Could some DSP guru please help ? For a sig-delta ADC, how is the cut- off frequency for the low-pass filter determined, given that there is also a decimation filter just after that. Any hints, suggestions would be of immense help. Thanks in advance.
Low pass filter for sigma delta ADC
Started by ●April 7, 2011
Reply by ●April 7, 20112011-04-07
On 07.04.2011 7:56, Daku wrote:> Could some DSP guru please help ? For a sig-delta ADC, how is the cut- > off frequency > for the low-pass filter determined, given that > there is also a decimation filter just after that. > Any hints, suggestions would be of immense > help. Thanks in advance.I'm not even near a guru, but i can tell you that the cutoff frequency of the composite response should be lower than the point where the Noise Transfer Function starts rising. Usually no one performs filtering in SDM in one step. Most often the data stream that the modulator produces is filtered by combination of sinc (running average) or CIC filter, because they are easier to implement in hardware, and one or several FIR stages. The way you choose their cutoff frequencies and decimation ratios depends on both the required in-band SNR (because after decimation all the SDM noise that is not sufficiently attenuated gets aliased into the 1st Nyquist zone) and hardware constraints (speed, area, power consumption etc). You can read more on this topic, for example, in http://www.amazon.com/Understanding-Delta-Sigma-Converters-Richard-Schreier/dp/0471465852 and http://www.amazon.com/Delta-Sigma-Data-Converters-Theory-Simulation/dp/0780310454 If you need a more specific answer then try to reword your question so that it would be a bit more informative. -- Alexander
On Apr 6, 11:56=A0pm, Daku <dakup...@gmail.com> wrote:> Could some DSP guru please help ? For a sig-delta ADC, how is the cut- > off frequency > for the low-pass filter determined, given that > there is also a decimation filter just after that. > Any hints, suggestions would be of immense > help. Thanks in advance.First decide how much of the high band aliased signal you can tolerate. Say it's 1% as an example. Then determine from the datasheet where the stopband (from the decimation filter) extends out to, say 20Mhz. Design your antialiasing filter so that at 20Mhz it has at max gain of 1/100. Usually a first or second order pole filter is all that is needed
On 04/07/2011 12:00 AM, Alexander Sotnikov wrote:> On 07.04.2011 7:56, Daku wrote: >> Could some DSP guru please help ? For a sig-delta ADC, how is the cut- >> off frequency >> for the low-pass filter determined, given that >> there is also a decimation filter just after that. >> Any hints, suggestions would be of immense >> help. Thanks in advance.(good specific advice snipped)> If you need a more specific answer then try to reword your question so > that it would be a bit more informative.Like, tell us from a systems perspective what you're trying to _do_. Are you building a sigma-delta converter from scratch? Are you using a commercial one? Is there some hybrid S-D solution out there that lets you buy the modulator but leaves you hanging as far as building the filter? I didn't address the original post because I'm not much of a S-D guru either (I've got a number of 1st-order S-D converters fielded, and they do great in narrow circumstances*, but that's baby talk compared to real S-D technology). What I do know is that there is a great deal of interaction between a S-D converter's front end and the filter -- so great, that I suspect that the real answer to your question is "analyze the front end behavior and choose a filter that makes your converter meet spec". If there are rules of thumb, I rather suspect that they only apply to specific front-end architectures, not to any old S-D modulator. * http://www.eetimes.com/design/embedded/4006431/Sigma-delta-techniques-extend-DAC-resolution, http://www.wescottdesign.com/articles/sigmadelta.html -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 4/7/2011 6:51 PM, steve wrote:> On Apr 6, 11:56 pm, Daku<dakup...@gmail.com> wrote: >> Could some DSP guru please help ? For a sig-delta ADC, how is the cut- >> off frequency >> for the low-pass filter determined, given that >> there is also a decimation filter just after that. >> Any hints, suggestions would be of immense >> help. Thanks in advance. > > First decide how much of the high band aliased signal you can > tolerate. > > Say it's 1% as an example. > > Then determine from the datasheet where the stopband (from the > decimation filter) extends out to, say 20Mhz. > > Design your antialiasing filter so that at 20Mhz it has at max gain of > 1/100. > > Usually a first or second order pole filter is all that is neededOops, that's what happens if someone is taken up with one particular application. Being involved primarily in design of sigma-delta modulators for DACs i completely forgot about such thing as the antialiasing filter :) If that is the lowpass filter mentioned in the original post, then this article may also be helpful http://www.analog.com/library/analogDialogue/Anniversary/15.html -- Alexander
