Calibrating FFT results, amplitude in to magnitude out
Started by Brian Willoughby ●March 25, 2011
On 4/2/2011 11:17 AM, Jerry Avins wrote:
> I'm happy to call them blue numbers, or whatever you please. Sometimes my mind wanders and goes off on a tangent.
At such times, when I say "Soon", I might mean about 2+i1/3 minutes. When I'm grounded, I leave out the part after the plus sign.
> > Jerry
LOL!
Jerry Avins wrote:
> I'm happy to call them blue numbers, or whatever you please. Sometimes my mind wanders and goes off on a tangent. At such times, when I say "Soon", I might mean about 2+i1/3 minutes. When I'm grounded, I leave out the part after the plus sign. > > Jerry
And if a half wave from ground?
That's as good as grounded. A quarter wave is when I get spacey. That's a real disconnect!
Jerry
Engineering is the art of making what you want from things you can get.
On Apr 2, 1:30&#4294967295;pm, illywhacker <illywac...@gmail.com> wrote:
> On Apr 2, 5:57&#4294967295;pm, robert bristow-johnson <r...@audioimagination.com> > wrote: > > > > > On Apr 2, 5:54&#4294967295;am, illywhacker <illywac...@gmail.com> wrote: > > > > On Apr 1, 5:25&#4294967295;pm, robert bristow-johnson <r...@audioimagination.com> > > > wrote: > > > > > On Apr 1, 7:50&#4294967295;am, illywhacker <illywac...@gmail.com> wrote: > > > > > > On Mar 31, 11:02&#4294967295;pm, Jerry Avins <j...@ieee.org> wrote: > > > ... > > > > > > What is that difference, then? In the s plane, one axis represents frequency and the other, gain. The only reason co call one imaginary has to do with the way we do the math. > > > > > > They are just names Jerry, mere labels! They could be called the red > > > > > axis and the blue axis. > > > > > so when we measure or describe quantity in physical reality, they are > > > > "blue numbers"? &#4294967295;maybe, instead, we should call it "physical > > > > blueality" > > > > Might as well. The word 'reality' is pretty much content-free anyway. > > > maybe this is all an illusion. &#4294967295;maybe we're just a simulation running > > in some cosmic computer and none of this is real. &#4294967295;or our brains are > > on life-support in some mad scientists laboratory and he's just poking > > us with simulus. > > > > While I agree that there is a difference algebraically between the > > > real numbers and the imaginary numbers, as I have said in other posts > > > and i thank you for saying so. > > > > (the most obvious difference being that the imaginary numbers are not > > > a subalgebra), I do not agree that the arbitrary and historically > > > determined labels 'real' &#4294967295;and 'imaginary' have any deeper meaning. > > > okay. &#4294967295;but i still don't expect anyone to place two leads of an analog > > voltmeter and read 3.6*i volts. &#4294967295;i don't expect anyone to use a > > stopwatch to measure 10*i seconds, nor do i expect anyone to measure > > the length of anything as an imaginary number. > > > > A wave function is a complex object, and this is surely an element of > > > reality. > > > it's an abstraction that is related to reality. &#4294967295;just as phasors are > > to EEs. > > > > I am aware that observables are represented by Hermitian > > > operators, and hence real eigenvalues, but the explanation for this is > > > surely not that 'we can only measure real numbers'. First, we would > > > only have to multiply all the operators by i to get anti-Hermitain > > > operators, and suppose that our measuring devices measure imaginary > > > numbers. Second, we do not 'measure real numbers'. Real numbers are > > > limit objects, and can never be specified exactly. > > > oh? &#4294967295;i think they can, but it's real physical measurements that cannot > > be made exactly. > > > > The things we > > > measure are members of finite sets, so you could say they are natural > > > numbers. But this would be miseading too, because a measurement > > > actually consists of an isomorphism between one finite set and another > > > - a correspondence - as when we count something. > > > we measure and *describe* physical quantity with real numbers. &#4294967295;it > > appears to me that we measure physical quantity with numbers that are > > real and rational. > > > listen, i don't know anything about quantum mechanics that i didn't > > get as a sophomore or junior in college. &#4294967295;while the underlying > > equations describing the wave equation is complex valued, i know that > > the expectation values are used to make a prediction of what we might > > observe are real values. &#4294967295;they have to be. &#4294967295;i know that complex values > > are used, at an abstract level, to describe other physical processes. > > in electrical engineering and signal processing, we do it a lot with > > "phasors". &#4294967295;but they're abstractions. they represent a sinusoidal > > function of a *real* voltage at a *real* time. > > > sorry, illy. &#4294967295;nothing you said has made a dent in this. &#4294967295;all of the > > physical quantities we measure and experience are numbers that > > eventually became known as "real numbers". &#4294967295;it's an appropriate label. > > But real numers are an abstraction too; this is the point you are > missing I think. The results of a measurement is inevitably, due to > our finite abilities, an element of a finite set. So when you say the > results of measurements are represented by real numbers, this is only > because the actual measurement process is not being described: rather, > an underlying 'true value' is being invoked that, while very > convenient, has no operational status at all, just as imaginary > numbers do not.
the fact that the result of a measurement is inevitably an element of a finite set (i guess that set would be the rational numbers in a finite range) does not deprive such a result of having an operational status. r b-j
On Apr 2, 9:29&#4294967295;am, robert bristow-johnson <r...@audioimagination.com>
mused:
> > April 1, right?
I wish I were that observant. I didn't notice the April 1 date of Jerry Avins's comment that
>>given x and y, I could draw a graph of x vs. y. >>How to even think about doing that if both are >>complex quantities boggles me.
and took it quite seriously. Rather than pointing out to him that he had often worked with complex- valued functions of complex variables (such as Laplace transforms), I tried to write a parody of typical postings that start long threads, where someone claims to have read something (usually hazily remembered, and generally wildly misquoted) in an unspecified book, and then asks Why? That my posting was dated April 1 is sheer serendipitous circumstance. --Dilip Sarwate
Dilip, I really thought that yours was a reply in kind.
Jerry
On 04/02/2011 09:55 PM, robert bristow-johnson wrote:
> On Apr 2, 1:30 pm, illywhacker<illywac...@gmail.com> wrote: >> On Apr 2, 5:57 pm, robert bristow-johnson<r...@audioimagination.com> >> wrote: >> >> >> >>> On Apr 2, 5:54 am, illywhacker<illywac...@gmail.com> wrote: >> >>>> On Apr 1, 5:25 pm, robert bristow-johnson<r...@audioimagination.com> >>>> wrote: >> >>>>> On Apr 1, 7:50 am, illywhacker<illywac...@gmail.com> wrote: >> >>>>>> On Mar 31, 11:02 pm, Jerry Avins<j...@ieee.org> wrote: >>>> ... >>>>>>> What is that difference, then? In the s plane, one axis represents frequency and the other, gain. The only reason co call one imaginary has to do with the way we do the math. >> >>>>>> They are just names Jerry, mere labels! They could be called the red >>>>>> axis and the blue axis. >> >>>>> so when we measure or describe quantity in physical reality, they are >>>>> "blue numbers"? maybe, instead, we should call it "physical >>>>> blueality" >> >>>> Might as well. The word 'reality' is pretty much content-free anyway. >> >>> maybe this is all an illusion. maybe we're just a simulation running >>> in some cosmic computer and none of this is real. or our brains are >>> on life-support in some mad scientists laboratory and he's just poking >>> us with simulus. >> >>>> While I agree that there is a difference algebraically between the >>>> real numbers and the imaginary numbers, as I have said in other posts >> >>> and i thank you for saying so. >> >>>> (the most obvious difference being that the imaginary numbers are not >>>> a subalgebra), I do not agree that the arbitrary and historically >>>> determined labels 'real' and 'imaginary' have any deeper meaning. >> >>> okay. but i still don't expect anyone to place two leads of an analog >>> voltmeter and read 3.6*i volts. i don't expect anyone to use a >>> stopwatch to measure 10*i seconds, nor do i expect anyone to measure >>> the length of anything as an imaginary number. >> >>>> A wave function is a complex object, and this is surely an element of >>>> reality. >> >>> it's an abstraction that is related to reality. just as phasors are >>> to EEs. >> >>>> I am aware that observables are represented by Hermitian >>>> operators, and hence real eigenvalues, but the explanation for this is >>>> surely not that 'we can only measure real numbers'. First, we would >>>> only have to multiply all the operators by i to get anti-Hermitain >>>> operators, and suppose that our measuring devices measure imaginary >>>> numbers. Second, we do not 'measure real numbers'. Real numbers are >>>> limit objects, and can never be specified exactly. >> >>> oh? i think they can, but it's real physical measurements that cannot >>> be made exactly. >> >>>> The things we >>>> measure are members of finite sets, so you could say they are natural >>>> numbers. But this would be miseading too, because a measurement >>>> actually consists of an isomorphism between one finite set and another >>>> - a correspondence - as when we count something. >> >>> we measure and *describe* physical quantity with real numbers. it >>> appears to me that we measure physical quantity with numbers that are >>> real and rational. >> >>> listen, i don't know anything about quantum mechanics that i didn't >>> get as a sophomore or junior in college. while the underlying >>> equations describing the wave equation is complex valued, i know that >>> the expectation values are used to make a prediction of what we might >>> observe are real values. they have to be. i know that complex values >>> are used, at an abstract level, to describe other physical processes. >>> in electrical engineering and signal processing, we do it a lot with >>> "phasors". but they're abstractions. they represent a sinusoidal >>> function of a *real* voltage at a *real* time. >> >>> sorry, illy. nothing you said has made a dent in this. all of the >>> physical quantities we measure and experience are numbers that >>> eventually became known as "real numbers". it's an appropriate label. >> >> But real numers are an abstraction too; this is the point you are >> missing I think. The results of a measurement is inevitably, due to >> our finite abilities, an element of a finite set. So when you say the >> results of measurements are represented by real numbers, this is only >> because the actual measurement process is not being described: rather, >> an underlying 'true value' is being invoked that, while very >> convenient, has no operational status at all, just as imaginary >> numbers do not. > > the fact that the result of a measurement is inevitably an element of > a finite set (i guess that set would be the rational numbers in a > finite range) does not deprive such a result of having an operational > status. > > r b-j
There are an infinite number of rational numbers in a finite range! And what the hell is an "operational status"?!? -- Randy Yates Digital Signal Labs 919-577-9882 http://www.digitalsignallabs.com yates@digitalsignallabs.com
On 04/02/2011 01:30 PM, illywhacker wrote:
> [...] > But real numers are an abstraction too;
A good point. Aren't all number systems abstractions, for that matter? Go out into nature and find me an integer... --RY -- Randy Yates Digital Signal Labs 919-577-9882 http://www.digitalsignallabs.com yates@digitalsignallabs.com
On Apr 4, 2:58&#4294967295;am, Randy Yates <ya...@ieee.org> wrote:
> On 04/02/2011 01:30 PM, illywhacker wrote: > > > [...] > > But real numers are an abstraction too; > > A good point. Aren't all number systems abstractions, for that > matter? Go out into nature and find me an integer...
Yes - that is what I have been trying to say. See my reply to Robert. illywhacker;
On Apr 3, 2:55 am, robert bristow-johnson <r...@audioimagination.com>
wrote:
> On Apr 2, 1:30 pm, illywhacker <illywac...@gmail.com> wrote: > > > But real numers are an abstraction too; this is the point you are > > missing I think. The results of a measurement is inevitably, due to > > our finite abilities, an element of a finite set. So when you say the > > results of measurements are represented by real numbers, this is only > > because the actual measurement process is not being described: rather, > > an underlying 'true value' is being invoked that, while very > > convenient, has no operational status at all, just as imaginary > > numbers do not. > > the fact that the result of a measurement is inevitably an element of > a finite set (i guess that set would be the rational numbers in a > finite range) does not deprive such a result of having an operational > status.
Dear Robert, My point is that real numbers are just one rung on a ladder of abstraction, rather than there being a binary distinction between 'real' and 'imaginary'. What is more, real numbers do not hold the special place on the ladder that you claim; or, rather, they do hold a special place, but not because they are 'real'. I will tell you why I think they are special below. According to you, real numbers are special because they express the results of measurements. But these real numbers are not measurements; they are our model of measurements, and we use imaginary and complex numbers in our modelling too, even quaternions, octonions, C* algebras,... Real numbers do not faithfully represent measurements because the results of measurements can only be elements of finite sets. This is because with finite resources, we cannot distinguish an element in an infinite set. This means that effectively the results of measurements are natural numbers, except, as I said earlier and Randy points out, even this is not right, since natural numbers are an abstraction too. What are the natural numbers? If you take all finite sets, and identify sets when there exists a bijection between them, what do you have left? The natural numbers. Any measurement dos not produce a number, but only an isomorphism between two sets (for example some of the fingers on your hands and the apples in a bowl). This isomorphism is then abstracted as a natural number. Once you have the natural numbers, you can embed them in the rationals, then in the reals, then in the complex numbers. So what is special about the reals? In my opinion, what is special about the reals has nothing to do with their algebraic properties at all, but is rather connected to their topology, i.e. their existence as a manifold, a 'continuum'. The real numbers are the 'smallest' set on the above list that contain all limits. Why is this important? Why is a continuum description ever important in a world that we can only ever access at finite resolution? There are two reasons: 1) By assuming that the set of possible results of measurements exists down to infinite resolution, we can render our theory independent of the resolution of our experiments. This makes theory much easier to construct. The actual finite measurement process has to be separately described. The continuum description contains all the finite descriptions as special cases. 2) Once we have all limits, we can use differential calculus. Anyone who has ever tried to manipulate finite differences, etc. will appreciate the advantage this brings. In other words, our mathematics is much more powerful this way. Note that using real numbers is probably only a useful approximation. Fundamental physics is unanimous in thinking that space and time are 'discrete' in some sense, in which case lengths really are measured in integers. Still, at the resolutions we use to probe the world most of the time, these integers are so 'close together' that they look like a continuum. So, looking for consensus, given the 'ladder of increasing abstraction', perhaps we can agree that real numbers are 'less abstract' than imaginary numbers in some way, even if not exactly 'real'. illywhacker;
