid saturation) resolution (ie vary the reference voltageto>> the ADC)? > >In theory you can do this. In practice, many stages in the ADC are >sensitive to absolute voltage differences rather than ratiometric ones. > Noise and offsets, in particular, are going to be in volts (or amps), >not in proportions of the full range. So if you measure thingsn in ADC >counts, then your noise and offset would certainly go up, and I would >expect your integral and differential nonlinearities to go up, too. > >> As for the interface between ADC and FPGA, if the ADC is running at 150 >> MHz, at what clock frequency does the FIFO have to be (I believe it is >> going to be the same thing). > >If the ADC is _converting_ 150 Msps (mega samples/sec), then the FIFO >needs to be able to accept that. For most FPGAs this means clocking the >FIFO logic with a minimum of 150MHz. > >> Can DSP blocks inside an FPGA be higher (or lower) than the input? For >> instance if I create a 2x upsampling block, followed by a low-passfilter,>> then 2x decimation (I'm just making stuff up) can they run at different >> frequencies? > >Yes they can. Running more than one clock domain in an FPGA means that >you have to pay careful attention to the signals that cross those clock >domains -- but it not only can be done, it is often done. > >> Does it makes sense for an FPGA run at its maximum frequency, higherthan>> the ADC frequency? > >FPGAs don't really have "maximum frequencies". They have a number of >different delays for various paths in the device (short paths generally >being faster than long ones, kind of). So vendors sell them in "speed >grades", and what clock frequencies can be reliably attained with a >particular part is heavily dependent on the details of the design. > >Usually when an FPGA vendor advertises an FPGA speed it's because >they've benchmarked the thing with some application that is inherently a >good fit for the part, which lets them advertise the highest clock theycan.> >It may indeed make sense for an FPGA to run at a higher frequency than >the ADC (and perhaps to run all the FPGA at a high frequency, to avoid >multiple clock domains). But the higher you push the frequency of >operation, the harder it will be for the design to meet timing. >Consistently reaching timing closure with an aggressively fast FPGA >design is one of the things that separates the men from the boys when it >comes to FPGA design. > >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.com > >Do you need to implement control loops in software? >"Applied Control Theory for Embedded Systems" was written for you. >See details at http://www.wescottdesign.com/actfes/actfes.html >
On 03/23/2011 01:45 PM, pacman101 wrote: (top posting fixed)>> On 03/23/2011 09:43 AM, pacman101 wrote: >>> Hello all, >>> >>> I started studying ADC design and FPGA clocking and I have a lot of >>> questions. >>> >>> I would like to know if small signals that is in between the voltage >>> full-scale measurement range digitized with the same amount of > resolution? >> >> So, for instance, if full range is 2.5V, then can you convert a 1V >> signal with the full resolution of the ADC? >> >> How? You need the ADC to know that the signal is at 1V, then you need >> to -- well, you get the idea. >> >>> If it isn't so, is there a way such that the ADC is designed so that no >>> matter what the input amplitude is, the adc always digitizes it at full > (or >>> near full to avoid saturation) resolution (ie vary the reference voltage > to >>> the ADC)? >> >> In theory you can do this. In practice, many stages in the ADC are >> sensitive to absolute voltage differences rather than ratiometric ones. >> Noise and offsets, in particular, are going to be in volts (or amps), >> not in proportions of the full range. So if you measure thingsn in ADC >> counts, then your noise and offset would certainly go up, and I would >> expect your integral and differential nonlinearities to go up, too. >> >>> As for the interface between ADC and FPGA, if the ADC is running at 150 >>> MHz, at what clock frequency does the FIFO have to be (I believe it is >>> going to be the same thing). >> >> If the ADC is _converting_ 150 Msps (mega samples/sec), then the FIFO >> needs to be able to accept that. For most FPGAs this means clocking the >> FIFO logic with a minimum of 150MHz. >> >>> Can DSP blocks inside an FPGA be higher (or lower) than the input? For >>> instance if I create a 2x upsampling block, followed by a low-pass > filter, >>> then 2x decimation (I'm just making stuff up) can they run at different >>> frequencies? >> >> Yes they can. Running more than one clock domain in an FPGA means that >> you have to pay careful attention to the signals that cross those clock >> domains -- but it not only can be done, it is often done. >> >>> Does it makes sense for an FPGA run at its maximum frequency, higher > than >>> the ADC frequency? >> >> FPGAs don't really have "maximum frequencies". They have a number of >> different delays for various paths in the device (short paths generally >> being faster than long ones, kind of). So vendors sell them in "speed >> grades", and what clock frequencies can be reliably attained with a >> particular part is heavily dependent on the details of the design. >> >> Usually when an FPGA vendor advertises an FPGA speed it's because >> they've benchmarked the thing with some application that is inherently a >> good fit for the part, which lets them advertise the highest clock they > can. >> >> It may indeed make sense for an FPGA to run at a higher frequency than >> the ADC (and perhaps to run all the FPGA at a high frequency, to avoid >> multiple clock domains). But the higher you push the frequency of >> operation, the harder it will be for the design to meet timing. >> Consistently reaching timing closure with an aggressively fast FPGA >> design is one of the things that separates the men from the boys when it >> comes to FPGA design. >>> Could you please explain to me exactly what FPGA experts mean by > timing or timing closure? > > Does it have to do with the fact that in reality there are delays as > signals pass through the logic circuits? Yes. "Timing closure" means that when all the delays in the circuit are added up, they come out to something less than the maximum allowable delay. This allowable delay is usually your clock period, minus a bit for jitter. Modern FPGA synthesis tools will try to put speed sensitive stuff close together, to speed up a particular path -- but they can only do so much, so the FPGA designer has to specify a circuit that has a chance of working. > Also, I do not understand how a dsp block processes data rates faster > than the input. So say there is a 150 MHz input coming in and I > generate a low-pass filter that runs at 200 Mhz, I would think that > at the output at certain cycles there is nothing coming out since > there isn't enough data coming in. Am I visualizing this correctly? Your question was "Can DSP blocks inside an FPGA be higher (or lower) than the input?". I took that to mean "Can DSP blocks inside an FPGA be _clocked at_ higher (or lower) _rates_ than the input?" The answer to that question is yes -- you can parallelize your algorithm and clock the blocks slower, or you can serialize your algorithms and clock the blocks faster (for instance, if you're sampling at 50MHz you may be able to use one multiplier clocked at 200MHz four times for each input sample). For that matter, even if the block is designed to be "straight through", with no sample rate change, it could still be clocked faster than the input clock. You would just need to buffer data going into and out of the filter with FIFOs, and extract data from the filter at the same speed it goes in. And of course, you could up-sample. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●March 24, 20112011-03-24
On Wed, 23 Mar 2011 19:22:47 +0000, glen herrmannsfeldt wrote:> pacman101 <janpac01@n_o_s_p_a_m.yahoo.com> wrote: > >> I started studying ADC design and FPGA clocking and I have a lot of >> questions. > >> I would like to know if small signals that is in between the voltage >> full-scale measurement range digitized with the same amount of >> resolution? If it isn't so, is there a way such that the ADC is >> designed so that no matter what the input amplitude is, the adc always >> digitizes it at full (or near full to avoid saturation) resolution (ie >> vary the reference voltage to the ADC)? > > In the case of DVMs (Digital Volt Meters) this is called autoranging. It > was rare for analog meters, but is common for digital meters. > > It takes some time, and normally comes in discrete steps. > > In audio systems, it is called AGC or ALC, Automatic (Gain or Level) > Control. In this case, unlike the DVM case, one is less concerned with > absolute level, and more with the variation of the signal. > > Consider those two, and compare to the problem you are working on. > > -- glenBut it isn't a common function of A to D converters, if it's a function of any at all -- it's a function of the circuitry that precedes the ADC. Autoranging, however, would be the way to go. -- http://www.wescottdesign.com
Tim Wescott <tim@seemywebsite.com> wrote:>> pacman101 <janpac01@n_o_s_p_a_m.yahoo.com> wrote:>>> I started studying ADC design and FPGA clocking and I have a lot of >>> questions.(snip, then I wrote)>> In the case of DVMs (Digital Volt Meters) this is called autoranging. >> It was rare for analog meters, but is common for digital meters.(snip)>> In audio systems, it is called AGC or ALC, Automatic (Gain or Level) >> Control. In this case, unlike the DVM case, one is less concerned with >> absolute level, and more with the variation of the signal.(snip)> But it isn't a common function of A to D converters, if it's a function > of any at all -- it's a function of the circuitry that precedes the ADC.Sounds right, but some people have different ideas for what ADC and DAC mean. The converter boxes for digital television are called Digital to Analog converters, as they convert digital television signals to analog televisions signals. Likely they have a DAC integrated circuit (or more) inside. There are also DAC for audio use, to connect to the digital output of a CD player (or other digital audio source). Reading again, I would agree, but with a some generalization, a little more of the associated circuitry could also count. -- glen
In RF (since I mostly study RF), when somebody says Automatic gain control (or leveling) does the algorithm control the gain of a Low-Noise Amplifier? If not, what type of Amplifier is it controlling?>Tim Wescott <tim@seemywebsite.com> wrote: >>> pacman101 <janpac01@n_o_s_p_a_m.yahoo.com> wrote: > >>>> I started studying ADC design and FPGA clocking and I have a lot of >>>> questions. > >(snip, then I wrote) >>> In the case of DVMs (Digital Volt Meters) this is called autoranging. >>> It was rare for analog meters, but is common for digital meters. >(snip) >>> In audio systems, it is called AGC or ALC, Automatic (Gain or Level) >>> Control. In this case, unlike the DVM case, one is less concernedwith>>> absolute level, and more with the variation of the signal. > >(snip) >> But it isn't a common function of A to D converters, if it's a function>> of any at all -- it's a function of the circuitry that precedes theADC.> >Sounds right, but some people have different ideas for what ADC >and DAC mean. > >The converter boxes for digital television are called Digital to >Analog converters, as they convert digital television signals >to analog televisions signals. Likely they have a DAC integrated >circuit (or more) inside. There are also DAC for audio use, >to connect to the digital output of a CD player (or other digital >audio source). > >Reading again, I would agree, but with a some generalization, >a little more of the associated circuitry could also count. > >-- glen >
On 03/24/2011 06:00 AM, pacman101 wrote: (top posting fixed -- hint, hint)>> Tim Wescott<tim@seemywebsite.com> wrote: >>>> pacman101<janpac01@n_o_s_p_a_m.yahoo.com> wrote: >> >>>>> I started studying ADC design and FPGA clocking and I have a lot of >>>>> questions. >> >> (snip, then I wrote) >>>> In the case of DVMs (Digital Volt Meters) this is called autoranging. >>>> It was rare for analog meters, but is common for digital meters. >> (snip) >>>> In audio systems, it is called AGC or ALC, Automatic (Gain or Level) >>>> Control. In this case, unlike the DVM case, one is less concerned > with >>>> absolute level, and more with the variation of the signal. >> >> (snip) >>> But it isn't a common function of A to D converters, if it's a function > >>> of any at all -- it's a function of the circuitry that precedes the > ADC. >> >> Sounds right, but some people have different ideas for what ADC >> and DAC mean. >> >> The converter boxes for digital television are called Digital to >> Analog converters, as they convert digital television signals >> to analog televisions signals. Likely they have a DAC integrated >> circuit (or more) inside. There are also DAC for audio use, >> to connect to the digital output of a CD player (or other digital >> audio source). >> >> Reading again, I would agree, but with a some generalization, >> a little more of the associated circuitry could also count. >> >> -- glen >>> In RF (since I mostly study RF), when somebody says Automatic gain > control (or leveling) does the algorithm control the gain of a > Low-Noise Amplifier? If not, what type of Amplifier is it > controlling? It is difficult to maintain noise figure and distortion resistance while gain controlling an amplifier. So AGC is rarely applied in the front end. In a superheterodyne receiver AGC generally controls the gain of an IF amplifier, or it controls one or more attenuators in the IF strip. In a direct conversion receiver AGC generally controls the gain at baseband. At any rate, if there's AGC it generally controls an amplifier that comes after any fixed bandlimiting filters. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
I see. Is autoranging different from automatic gain control?>On 03/24/2011 06:00 AM, pacman101 wrote: >(top posting fixed -- hint, hint) > >>> Tim Wescott<tim@seemywebsite.com> wrote: >>>>> pacman101<janpac01@n_o_s_p_a_m.yahoo.com> wrote: >>> >>>>>> I started studying ADC design and FPGA clocking and I have a lot of >>>>>> questions. >>> >>> (snip, then I wrote) >>>>> In the case of DVMs (Digital Volt Meters) this is calledautoranging.>>>>> It was rare for analog meters, but is common for digital meters. >>> (snip) >>>>> In audio systems, it is called AGC or ALC, Automatic (Gain or Level) >>>>> Control. In this case, unlike the DVM case, one is less concerned >> with >>>>> absolute level, and more with the variation of the signal. >>> >>> (snip) >>>> But it isn't a common function of A to D converters, if it's afunction>> >>>> of any at all -- it's a function of the circuitry that precedes the >> ADC. >>> >>> Sounds right, but some people have different ideas for what ADC >>> and DAC mean. >>> >>> The converter boxes for digital television are called Digital to >>> Analog converters, as they convert digital television signals >>> to analog televisions signals. Likely they have a DAC integrated >>> circuit (or more) inside. There are also DAC for audio use, >>> to connect to the digital output of a CD player (or other digital >>> audio source). >>> >>> Reading again, I would agree, but with a some generalization, >>> a little more of the associated circuitry could also count. >>> >>> -- glen >>> > > In RF (since I mostly study RF), when somebody says Automatic gain > > control (or leveling) does the algorithm control the gain of a > > Low-Noise Amplifier? If not, what type of Amplifier is it > > controlling? > >It is difficult to maintain noise figure and distortion resistance while >gain controlling an amplifier. So AGC is rarely applied in the frontend.> >In a superheterodyne receiver AGC generally controls the gain of an IF >amplifier, or it controls one or more attenuators in the IF strip. > >In a direct conversion receiver AGC generally controls the gain atbaseband.> >At any rate, if there's AGC it generally controls an amplifier that >comes after any fixed bandlimiting filters. > >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.com > >Do you need to implement control loops in software? >"Applied Control Theory for Embedded Systems" was written for you. >See details at http://www.wescottdesign.com/actfes/actfes.html >
